11-27-2023, 03:37 PM | #1 |
11
Rep 21
Climate Control system not working
I got in the car today and noticed there was no air coming through the vents. I tried recirculating, max A/C, the spinning the dials on each side of the vents, just feet, just dash, just defrost, super low temp, super high temp…nothing. Has anyone experienced this? If so, what was the outcome/solution? Thanks for the help.
11-27-2023, 04:28 PM | #2 |
4540
Rep 3,508
Do you have it set on Auto because if you do the car will pick to location in which the air comes out of. That's the only thing I can think of right now.
2022 M8 Comp Convertible
11-27-2023, 04:29 PM | #3 |
4448
Rep 7,489
Was the ambient temps cold? If yes, the system is designed not to blow cold air on the passengers. If you drive a few miles and the car comes up to operating temps...does warm air then start to blow from the dash vents?
11-27-2023, 04:57 PM | #4 |
11
Rep 21
It was about 40 degrees out, but I had just left the gym and was trying to cool off. I thought the outside temp,may have something to do with it, but when I couldn’t get any hot air to blow either, I started to get more concerned.
11-28-2023, 03:13 PM | #7 |
4448
Rep 7,489
Thanks for the update...hope its something simple and easy to correct.
