BIMMERPOST Universal Forums General BMW News and Cars Discussion Do you warm up your modern-day BMW before driving off?
      02-08-2019, 06:27 AM   #89
Romanf15
12
Drives: F15 2015
after a cold start i just wait between 30sec-1min before taking off and in winter I will wait till my steering wheel warms up and also my butt.
      02-08-2019, 08:03 AM   #90
7qwerty
Drives: 2014 BMW 650i
I guess letting it warm or not doesn't matter. Just keep it on a low a bit for sometime.
      02-11-2019, 03:15 PM   #91
Fritzer
No one sleep in Tokyo
Fritzer's Avatar
No_Country
943
1,507
Drives: 2011 E90 328i//1995 E34 530i
I let my E90 warm up for about 2-5 minutes. A little bit longer because it's been hitting under 40 degrees Fahrenheit here in San Diego at night. (I know, so cold brrrrrrr)
2011 E90 328i, 1995 E34 530i, 1992 E32 740i, 1991 E34 525i
      02-14-2019, 10:50 AM   #92
PKR
21
81
Drives: 2014 F31 1948 CJ-2A
I wait until the engine comes off high idle before driving, and keep the revs low for the first few miles.
      02-14-2019, 05:17 PM   #93
Gen13 F36
Gen13 F36's Avatar
1599
3,752
Drives: 428i Gran Coupe
I just start and drive about 20 sec. That about the time I put my phone on its mount and buckle my seatbelt. And then again 20 sec plenty of time to get the oil circulate.
sspade2463.00
Ickdeep5715.50
      02-14-2019, 05:23 PM   #94
gurusan
gurusan's Avatar
93
151
Drives: 2012 335is E93
On cold starts I suggest locking it in a higher gear and flooring it, helps warm up the turbos and engine faster.
      02-14-2019, 05:41 PM   #95
Al Bundy's Dodge
No_Country
1639
903
Drives: 2018 M2 6MT
Same here. Let the revs drop, takes maybe 30 seconds. I do that year round.
Then while going light on the throttle I usually shift under 2500 RPMs for a couple miles and then keep it under 3k RPMs until the engine reaches operating temp.
All I know is what I do wont hurt the car, but driving hard after cold start certainly could.
2009 328i xDrive 6MT (Retired and I miss her)
2015 335i xDrive 6MT (Retired and I dont miss her)
2018 M2 6MT (Never retiring)
      02-14-2019, 06:10 PM   #96
RoarinRow
RoarinRow's Avatar
66
193
Drives: 2012 328i Glacier Silver
2012 BMW 328i  [0.00]
2014 BMW X1  [0.00]
I don't warm it up really, but I do take my time to leave from my spot, e.g. look at the gauges, look around my surroundings, wait for garage door to close, check my rear view mirror, etc. before actually leaving. So with all this, this is pretty much my warm up time.
2012 328i Sedan - Glacier Silver - 18" Toyo Proxes 4 Plus Tires with Nürburgring Metal Grey Rims, H&R Sport Springs, VRSF Intercooler, JB+, aFe Air Filter, Magnaflow Exhaust, Carbon Fiber accents, SS Pedals, Bavsound System, BMW CCA member since 2015. First Bimmer - 2000 Z3 M. Second Bimmer - 2014 X1 sDrive28.
      02-14-2019, 07:25 PM   #97
rmata
Drives: BMW 330i
Warming up the car is a practice that is not current anymore with all fuel injection vehicles. In fact letting the car warm up in idle for the car means that the "normal" functional temperature will take longer to be reached, and the car will have to compensate that by injecting additional fuel into the combustion mixture and we can say that that is "not beneficial".
a few seconds or a minute or 2 is more than enough to make the oil engine moving, after that driving smoothly until it reaches the "normal" operating temperature is the best practice for the sake of the motor
      02-15-2019, 03:49 PM   #98
OUGrad05
521
859
Drives: 2023 i4 and 2022 Acura MDX
No need to idle for minutes on end. You want oil pumped back to the top of the engine which occurs in the first few seconds of running, then take it easy on the gas until there's temp in the coolant AND in the oil.
2023 i4 eDrive40
2022 Acura MDX
      02-16-2019, 04:32 PM   #99
yco
i'm just saying
yco's Avatar
5723
2,634
Drives: E71 X6M '10 (sold)
the duration of warming up depends on the temperatures for me but i believe waiting a little is good for every engine.. in hot summer days a 50-60secs will be enough.. in really cold ukraine winter i do wait 2mins at least.. and in super cold winter days i never turn off the engine when its super hot.. like pushing it for a while before reaching the destination.. i believe its not good also.. driving calmly in last 3-4 mins before i arrive..
if more than 12 hours past i do wait at least rev goes down.. for my current ride i press M button and wait till exhaust flaps open on its own.. then i go.. driving progressively higher revs till oil reaches optimal levels..
below -10c things are not like that cause viscosity changes also.. thicker oil cant reach every part of the engine %100 for a while.. actually cold start behaviors is affecting a lot for engine's lifespan.. not even talking about turbos..
OUGrad05521.00
      02-17-2019, 09:19 AM   #100
OUGrad05
521
859
at -10*C yes you'd need 45 seconds or a minute to get enough oil moved around.
My garage drops to about 50* when its in the teens F* outside, so it has to get pretty darn cold to drop the temp in my garage to the mid 40s. That's only happened once or twice and both times it was below zero F outside
If you're car is constantly in temps that are well below freezing you may need to let it idle for a short period but no need for a 10 minute idle session.
2023 i4 eDrive40
2022 Acura MDX
      02-17-2019, 05:12 PM   #101
Efthreeoh
17139
18,670
It's called multi-viscosity oil for a reason...
      02-20-2019, 07:05 PM   #102
korakisa
Drives: F30 320i
I wait few seconds until the engine comes off high idle .Also a little before switch off engine.
      02-21-2019, 10:00 AM   #103
EDWYER
Yoda of mods
EDWYER's Avatar
1670
3,004
Drives: X5 RWD
2015 X5 RWD  [0.00]
2016 BMW M2  [10.00]
I wait 15 seconds and drive.
Current: 2020 Explorer ST (Agate Black Metallic), F15 SGM RWD
F87 AW (retired) F30 SBM 316rwhp/440rwtq (retired)
Follow me on Twitter: https://twitter.com/EdwyerCLT
YT: https://www.youtube.com/@DWYERGARAGE/videos
      02-21-2019, 08:16 PM   #104
Alfisti
6493
3,030
Drives: 2008 Saab 9-3 Combi
Originally Posted by MJBO View Post
Basically I start and drive away.
I start my car, plug my phone in, put my keys/wallet in their respective places, then drive off. My park is three stories up and by the time I get to the swipe sensor to open the gate cold start has finished.
Accelerate pretty gentily until oil temp is at normal then enjoy a few higher revs.
If the temps were crazy cold like in some places in the world? I’d probably give it more time before setting off, but “cold” here in Melbourne is like 10C (50F), so no need.
You have NFi what cold is. NONE, fuckign zero. Shuddup.
      02-21-2019, 08:18 PM   #105
MJBO
MJBO's Avatar
Australia
2580
1,454
Drives: 2023 G81 M3 Touring
If the temps were crazy cold like in some places in the world? I'd probably give it more time before setting off, but "cold" here in Melbourne is like 10C (50F), so no need.
Lol, trust me I know that 😂
      02-21-2019, 08:23 PM   #106
Alfisti
6493
3,030
Originally Posted by Huz-Z View Post
Its typically quite cold in winter here.
Fucking Canadians .... "quite Cold". It'll hit 3 degrees and be sunny soon and everyone will walk around saying "oh it's a beautiful day".
      02-28-2019, 10:41 AM   #107
taseal
79
182
Drives: '15 Corvette, '15 X5,
I don't let it warm up... but that being said, I live in FL and coldest it gets is in the 30s... mostly 70-90f weather.
My corvette shows me an alternative redline until engine warms up. Pretty sure some other BMWs have this. I go by that.
      02-28-2019, 12:55 PM   #108
gatorfast
gatorfast's Avatar
4989
6,859
Drives: 718 Cayman
It maybe touches 39 degrees for one hour a year in south florida Its been a hot winter this year.
BMW M cars have a variable red line which increases as the engine warms up. However, even the reduced red line its still far too high to rev on a cold engine. I always keep it below 3k rpm until the oil temp needle has come off its resting position.
      02-28-2019, 02:11 PM   #109
taseal
79
182
it sure has been a warm winter...
I wonder if car's shift points change to upshift more when engine is cold?
Also what is the running temp for our cars generally? US cards are 190-210.... I noticed this X5 runs around 230.
      02-28-2019, 02:23 PM   #110
gatorfast
gatorfast's Avatar
4989
6,859
Drives: 718 Cayman
My car is a manual so I control the shift points, but I dont think the autos take engine temp into consideration. As long as you are not in D3/sport+/performance driving modes and accelerate mildly the transmission will likely never shift above 3k rpm.
Search this Thread:
Advanced Search
