BMW M8 Forum and 8 Series Forum BMW M8 and 8-Series General Discussion Display Key battery issues
      07-03-2023, 04:54 AM   #1
chillo
chillo's Avatar
United Kingdom
32
52
Drives: 840d Convertible
Been having issues with my display key display powering the display briefly when i press on button then going blank so can't access the menu's on it.
Have had it charging and it seems to be not able to hold charge. Nearly got stuck yesterday as it was dead but managed to plug into a usb charger which powered it up and unlocked the car otherwise I would have been stranded!
Going to replace the battery as assume that is the problem that the battery is dead.
Anyone done this? no issues doing?
Q. How would you get into the car if the display key is dead/flat battery and no way of charging it?
840d Convertible with B&W
F430 Spider
Mustang GT Shadow convertible (manual!)
Ducati Panigale v4r
Ducati 1299s
      07-03-2023, 05:05 AM   #2
maechthildt
Germany
51
32
Drives: BMW M8 Competition
You can unlock the car with your mobile. Also mine came with a plastic card key you can put in your wallet for emergencies.
      07-03-2023, 05:15 AM   #3
chillo
chillo's Avatar
United Kingdom
32
52
I was away from my home
My car is a 2019 build so don't think i can use my mobile or the digital key card as wasn't this only enabled for 2020 on build cars?
F430 Spider
Ducati Panigale v4r
Ducati 1299s
      07-10-2023, 09:57 AM   #4
Milquetoa$t
59
23
Drives: 2019 BMW M850i, BMW Motorrad
There are YouTube videos on how to replace the rechargeable battery on the display key. You can also power down the display key by holding the power button down until prompted, you will also notice a message that tells you the physical buttons (lock,unlock) will still work with the display completely powered off. This will help with battery conservation until you can replace it. Lastly the key card will work on a 2019, I purchased one from the dealership because my pre-owned did not come with one. It was about $60 and you will need your VIN and proof of ownership to order one.
      07-11-2023, 03:27 AM   #5
chillo
chillo's Avatar
United Kingdom
32
52
So I bought a new battery (MKD35UP 580mAh) which sorted this!
All good now!
F430 Spider
Ducati Panigale v4r
Ducati 1299s
Appreciate 3
