BMW M8 Forum and 8 Series Forum BMW M8 and 8-Series General Discussion Shifter removal??
      12-06-2023, 01:32 PM   #1
fmzip
Spoiler Bandit
fmzip's Avatar
1650
872
Drives: 2019 M850i / 2016 228i
Shifter removal??
In order to access the bolts that hold the shifter in place, does this piece just snap into place?
      12-06-2023, 04:44 PM   #2
jeezz
50
63
Drives: BMW
What I know is you have to remove the whole unit you see on the photo.. from the CID screen to the armrest. Then you can get it out of the car and unscrew the shifter from the back side.
yep it's crazy every other BMW it's just like unclip the cover around it...
      12-06-2023, 06:50 PM   #3
fmzip
Spoiler Bandit
fmzip's Avatar
1650
872
Thanks for the info. Have you done this before? Looking at these pics, I thought the piece would snap in and out??
      12-06-2023, 07:17 PM   #4
jeezz
50
63
Drives: BMW
I just removed the whole unit once for another job, so I didn't check how this cover is mounted.. but from what I see on your last picture, looks like the cover piece is plastic welded. So you would have to grind them welds off from the bottom.
      12-06-2023, 08:52 PM   #5
fmzip
Spoiler Bandit
fmzip's Avatar
1650
872
Thanks for the info. So is it best to work from top to bottom to get the whole trim piece out? Speaker cover, display etc?
Trying to install these and get access to this connector by the shifer
      12-07-2023, 08:39 AM   #6
jeezz
50
63
Drives: BMW
Ah ok, for this install you definitely have to remove the whole center stack.. I also have these Buttons installed.
It's been some time. You have to remove speaker cover, display, cup holder, nfc pad, back seat, center console trim in the back, center armrest storage compartment, center arm rest itself.
      12-07-2023, 09:07 AM   #7
fmzip
Spoiler Bandit
fmzip's Avatar
1650
872
Thanks bud....guess this is going to be more of a project than anticpated!
      12-07-2023, 02:53 PM   #8
jeezz
50
63
Drives: BMW
It sounds worse, just take time it's no big deal.
      12-07-2023, 08:12 PM   #9
fmzip
Spoiler Bandit
fmzip's Avatar
1650
872
I already have had the back seat out to take out the center arm rest leather and cubby. Also took out the cup holder before so it's likely not going to be too difficult (famous last words!)
      12-08-2023, 06:48 AM   #10
fmzip
Spoiler Bandit
fmzip's Avatar
1650
872
Jeez, did you remove the whole section in one piece like this?
      12-08-2023, 07:47 AM   #11
jeezz
50
63
Drives: BMW
yes
      12-08-2023, 07:55 AM   #12
fmzip
Spoiler Bandit
fmzip's Avatar
1650
872
yes
Thanks, Do you recall if there are more mounting points than circled?
      12-08-2023, 09:10 AM   #13
jeezz
50
63
Drives: BMW
These have to be all
      12-08-2023, 10:23 AM   #14
fmzip
Spoiler Bandit
fmzip's Avatar
1650
872
Thanks for the assist...is the one you noted "back" visible after removing the cup holder?
      12-08-2023, 10:26 AM   #15
jeezz
50
63
Drives: BMW
No like I said nfc pad need to be removed
