04-02-2016, 10:49 AM | #111 |
2033
Rep 8,339
Those did not look like bi xenon on the test pics. They looked like yellow halogens standard on the 328i e9x series. Is the new F series 3s considerably worse than the e9x series? Maybe I'm mixing up my beams. I mean HID. I have the adaptive HID lights on my 335i.
04-02-2016, 12:08 PM | #112 |
45
Rep 167
Drives: '18 540i '15 X5 '03 530i
Everybody who owns a bimmer with halogen lights agree it is insufficient lighting and beamed so low. Even older bmw's are same as i had difficulty seeing the road in my '03 e39.
I've tried different bulbs and just went back to silverstar ultra and adjusted low beams. If anyone wants to adjust, i suggest not going more than 5 clicks (adjuster screw have detents)to the right to gain approximately 250 ft. low beam focus. i can see road better now. |
04-02-2016, 12:38 PM | #113 |
Rep 1
I recently ordered a new 228i without the lighting package, and the car is now in transit to the West coast. When I called the dealer and asked about the headlight issue, I was told higher discharge bulbs can be installed for $185.00, which are supposed to extend the beam and are "almost as good as the xenons". He said they know about the problem and that's why they keep the bulbs in stock! l'm not buying a new car that has crappy headlights that I have to pay extra to be almost as good as the marginally rated xenons. Maybe they should have mentioned this to me when I was placing the order? The dealer is waffling on whether the deposit will be refunded.I am going to the dealer today to cancel my order for this car. Dependent on the dealer response I will either walk away or start over with a new build which will include xenons. This is disappointing for my first BMW purchase experience.
04-02-2016, 01:24 PM | #114 |
5150
Rep 3,241
I just don't understand why BMW doesn't change their factory specs to resolve the aim of the low beams. Based on what I'm seeing in this thread, it's a common problem for those that actually care about seeing well at distance at night. Unfortunately, the US is full of drivers which shouldn't be driving in the first place and these people don't care.
04-02-2016, 01:47 PM | #115 | |
1622
Rep 3,402
04-02-2016, 02:55 PM | #116 |
390
Rep 859
Drives: 2017 Alfa Giulia Quadrifoglio
My F80 with Euro coded LEDs are excellent. If the U.S. stop restricting innovation, automobile lighting will advance rapidly.
04-02-2016, 03:10 PM | #117 | |
1622
Rep 3,402
04-02-2016, 04:24 PM | #118 | |
Brit Abroad
392
Rep 707
Drives: 2016 Frozen Black M4
2016 ///M4 / Frozen Black Metallic / Full Sakhir Orange Leather
Instagram @M4TTE_BMW More info and photos here. |
04-02-2016, 04:43 PM | #119 | |
Rep 37
Drives: 2015 BMW 328 i xDrive M Sport
It's not that all Halogens are bad, the Base Honda Accord Halogen headlights got Acceptable ratings. It's how these halogens are designed. The 3 series ones are really bad
04-02-2016, 05:34 PM | #120 | ||
281
Rep 4,121
04-02-2016, 05:57 PM | #121 | |
351
Rep 1,684
I brought this on myself as I wanted a stripped down X1 for my wife as she refused any options saying she didn't want it. But, I am trusting BMW that even in its base config that my car will perform like a BMW. And that means a baseline of safety. BMW should have killed off its stock lights years ago. But, if they do that then they can't tout the performance of xenon or LED to be X times better. BMW should offer to retro all stock underperforming headlights built and sold during the past 5 years. I mean, it's the headlights people. |
04-03-2016, 01:53 AM | #122 |
175
Rep 4,302
Drives: M135i
LEDs/xenons STILL aren't standard here on the 335d; that's a £45k car. My old one (E91) didn't have them either.
Luckily the M135i has them as standard. For bad lights try a LR Defender; you're better off holding a lit match up to show the way. The only vehicle in which I upgraded the lights. |
04-03-2016, 11:16 PM | #123 | |
2759
Rep 6,760
I've had to adjust them on every single BMW I've had so far. Rule of thumb, give it 3 turns (unscrew motion) on each knob, see how you like it. If you need to go more than 5-6 turns you should take it to a shop because your left/right headlights may no longer be correctly aligned to "meet" at a distance.
2018 F80 Santorini 2019 Z4 3.0i 2022 X2 M35i |
04-04-2016, 04:10 PM | #124 | |
723
Rep 912
04-05-2016, 12:44 PM | #125 |
TIM YOYO
1504
Rep 3,283
Drives: 2013 M3
So much misinformation in this thread it's making my head spin. They tested way more than the halogens. The AutoBlog article just sucks. You're far better off checking out the IIHS results directly.
They tested two models with several different headlight configs: 2-Series - HID - Halogen 3-Series - LED - Halogen They tested with and without adaptive and high-beam-assist, where available. You can see detailed test results on the respective vehicle test pages; just click on "headlights" in the menu. BMW 2-Series BMW 3-Series Toyota Prius (best in test) There are some great charts on that site that show the performance of the headlights. You can see that the BMW really only falls short because of its low-beam performance. As most have noted, that is an adjustment issue. For example, here's the 3-Series halogen, 3-Series LED adaptive, and Prius LED: 3-Series halogen 3-Series LED adaptive Prius LED
His: 2019 R1250GS - Black
Hers: 2013 X3 28i - N20 Mineral Silver / Sand Beige / Premium, Tech Past: 2013 ///M3 - Interlagos Blue Black M-DCT Past: 2010 135i - TiAg Coral Red 6MT ///M-Sport |
04-05-2016, 01:07 PM | #126 | |
233
Rep 417
The autoblog article isn't that great when it comes down to the details, and they mostly got it from a blurb on the IIHS site, but it does mention that there were different bad scores for the more premium headlight options for the 3er. Either people didn't care to address that and just wanted to get on a soapbox, or failed at reading.
Current: 2016 BMW M235i | 2013 BMW X1 xDrive28i (wife's)
Gone but not forgotten: 1992 Buick LeSaber Limited | 1999 Acura CL 3.0 | 2003 Volvo S60 2.4T | 2006 BMW x3 3.0i | 2009 Honda Fit Sport |
04-11-2016, 11:07 AM | #127 | |
2316
Rep 4,341
Sad that a Prius that is slower lights the road better. |
07-12-2016, 01:38 PM | #128 |
233
Rep 417
Add the X1 to the list of marginal scores:
07-18-2016, 06:29 PM | #129 |
244
Rep 701
Did it say what kind of light on the Acceptable ones?
I know CR-V only has projectors on the Touring trim and all others have reflectors. CX-3 has Halogen and HID.. |
07-18-2016, 07:33 PM | #130 | |
1889
Rep 5,506
It sounds like they are just going to put in some replacement bulbs for you in the stock halogen housing. That's something you can easily do yourself for much less. The actual improvement in lighting would be minimal as well. Just the dealer trying to rip you off by "upgrading" your headlights with some "xenon" colored bulbs.
Auto Detailing Enthusiast!
07-19-2016, 09:54 AM | #131 | |
TIM YOYO
1504
Rep 3,283
Drives: 2013 M3
http://www.iihs.org/iihs/news/deskto...hs-evaluations Vehicle: High Beam/Low Beam Ford Escape: HID/HID Honda CR-V: Halogen/Halogen Hyundai Tuscson: LED/Halogen Mazda CX-3: LED projector/LED reflector Keep in mind that they way they rate these headlights is very complex. It's not a simple matter of "LED > HID > halogen". They factor in illumination from multiple angles, as well as glare.
07-22-2016, 05:24 PM | #132 |
244
Rep 701
Thank you.
I care more about low beam performance since i rarely use my LED high beam. If that comparison graphic on top is actually accurate... Holy shit... you can almost see twice as far in a Prius than my LED. Not that i am going to get a Prius but it would be nice if i can see a little further at night, especially the driver side. |
