12-21-2022, 02:58 PM | #1 |
4269
Rep 4,335
HK to B&W With Match DSP
Since it's a popular topic saw this in the "news" section of Bimmerpost. Good walkthrough to end up with near B&W from HK leveraging the Match DSP as doubt you can buy the upgraded RAM unit required for B&W from BMW.
https://g05.bimmerpost.com/forums/sh....php?t=1978330 |
12-21-2022, 04:48 PM | #2 |
9052
Rep 7,621
I skimmed through it. Did he mention what it all cost anywhere?
FlorinQCK-2.50 |
12-21-2022, 05:06 PM | #3 | |
156
Rep 114
"So overall, very happy with this mod so far. All together I'm probably in about $3000 which is a lot (add another $700 for the B&W grills)...." I spent $3400 to have a professional high end installer put in the Match 10UP amp, 2 Match 8" 2 Ohm subs and a DSP tune. Sounds fantastic. I'll put it up against any B&W, B&O, etc. It's all about that amp and the tune. The HK drivers are fine. |
FlorinQCK-2.50 |
12-21-2022, 05:58 PM | #4 | |
9052
Rep 7,621
FlorinQCK-2.50 |
12-21-2022, 06:00 PM | #5 | |
4269
Rep 4,335
The B&W regardless of the naysayers creates a tight and accurate bass that I feel in my chest while driving. It's not just the subs under the seat but the overall sound panorama which includes the door and center console midrange drivers. Just was sharing as a pathway for those with HK and looking for a potential alternate path. |
12-21-2022, 06:26 PM | #7 |
9052
Rep 7,621
Ah, ok, now I see.
FlorinQCK-2.50 |
12-21-2022, 06:36 PM | #8 | |
156
Rep 114
12-21-2022, 06:40 PM | #9 | |
4269
Rep 4,335
Small fortune is always a lost in translation. My home audio gear is a small fortune to the tune of a well loaded 5 series. 😜. Don't tell the wife as she's clueless to that. 👍 |
r33_RGSport12971.00 FlorinQCK-2.50 |
12-30-2022, 08:13 PM | #11 | |
4269
Rep 4,335
My #1 vice is horology and have a few in the collection worth more than my house (which is golden on my balance sheet). Once again the wife is clueless as we've been married for 9 years and I built a trust prior to doing so and the trust owns all true assets so no need for a pre-nup. 👍. Home audio not included as it is a rounding error lost in translation. |
subterFUSE563.50 FlorinQCK-2.50 |
12-31-2022, 02:21 AM | #12 | |
271
Rep 189
FlorinQCK-2.50 |
12-31-2022, 02:25 PM | #13 |
4269
Rep 4,335
Actually have some further refinements plus actual settings, e.g., how many clicks up from neutral on each EQ setting as unfortunately the UI doesn't list the frequencies. Had to do that in case an OTA or dealer shenanigans wiped them out. No way I wanted to start over after 2 plus years of calibration. Will dig that up and share.
FlorinQCK-2.50 |
12-31-2022, 03:27 PM | #14 | |
271
Rep 189
FlorinQCK-2.50 |
01-01-2023, 11:53 AM | #16 | |
4269
Rep 4,335
That said I have memory button #4 to take me straight to the bass trim (never have to monkey with the treble trim). The key being the source SSD vs SiriusXM or just the mix of the album for a tweak (click or 2) up/down to adjust the bass. In general SiriusXM is a click 2 up and then when back on SSD (all high res 92/24 FLAC) a click 2 back down. Technically not needed but I'm an audio perfectionist. |
Beemer5to3907.00 FlorinQCK-2.50 |
01-01-2023, 12:02 PM | #17 |
907
Rep 1,154
bloozemanAZ yeah i listen to a lot of rock, with some heavier stuff too (Metallica, Foo Fighters etc). Don’t suppose you’ve got a photo of your EQ setup? I tend to stick to Studio as the soundstage, as I’m not a fan of any false sound, albeit to B&W does it much better than the Logic7 on the HK system!
FlorinQCK-2.50 |
01-01-2023, 03:32 PM | #18 | |
4269
Rep 4,335
Totally agree on the DSP aspect as my only disappointment is there is no way to defeat it whatsoever. 1st thing I did on my wife's X5 was disable Logic7 in the HK. I did an audio comparison between HK and the base system and the HK was a no brainier $600 option. They offered the B&O for $3900 but the dealer didn't have anything on the lot with it and frankly even if it was stellar wouldn't have included in the order anyway as not my DD and used that cash to option up all the non-standard safety features, add ACC (best you could get at the time) and the HUD. One thing I miss about the outgoing Lexus was it's Mark Levinson, defeatable DSP and DVD-A support in the 6 disc changer. Just loaded it up with all DVD-A discs with 5.1 sound and it was pure bliss. Have all of those DVD-As and a boat load of SACDs all ripped into FLAC on my 2TB SSD in the M850i. Would love to hear them with the DSP defeated. |
FlorinQCK-2.50 |
01-01-2023, 04:00 PM | #19 | |
4269
Rep 4,335
All calibration was done against the same high res tracks I use for all audio testing: new home audio components, the HK vs B&W, etc. They are selected off of some of the best studio album mixes, e.g., Steely Dan's Aja, Chris Rea's Road to Hell and Yo-Yo Ma's Haydn: Cello Concertos. Once dialed in all genres work like a champ unless just a crappy mix, e.g. Ozzy's Bark at the Moon. I owned a pair of B&W 801s (paid $35K for the pair and sold on Audiogon for $30K) for a couple of years and the components on the 8 series are sourced from them. So it was relatively easy for me to calibrate with just the factor of the cabin size of my coupe in play. The bass trim setting is for SiriusXM but as stated before if too heavy when on my SSD just press memory #4 and slightly tweak. The final key being the sound profile set to Concert. When first getting the car and being a purist I thought studio would be the best especially for the 5.1 sources on the SSD. Nope not even close and Studio is also DSP fabricated anyway or otherwise it would cancel out the center channel on the dash which it does not. Lastly to get the sound envelope opened you need at least 40% volume. Hence, when solo I relish in the B&W audio but when the wife's in the car then it's the BMW exhaust. 👍 |
FlorinQCK-2.50 |
01-01-2023, 04:02 PM | #20 |
4269
Rep 4,335
Keeps barfing on the attached pic so trying again.
That failed too. Must be the Bimmerpost bug that sometimes reorients a picture sideways but in this case just barfs (it's a supported JPG). B&W Audio Settings Base 6 100 Hz 4 200 Hz 3 500 Hz 2 1 kHz 0 2 kHz 2 5 kHz 3 10 kHz 3 Treble 0 Trim Treble 0 Bass 6 |
01-01-2023, 04:26 PM | #21 | |
271
Rep 189
FlorinQCK-2.50 |
01-01-2023, 04:36 PM | #22 |
4269
Rep 4,335
As mentioned in the first post with the failed attachment Concert. That said I've only tried Studio and Concert with the latter being the clear winner. Didn't go past Concert once I had pure perfection dialed in. May give the others a shot for grins to see if there is any room for improvement but doubt it as every layer added to the DSP complicates the calibration.
