04-14-2020, 01:30 PM | #1 |
5139
Rep 3,235
Not buying this guy's Toyota Corolla dyno results
I'll just cut to the chase. Been having a back and forth on a different forum where someone was claiming significant horsepower gains by just reducing exhaust restriction on the current gen Toyota Corolla with the M20A engine. My stance was that any aftermarket exhaust system would only be for sound, aesthetics, and maybe weight savings.
So he produced a dyno chart posted on 2JRacing's FB page showing by adding an intake, headers, less restrictive mid pipe, and cat back that they were able to get 30WHP gain on the factory tune. To me this doesn't pass the smell test as that's huge for what amounts to be an econobox that is naturally aspirated. I also looked deeper into the dyno run where they claim the base line run put the horsepower at 151whp. That didn't seem right to me assuming a 20% loss would mean they're claiming the stock setup is at 189 crank HP. The factory rating is 168 HP. With their mods, their dyno run shows 180whp which would translate to 225 HP at the crank. So in essence, this tuner is claiming a 33% increase in just bolting on an intake and exhaust over the factory HP number or 20% over their measured stock baseline with no tune. Something doesn't add up. What are your thoughts? |
04-14-2020, 01:49 PM | #2 |
Clean is the new cool, keep it that way.
808
Rep 1,683
Seems like BS to me, even on a custom tune I would doubt it. Dyno settings are easy to manipulate, so trusting a dyno sheet is pretty dumb.
edit: a Quick search shows that OV tuning did get 27WHP out of a stock M20A Corolla though on a custom tune.
04-14-2020, 02:28 PM | #6 |
3931
Rep 3,972
Does it matter?, it's a corolla.
14
G3min1110.00 IllSic_Design2122.50 Pauldunlop13417.50 Conissah1574.50 zx10guy5139.00 BigHunk269.50 euro*1654.00 quick6750.50 jmg18493.00 MisterF80M31045.50 ntg442887.50 XMetal1096.50 MmmmmM22578.00 paliknight2186.50 |
04-14-2020, 03:49 PM | #7 |
6024
Rep 3,610
Dyno readouts can be fudged by any company.
1/4 mile and 60-130 times can't. i'd be curious to see what kind of trap speeds guys are running with their setup compared to stock
2018 Porsche GT3 6MT 2021 M2C DCT Previous: Ferrari 458 | R35 GTR | F80 M3 | E46 M3 | E36 M3 | Scion FRS |
04-14-2020, 04:47 PM | #8 |
2870
Rep 3,445
You know what they say, if it's too good to be true, it was probably tweeted.
04-14-2020, 05:44 PM | #9 |
1Addict
3202
Rep 7,860
This is most likely done by cherry picking results by doing a nonideal low read baseline and perfect conditions and highest read after mods.
Having done similar mods on past NA cars, including Japanese makes, I call total BS. Most I ever saw from this kind of thing was ~15hp.
zx10guy5139.00 infinitekidM2C4185.50 |
04-14-2020, 07:08 PM | #10 |
/M Enthusiast
1596
Rep 1,617
They turned that thing into a beast!
Ok, I really doubt a near 20% gain with bolt ons and no tune. They should have bought something with a 2.0t it would of had way more torque and hp to start with, then throw a tune on it, done!
2019 M2 Comp, Alpine White, DCT, track car build, 1/2 cage, AP Racing Brakes & Nitron Coilovers, BM3 Stage 1 93 Oct.
2018 Porsche Cayman GTS, Night Blue Metalic, PDK, COBB tuned 93 Oct. 2004 Audi A4 Avant USP 6mt, RS4 clutch, built motor, Garrett GT3071r "Big Ass Turbo" Motoza Tune |
zx10guy5139.00 |
04-14-2020, 09:55 PM | #12 |
2870
Rep 3,445
A few things to think about. On NA engines, displacement, compression ratio, max RPM (helped out by lightweight parts) and things like that determine the maximum power. A good way to figure this out is to look at same displacement and similar and different compression-ratio engines and see what they make. That usually gives you an idea if it's possible or not. Also, aren't these more limited by RPM, being NA? As in what else could possibly be going on here? I suppose that air induction could be crazy restrictive, but that just doesn't make any sense with all the other parameters involved.
I don't believe there would necessarily be a 20% loss, maybe if it was a RWD or especially an AWD vehicle (20% is much closer to AWD figures, my RWD only loses about 12%). Being FWD, that Corolla probably only loses around 10%. The engine is probably up around 200hp according to the chart, assuming all of this. Just a real quick cursory look shows small displacement 2.0-ish type engines having to rev to around 8K to make 200hp. Yeah, it's really fishy.
zx10guy5139.00 |
04-14-2020, 10:39 PM | #13 |
5139
Rep 3,235
Unless this happened recently, OV Tuning wasn't able to come up with a tune for the M20A. There's a long thread on Toyota Nation where OV promised to come out with a tune. Then they said they were close. Then gave up.
04-14-2020, 10:44 PM | #14 | |
5139
Rep 3,235
I just wanted to see if I'm not some sort of dinosaur where there was some magic potion being sprinkled on these 4 bangers that would make these gains plausible. |
04-14-2020, 11:23 PM | #15 | |
2870
Rep 3,445
zx10guy5139.00 |
04-14-2020, 11:26 PM | #16 |
11572
Rep 12,712
why is this surprising? its a turbo car choked up with emissions crap and they remove all the restrictions.
Instagram; @roastbeefmike
04-14-2020, 11:53 PM | #17 |
5139
Rep 3,235
There is no turbo. The engine in question is a Toyota M20A naturally aspirated motor.
04-14-2020, 11:54 PM | #18 |
i'm just saying
5723
Rep 2,634
actually its a pretty nice engine that using both port and direct injection with whopping 40% thermal efficiency aside you cant get 30whp by changing here or there without remapping out of a 2.0L engine..
few ways to achieve such results by using a lower gear on stock run and higher with bolt ons.. you can multiply kW by 1.4 not 1.34 like it should be.. or different fuel.. i guess the half of the gain d be plausible.. or after remapping the engine it can produce 50% more power than Toyota engineers could achieve which then these guys deserves a trophy..
zx10guy5139.00 |
04-14-2020, 11:56 PM | #19 | |
5139
Rep 3,235
04-15-2020, 12:05 AM | #20 | |
11572
Rep 12,712
i rented a corolla a few years back when i was in colorado for a wedding. the combo of that car plus the altitude was almost dangerous when trying to merge onto the freeway. my foot was through the floor getting on the on-ramp and it had a hard time reaching the speed of the flow of other cars in a reasonable amount of time. it was that terrible.
04-15-2020, 08:50 AM | #21 | |
1803
Rep 1,011
Take that as you will. |
04-15-2020, 07:53 PM | #22 |
2006 TIME Person Of The Year
9720
Rep 6,445
I was just watching a YouTube review on the turbo-4 Mustang and was surprised to learn Ford says the car gains 20 HP by just using premium fuel. Not WHP and a different car, but to me this does provide some perspective.
