05-18-2017, 08:00 AM | #2 |
41
Rep 93
Reply from KW
I sent an email to KW about recommended settings and this was the reply I received. I am going to Autobahn this weekend and I'm gonna try it. I will report back next week.
Dear James, the M Performance coilover was developed on BMW guideline and it is different to the KW V3. for track you can close the rebound and bump front and rear 2 – 3 clicks. Street settings would be rebound 9 clicks and bump 4 clicks at the front axle and rebound 9 clicks and bump 4 clicks at the rear axle too.
2024 GLS
2016 X5 |
Sungillest101.50 |
05-18-2017, 04:29 PM | #3 | |
80
Rep 270
FRONT are 9 clicks open REBOUND + 6 clicks open COMPRESSION REAR are 12 clicks open REBOUND + 6 blicks open COMPRESSION thats what ive been using. But will try with harder settings next time out.
06-08-2017, 01:26 AM | #4 | |
587
Rep 898
I'll play with the rebound & compression more after I get an alignment. Can you do me a favor? Can you try seeing how many clicks from full stiff the compression is on your fronts? My front left shock is a bit hard to adjust for some reason. |
06-08-2017, 07:29 AM | #5 | |
80
Rep 270
TUNEDM360.00 |
06-08-2017, 07:39 AM | #6 | |
300
Rep 379
If you do have some experience. My recommendation would be camber plates. You will need them or you will destroy the outsides of the front tires pretty quickly. Ground Control and a few others have plates for the OEM strut size, which is what the MPC is. Edit: Oh... just noticed "M3 track car" in your sig. You will want camber plates, brake fluid and pads too.
BMW CCA and PCA HPDE Instructor
Former BMW CCA National Capital Chapter HPDE program Chairman 2021-2022 |
06-08-2017, 07:48 AM | #7 | |
41
Rep 93
The E36 had -3.5 with 1/16" toe out in the front and -2 with 1/16" toe in in the rear. TC Kline Coilovers. They gave me a recommended setting for the coils when I bought them and I never changed them in 2 yrs. lol They just worked that well! I will most likely leave it for Sat and maybe experiment a little on Sunday. I'll report back on Monday.
2024 GLS
2016 X5 |
06-08-2017, 12:02 PM | #8 | |
587
Rep 898
Can you do adjustments on damping when car is loaded, or does it have to be unloaded? |
06-08-2017, 04:33 PM | #9 | |
80
Rep 270
I'm gonna try now -3 or maybe -3.5
06-08-2017, 04:38 PM | #10 | |
80
Rep 270
I dont think it matters if car is loaded or not when adjusting for damping...
cookiesowns587.00 |
06-14-2017, 02:44 PM | #11 |
41
Rep 93
The car did great at Putnam however I don't think -2.5 was quite enough. I may try -2.75 or a little more next time. There was a little more wear on the outer edges of the fronts. I am gonna stiffen it a little more for next time though. I think I will try about 3 clicks on both rebound and compression but we'll see. I was really impressed, the ambient temperature was around 90F both days and my oil temp didn't go above 220F while on the track. I think BMW has the oil temp issues figured out.
2024 GLS
2016 X5 |
06-14-2017, 03:54 PM | #12 | |
798
Rep 1,368
