01-27-2021, 10:05 AM | #1 |
19550
Rep 10,190
Random I-Drive Shut Down Issues...thoughts???
This just happened a few times over the past 2 weeks. I would drive the car (after not driving it for several days) and within a few minutes my I Drive will shut off completely and then turn back in a few seconds.
EG: I drove the car last night for the first time since Friday and about 1 mile in, the I-Drive shut down and then it turned on right away. I drove the car about 30 more miles with no issues. I then drove it back home about 3 hours later with zero issues. Could this be a power source issue or lack of it due to limited driving? I cant see that happening since I had no issues for the prior 7 weeks of ownership but one never knows. Anyone else have this type of experience? I know I can take it to the dealer as they will be the only one to rectify it but was just asking the community here their thoughts.
2023 BMW M8 Coupe Competition Alpine White 2022 Porsche Carrera GTS Coupe Shark Blue 2020 Audi R8 V10 Performance Suzuka Gray 2012 Mercedes Benz C63 AMG Black Series Obsidian Black Last edited by Vic55; 01-27-2021 at 11:37 AM.. |
01-27-2021, 12:47 PM | #2 | |
4425
Rep 4,109
Has it been coded? |
Vic5519550.00 |
01-27-2021, 12:50 PM | #3 | |
19550
Rep 10,190
2023 BMW M8 Coupe Competition Alpine White 2022 Porsche Carrera GTS Coupe Shark Blue 2020 Audi R8 V10 Performance Suzuka Gray 2012 Mercedes Benz C63 AMG Black Series Obsidian Black |
01-27-2021, 01:03 PM | #4 |
4425
Rep 4,109
01-27-2021, 01:11 PM | #5 | |
19550
Rep 10,190
I didn't have time to have him do more so I picked that at the time for no specific reason.
01-27-2021, 01:31 PM | #6 |
1920
Rep 2,011
Drives: 2022 i4 M50
Sounds like this could be an overheating issue if it's mainly happening shortly after startup, that's when the CPU is likely working the hardest but the cooling components might not have as much of an effect with the ambient temp. Has it been more typical after sitting around in the sun or in a warm garage for a while?
Not saying it should be normal, just a slight issue on the hardware end that's being magnified by the situation. Voltage drop could possibly be an issue as well, but hopefully not the case. Granted, nobody is going to want to trace it out specifically, so if it's not throwing any codes pointing to an electrical problem, the trouble shooting will probably start with a few hard resets, followed by re-flashing the software, followed by replacing the head unit.
Current: 2022 i4 M50 | 2022 G07 X7
Gone: 2020 F92 M8 | 2020 G07 X7 | 2018 F80 M3 | 2017 F15 X5 | 2016 F16 X6 | 2015 F36 4 series GC |
Vic5519550.00 |
01-27-2021, 01:36 PM | #7 | |
19550
Rep 10,190
Its always in a garage before being driven except after I take it out and drive it for a while and park it where it may be. But the initial start up (cold) is in my garage.
01-27-2021, 01:55 PM | #8 |
19550
Rep 10,190
I wonder if this will work
limeypride unfoundnemo
unfoundnemo1920.00 |
01-27-2021, 02:00 PM | #9 |
1920
Rep 2,011
Drives: 2022 i4 M50
Yeah, that's what I meant by the hard reset, definitely worth a try in case there are any gremlins floating around. I'd think that having the car sit for 30+ min would have the same result, but hopefully that does it.
Vic5519550.00 BMW Lunatic474.00 |
01-27-2021, 02:24 PM | #10 | |
19550
Rep 10,190
Its sad that the system comes to that.
01-27-2021, 02:27 PM | #11 |
605
Rep 909
Is your car on the latest software? Do you have the chance to read out the fault codes via an app such as Bimmertool? That is the first thing I would do next to resetting the unit. Often you will not know there is an error code behind it unless you read it out with one of the meant tools. If you do that and establish that no errors are being thrown then the next thing would be report it to the dealer. Most likely the latter will suggest a software update...... And take it from there. If it's a software issue the update most likely will solve it. Of course as some suggested the scenario of having to replace the headunit is also possible. Keep us posted.
Resjudicata1604.00 |
01-27-2021, 02:44 PM | #12 | |
19550
Rep 10,190
I appreciate the details, Ill report back for sure.
01-27-2021, 03:29 PM | #13 | ||
4425
Rep 4,109
LMAO |
01-27-2021, 04:43 PM | #14 | |
605
Rep 909
A great tool (app) which is used and talked about a lot here at Bimmerpost is bimmer tool: https://bimmer-tool.com/ To run it you will need an OBD II Adapter and although many will work, these are the recomendations: https://bimmer-tool.com/index.php/adapters/ Another program I can advise is bimmer link: https://www.bimmerlink.app/ Check the specs of the OBD II adapter you have and compare. Before buying one you should of course try the one you have. Both are great tools for reading out fault codes and also for clearing them as well as to do a whole range of other things. For example after installing a tune previously on my F32 435i engine I once had a catalytic converter temperature error (until I installed a catted DP). No code appeared in cluster so unless I hooked up the OBD II with bimmer tool there is no way I would have known that. It's just a simple example but it can often make a difference because you might discover something well before a potential problem may manifest itself. |
Vic5519550.00 |
01-27-2021, 05:00 PM | #15 | |
19550
Rep 10,190
01-27-2021, 06:09 PM | #16 | |
4298
Rep 4,364
The reason for the skepticism is my M850i lived through this past AZ summer season which had the record number of days for triple digit temperatures. Even in the garage it was 80 degrees easy and taking it on a drive the first few minutes put it in 115 degrees and I never experience an iDrive reboot. Hence, FBMWWINS' advice on checking fault codes, etc. is sound advice if the iDrive reset does not do the trick. |
01-27-2021, 06:14 PM | #17 |
6332
Rep 2,369
Drives: Z4 M40i
Was taught reset/reboot is a 70 sec hold on the volume button. It goes on & off a few times. I'm using the native Spotify app. Gets wonky (highlighted song, album art) if I use shuffle feature. Any thoughts? Been wondering if dealer can separately uninstall/reinstall ConnectedMusic/app.
01-28-2021, 09:33 AM | #18 | |
1604
Rep 2,937
my unit will reboot after updating the maps and "re-syncing" if I go "off the grid" for a while. We live in DC, but have a mountain cabin that's so far into WV that we don't get signals of any kind (no cell, no GPS, no wifi, nothing). However, when you said that it keeps happening multiple times; amd combined with the most likely guess of overheating; plus BloozemanAZ says it doesn't overheat in AZ; I'm "guessing " by reasonable deduction from all the above given facts; that you might have a defective head unit. I'd see if the dealership can reprogram the software, or reformat and replace. if not, you might need a whole new idrive. |
01-28-2021, 02:37 PM | #19 | |
1920
Rep 2,011
Drives: 2022 i4 M50
In actuality, if it is a "defective unit", the real defect would probably be something as simple as a chip that isn't set in correctly or some thermal paste that was applied a little light in one area, fairly common for those types of components in general. Definitely agree as I mentioned that the troubleshooting route would start with hard resets and move to reinstalling software and then replacing the head unit assuming it's not throwing any faults otherwise.
01-29-2021, 09:50 AM | #20 |
19550
Rep 10,190
Well the hard reset apparently did NOT work as I drove the car in the PM and it shut down before mile 1 and then no issues for the next 9 miles. It wasnt even hot outside here in SoCal and no issues a few hours later on the way back.
Time to see the damn dealer. But more than that; thank you to all for your input and suggestions.
01-31-2021, 07:46 PM | #21 | |
4298
Rep 4,364
01-31-2021, 09:33 PM | #22 | |
3160
Rep 1,844
Fingers crossed it's a minor bug!
2024 M8C; 2024 X6MC; 2021 G80 M3C; 2022 P992140
RETIRED: 2021 F93, 2021 F96,2019 F82 M4C, 2018 F80 M3C, 2018 F86 X6M- black fire, 2015 F13 M6, 2015 F10 M5, 2012 F10 550i M-Sport, 2012 F13 650i X-Drive, 2009 E60 535i M-Sport, 2007 E60 530i |
