04-09-2024, 03:30 PM | #1 |
551
Rep 1,070
Oil Drain Plug Kits?
Been doing research on oil drain kits to make the process easier but $150 on the AGA hose kit seems pretty steep but I did find a potential solution on Amazon for $50. Can't really tell how the clearance is and I've searched the forum with no results on this item.
Curious if anyone has tried this or any other solutions other than AGA? I know Kies tried the fumamoto but it ended up shearing off so that's a no go. |
04-09-2024, 04:03 PM | #2 |
368
Rep 935
AGA is tried and tested. Amazon may be cheaper, but you get what you pay for. I wouldn't cheap out on such a simple/important piece. S55 engines are expensive if u had to replace due to some kind of failure ...better yet, just leave the drain plug as it is and invest in a good floor jack and jack stands...
04-09-2024, 04:10 PM | #3 |
68
Rep 56
Femco and Stahlbus are some other options. I have a Femco compact valve that I'd be installing the next time I do an oil change. I chose Femco over Stahlbus since it's a little bit lower profile.
1heckinboi44.00 |
04-09-2024, 04:39 PM | #4 | |
1127
Rep 1,322
04-09-2024, 04:43 PM | #5 | |
551
Rep 1,070
arfboy26.00 |
04-09-2024, 11:01 PM | #6 |
33
Rep 45
Here is a list from my notes. I didn't get one because of clearance concerns and metal compatibility (I have a magnesium pan).
I was also planning to add a cover plate over the drain plug opening on the skid plate with a piece of metal for additional protection, in case I did get one. Code:
femco compact sb m12x1.5-t12 looks low profile. 12mm height. brass. stahlbus m12x1.5x12mm, steel steel, depth is 22mm with cap, 21mm without cap. inside depth 12mm fumoto f-139 brass ezoil ez109 nickel-plated brass, 29mm depth, fumoto style. aga clean oil drain plug silver colored, $99, 4.5mm stock head, depth 10mm. |
louielouie550.50 1heckinboi44.00 |
