04-08-2009, 03:08 PM | #1 |
13
Rep 362
'09 Nismo 370z
damn...now i'm considering one of these. this car has a really nice clean look to it IMO. I'd say....Nismo 370z > 335i.
Quote from Edmunds: ---------------------------------------------- The first Nismo Z didn't come around until the end of the Nissan 350Z's model cycle, but Nissan isn't w asting any time with the 370Z version. The 2009 Nissan Nismo 370Z hits U.S. dealerships in June, and this time it has a little more power and torque than normal Z-cars, thanks to a 350-horsepower version of the 3.7-liter VQ-series V6. Nissan expects the track-focused Nismo model to account for 5 percent of all Z coupe sales. As with the original Nismo Z, the chassis and bodywork for the 2009 Nismo 370Z have been developed by Autech, the Japanese company that prepares Nissan's entries for the Japanese Super GT (JGTC) racing series. But Nissan has been more heavily involved in the engineering of the 2009 Nismo Z, and the automaker had final approval on the design. Probably that's why Randy Rodriguez, the Nissan Design America designer who's credited with the initial sketches for the regular 370Z, is pretty happy with how the 2009 Nismo 370Z turned out. "I think it's much better than the last version," he tells us. "The last Nismo was kind of busy and didn't really accentuate the design very much. There was a lot of stuff added to it, and this one seems to be a little bit more refined." At a glance, though, the 2009 Nissan Nismo 370Z appears to compromise the new Z-car's effort to slim down to pure sports-car dimensions. The Nismo's wheelbase remains 100.4 inches, but at 174.3 inches in overall length, it's 7 inches longer than the normal 370Z. It also has a 0.6-inch wider track than the Sport-package 370Z, due to the wider rims of the lightweight forged-aluminum Rays wheels. They measure 19-by-9.5 inches in front and 19-by-10.5 inches in back. Aerodynamic considerations dictated the longer body for the Nismo Z, which is, after all, meant to be a racing car that just happens to have a carpeted interior, not to mention DOT-legal tires (Yokohama Advan Sports, 245/40ZR19 98Y in front and 285/35ZR19 99Y in the rear). The front and rear fascias are radically different, and most of the extra length is in the nose. This adds a few extra pounds, as the Nismo's curb weight is listed at 3,300 pounds versus 3,232 for a base, manual-shift 370Z. "I know it's for performance reasons that they put a really long nose on it," says Rodriguez. "Those JGTC cars are really low and super wide, and they make them longer, too. There's an old Datsun 240Z called the G-Nose that I used to own. It was an extended-nose version of the regular 240Z, and the Nismo kind of reminds me of that." Rodriguez is even fine with the large rear wing Autech has put on the 2009 Nismo 370Z to increase downforce. "Actually, I think the wing should be bigger. And I wouldn't mind seeing a more extreme version of the Z that's even more aggressive, wider and lower — and with at least 370 hp." Underneath its showy aero bits, the 2009 Nismo 370Z is no less hard-core than the 350Z Nismo. Autech still takes the standard Z-car chassis off the assembly line and welds the seams of the unit body by hand — a labor-intensive process that increases structural rigidity beyond that of a normal, spot-welded unibody. Mass dampers are then fitted between the unibody's left and right frame members to control the extra vibration inherent in a seam-welded chassis. Of course, there are extensive suspension changes, too. The Nismo Z gets hollow antiroll bars, so they're lighter than the ones on the regular 370Z. The front bar is just 15 percent stiffer, but the rear antiroll bar is 50 percent stiffer, so the Nismo 370Z should turn in so quick, it'll seem it all happened yesterday already. The front strut tower brace is stiffer, too. Overall, the 2009 Nissan Nismo 370Z has 40 percent better front-end rigidity than a regular Nissan 370Z. As for the rear end, it's a huge 140 percent more structurally rigid. Roll stiffness is up 15 percent, too. So, yeah, you're going to notice something's up as soon as you get into the Nismo Z. Spring rates are 15 percent higher than the regular 370Z in front and 10 percent higher in the rear. We're cautiously hopeful the ride won't be as harsh as on the Nismo 350Z, but aren't about to place any bets. The Nismo has the same 13.7:1 steering ratio as ordinary 370Z coupes, while its brakes are identical to those of the Sport-package 370Z, featuring 14.0-by-1.3-inch front discs and four-piston fixed aluminum calipers and 13.8-by-0.8-inch rear discs and two-piston fixed calipers. To get that 350-hp rating, Nissan revised the ECM tuning of the VQ37VHR engine and fitted a less restrictive exhaust. The exhaust pipes are laid out in an H configuration for the Nismo 370Z instead of the Y-pipe on the regular Z, and have, of course, been tuned to deliver a deeper sound. The 350 hp peaks at 7,400 rpm versus 332 at 7,000 rpm in the normal Z. Redline remains 7,500 rpm, though, so you'll really have to work to use that extra power. Torque edges up 6 pound-feet to 276 lb-ft at the same 5,200-rpm threshold. You can only have the six-speed manual transmission in this car, and it drives the rear wheels through a standard viscous limited-slip differential. Also standard is Nissan's neat SynchroRev Match feature, which gives you one less thing to worry about on the track. Nissan isn't making any 0-60-mph predictions for the Nismo Z, but the company is predicting 18 mpg city/26 mpg highway EPA ratings — the same as for a regular 370Z coupe. Aside from the black-and-red cloth upholstery and a plaque identifying the car's birth order in the limited-production run, the interior of the 2009 Nissan Nismo 370Z is the same as every other Z car. But don't go looking for a navigation system or a bunch of subwoofers. This is the track-day Z; you'll have air-conditioning and a basic four-speaker stereo with an aux jack and you'll be happy about it. Inside Line says: Another out-of-the-box solution from Nissan for those of you who want to track a Z car, and this time the Nismo Z is pretty enough to park in pit lane or your driveway. — Erin Riches, Senior Editor
'10 E92 335xi space gray/coral red
'07 WRX STi |
04-08-2009, 03:11 PM | #2 |
68
Rep 1,456
Drives: 2008 E92 335i
It looks a lot nicer than in stock form. I don't like the crease on the front bumper though; looks like a pseudo dive plane. But if you went from a 335i i am willing to bet that you're going to hear more road noise. If you don't mind that then go for it.
04-08-2009, 03:54 PM | #4 |
663
Rep 26,878
Drives: 2-325 330 2-335 2-Z4 2-135 X5d
Wow i actually like.
04-08-2009, 03:58 PM | #5 | |
Smiling Politely
1381
Rep 29,118
i love it
04-08-2009, 04:53 PM | #9 |
248
Rep 6,125
Only thing I have issue with Z (or any other non-luxury line cars) after having BMW for 2nd time is that lack of leather and soft plastics that BMW uses everywhere.
Too much hard plastic interior. I really liked C350 sedan but I just couldn't see myself touching too much "hard plastics" while everyone outside enjoy the beauty of the new C-class that I make full payments of. But I do like how it looks on this Nismo and yes- I would consider this one as well. I testdrove regular 370Z. it sounds soooo good and drives like P-car. You point and car goes exactly where you pointed. Def. bang for the bucks sports car.
PAST: F80 M3 ZCP | 911.1 C2S | F10 M5 ZCP | E70 X5M | E90 M3 | E46 M3 | E36 M3 |
04-08-2009, 05:21 PM | #11 |
D to the X to the B!
345
Rep 2,106
I like it but I dont think the 335i falls in the same category. They shouldn't be compared.
Nismo 370z is a track vehicle and the 335i is a daily driver which is good on the track too. Anyway, kudos to the nismo 370z. It's not bad at all. Better looking then the old nismo 350z.
11 corvette C6
04-08-2009, 05:57 PM | #12 |
228
Rep 20,998
im not digging the front bumper
09' E92 335i | 6MT | Montego Blue | Black Dakota Leather | Dark Burl Walnut | Premium | Sport | Cold Weather | Nav | Sirius | Comfort Access | iPod and USB adapter
04-08-2009, 06:25 PM | #13 |
51
Rep 2,361
04-08-2009, 06:31 PM | #14 |
27
Rep 707
Not digging the front bumper either. Plus, that thing is probably going to be pretty expensive, I would think. Top of the line 370's are 40ish, I would assume this would be more expensive, although it lacks the nicer interior (aka leather and nav from what I could see) of the optioned out regular 370's.
-Ben |
04-08-2009, 08:42 PM | #15 |
***** noob
1370
Rep 10,479
$40ish is MSRP....you could get a fully loaded under $40k
04-08-2009, 11:50 PM | #18 |
***** noob
1370
Rep 10,479
^^thats a fly catcher
04-09-2009, 01:22 PM | #20 |
509
Rep 1,570
Drives: 2013 LRP M3 Coupe
I like it.. I'd take off the wing tho.. but I like the redesigned front fascia without the "shark's tooth".. really nice job on the Nismo Z this time around..
04-09-2009, 01:56 PM | #21 |
2006 join date crew
182
Rep 1,482
Front bumper is missing something, fogs? vents on the sides where fogs should be? rear is nice
04-09-2009, 02:02 PM | #22 |
aka 1013MM
1253
Rep 9,545
whats the price on this?
