01-18-2024, 12:19 PM | #1 |
177
Rep 60
Drives: M850i xDrive Gran Coupe
[SOLVED] Mystery Plug - Center Console
EDIT: turns out I’m an idiot sandwich and it was indeed for the wireless charger. I didn’t recall removing two plugs, but seems I did. It’s just hidden in the bottom corner of the charger which is why I didn’t notice after plugging one of the two connectors in. Thanks for the help regardless!
Hey everyone, Had the incredibly tedious process of swapping out my interior trim this week, and upon reassembly, I noticed something odd that I hadn’t noticed when removing the center console. A mysterious black/purple connector. It does not belong to the wireless charger, the USB/cigarette lighter, nor anything to do with the gear shifter area. Does anyone know what this is supposed to be for? Am I crazy or did I forget something? Pic of connector: View post on imgur.com Last edited by Bimmertron; 01-19-2024 at 05:13 AM.. |
01-18-2024, 12:39 PM | #3 |
4570
Rep 3,534
Just like dubbrand said I would assume its just option you don't have.
01-18-2024, 01:45 PM | #4 | |
1591
Rep 4,553
OP, based on the photo your car is an early MY20 build? My guess would be October 2019 build date? If so, that's pre covid so the unknown connector wouldn't be for an option constraint due to component shortages. If you don't notice anything not working, and don't receive any diagnostic messages, then I guess don't worry about it. However, my guess is it might go to some button on the console or the ambient lighting running thru the console, etc ..
2023 840GC | 2021 740i | 2019 X3
01-18-2024, 01:56 PM | #5 | |
4570
Rep 3,534
01-18-2024, 02:06 PM | #6 |
1591
Rep 4,553
Likely because your build was during covid related chip shortages and in the US there was no configuration of the 8 series that did not offer the wireless charger (except the covid shortage scenario). Typically, if a market offered no wireless charger as standard and you didn't order the option, you wouldn't get the wiring to retrofit it later. With BMW it's been that way for about the past 15 years.
01-19-2024, 06:04 PM | #8 |
239
Rep 96
Weird. Doesn't really make sense to custom build a harness based on a specific build. I was into Hondas and acuras when I was younger the harnesses were all the same. If you wanted to add the option the wiring was already there for you.
01-19-2024, 08:43 PM | #9 |
1591
Rep 4,553
BMW was like what you described up until 2008 or so when they shifted to custom harnesses. Anything to save a dime for each car built.
