01-24-2024, 02:36 PM | #1 |
910
Rep 1,156
Oil specs are a minefield!
My car is a 2021 840i (EU spec, so has OPF). Am I right in thinking Castrol Edge 5W30 LL-04 is the right oil? Or 0W30 LL-01? The manual is as much use as if it were written in hieroglyphics…names about 10 different oils!
01-24-2024, 03:14 PM | #2 |
4573
Rep 3,537
My trick of the trade is call down to parts at your local trusted dealer ask them to look up an oil change kit and while they bring it up give you the cost ask them what the oil information is. They typically just tell you and then you can buy your own from there. Sometimes that makes the owners manual mess easier to get through but all regions are a bit different and oil is equal as long as it meets the standards (don't let things get out of control with oil threads LOL).
2022 M8 Comp Convertible
Beemer5to3910.00 bloozemanAZ4302.50 |
01-25-2024, 08:54 AM | #3 | |
4492
Rep 7,535
Does it confuse me...thankfully , no.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 01-25-2024 at 09:08 AM.. |
01-25-2024, 09:00 AM | #4 | |
910
Rep 1,156
Glad you’re not confused, but there’s more than just viscosity to think about, as you can get 0W30 and 5W30 grade oils that do not even meet BMW specification, or a 0W30 that meets LL-01 or 0W30 LL-04 spec, and the same for 5W30. Thank you for your valued input. |
01-25-2024, 09:12 AM | #5 |
4492
Rep 7,535
Here's an example from a g30 M550ix...the owners manual built into iDrive gives BMW recommendations for suitable oil viscosity...just select an oil with one of the recommendations and avoid the ones that says it is not suitable:
01-25-2024, 05:39 PM | #6 |
147
Rep 548
Ll04, mid saps, ll01 high saps. I think ppe 5w40 is good for a dd. It's very light for a 40 weight and a low flash point. Xcess gen2 5w40 for more protection.
Beemer5to3910.00 |
