01-16-2023, 01:21 AM | #1 |
104
Rep 61
M850i tires: what are you running?
I’m unimpressed with the Bridgestone S007 durability and thinking of a change for the next set on my OEM wheels. I’d like to retain max summer performance characteristics, but I do need to compromise a little for a tire that can still run in the occasional rainstorm or 40°F temp. No snow, monsoon, or truly cold weather.
What are the current (i.e. available) alternatives that you’ve chosen and how have they performed? TIA, Rich |
01-16-2023, 07:34 PM | #2 |
704
Rep 245
Drives: MY24 Porsche Taycan
Mine is merely the 840 lol, but I changed mine out for ultra high A/S (Continental ExtremeContact DWS06+) bc I need to be able to drive when temp drops well below 40. I also wanted a taller sidewall front and rear to fill out the top of the wheel well a bit more so went with 40 front, 35 rear. Tire Rack is a great resource for tires. There are typically a lot of customer reviews and rankings for dry, wet, etc. and Tire Rack does testing on a lot of the tires in different conditions. And if you want summers, Michelin summers are usually really good.
MY24 Porsche Taycan | Neptune blue | Black |
MY24 Audi SQ5 Prestige | Mythos black metallic | Magma red Nappa Retired: MY23 BMW 840i Coupe | MY21 Audi SQ5 | MY19 Audi A6 |
Van_bimmer108.50 rw99104.00 |
01-16-2023, 09:11 PM | #3 |
249
Rep 172
My completely flat S007 agrees. I’ve had deep tissue massages that have been harder than this tire.
rw99104.00 chancellorbeem36.50 |
01-16-2023, 10:15 PM | #5 |
303
Rep 187
Drives: 2023 M8 Competion Coupe
Pilot Sport All Season 4
01-17-2023, 12:34 AM | #7 |
5223
Rep 1,799
I have the pilot sport all season they are ok but not like the ps4's. When winter breaks I'm tempted to swap. I also went up to 40 and 35 very good move.
OK, you're just the person I want to talk to. I've been thinking about upsizing my tires, too. If fact, I started a thread in the General BMW News section on this topic 2 days ago https://f92.bimmerpost.com/forums/sh....php?t=1984646 You seem to be the first I've run across that's pulled this off. I take it you went to 245/40/20 and 275/35/20 - if you kept the OEM wheels. These are the Alpina tire size, although it has a wider wheel set. The discussion has been whether it's prudent to increase OEM tire diameter on cars that may have been engineered for a specific tire size. The consensus (from tire shops, performance shops, BMW techs and forum people has been: No, no, no, sure, keep the four tires in the same ratio as OEM and you'll be fine, shouldn't be a problem, stay OEM. So, did you research this, talk to anyone who might actually have knowledge of this topic or just know because you're a real car guy? The wheel well on the 8 really needs your size tire.......as you probably know. How long ago did you do it and have you noticed any problems, aside from the speedo reading (it's actually probably reading closer to the true speed now). Oh, are you running any spacers? Thanks. And oh, and a few pics would be nice, too. |
01-17-2023, 05:30 AM | #8 | |
271
Rep 189
01-17-2023, 06:56 AM | #9 | |
5223
Rep 1,799
The Alpina is hatched out of an M850. A lot has been written about what they change, however I've never read anything that addresses the larger tire profile. But they put real tires on it. The M850 uses a very low profile on 8" fronts and 9" rears. The Alpina has a 20" wheel and a 21" wheel. They use the same width tires as the M850, 245 and 275, but they bump the rim width to 8.5" and 10". Your wheels also got pushed further out. Hence, my statement about the wider wheel set. If you went to the 21s, you'd be back to your rubber bands again. The Alpina 20s are all season. The 21s go with performance summers, and back to the pothole problem. I'm going with a 9" front and a 10.5" rear and then upping the widths to 255 and 285 in the Spring. I ordered Michelin PS4s at the OEM height, but I really want to go your route. Do you think you could PM me your tech's info? I'd like to chat with him for a few minutes. Aside from a better ride, how is the handling? You must give up some with the higher profile, but then get some back with the wider stance, although the tire widths still remain the same. How long have you had this setup? Thanks. |
01-17-2023, 09:25 AM | #10 |
994
Rep 762
Continental ExtremeContact™ DWS06 Plus all seasons
Very smooth ride, so far gripping perfectly for my type of driving
01-17-2023, 09:16 PM | #11 | |
271
Rep 189
I mean if Alpina decided that size worked for them who am I to argue. Besides I really have no choice. Driving in the NYC area with the old spec I was bending a rim a month while being very careful. Now haven't bent one in over a year. It's amazing what a difference an inch of sidewall can do. Also this is a m850 problem our friends with m8's have about the same amount of sidewall we are looking to create. |
01-17-2023, 09:26 PM | #12 |
4269
Rep 4,335
A definite sensible choice as ran similar Continentals on my sport sedans. Total grip for anything a normal driver needs including spirited drives but definitely not a track car solution.
TupperBMW994.00 |
01-17-2023, 09:30 PM | #13 | |
4269
Rep 4,335
BigMofoFrog180.50 |
01-17-2023, 10:48 PM | #14 |
1291
Rep 1,658
Mine came with Pilot SS’s as part of the ZTK pkg. Luv Michelin Pilots, and been using them on a variety of cars since they first came out
01-18-2023, 12:54 AM | #15 | |
5223
Rep 1,799
01-18-2023, 02:37 AM | #16 |
271
Rep 189
I haven't checked the speedometer vs gps in my new car but in my old it was off about 3mph before the larger tires and perfect after. Go figure. You also asked how long I have run this setup id say 2 years. 20 months on my 2019 m850 convertible 4 months on my 2023. The rims and tires that came with my 23 haven't seen 1 mile and they are available. Lol
snowbimmer5222.50 |
01-18-2023, 10:50 AM | #18 | |
5223
Rep 1,799
The tire size change amounts to about a shade over 3% difference in revolutions per mile. So you probably have one of the most correct BMW speedometers around now. |
01-18-2023, 08:16 PM | #19 |
104
Rep 61
Thanks, all, for the input and info. I bit the bullet and ordered some MPS4 All Seasons in OEM sizes. I’ll report back on my impressions of them in a few months.
And for anyone still running on S007s, keep a very watchful eye on the inside/outside shoulders of your tires. And keep ‘em fully aired up! |
01-21-2023, 01:51 AM | #20 |
271
Rep 189
Resjudicata if my memory serves me correct you changed tires and opted for 35 and 40 like I did. snowbimmer needs our handholding
snowbimmer5222.50 |
01-21-2023, 02:07 AM | #21 |
5223
Rep 1,799
01-22-2023, 02:56 PM | #22 |
704
Rep 245
40 front/35 rear really fills the gap…
rw99104.00 Bogdan Rad11.50 |
