08-02-2007, 07:45 AM | #89 | |
18
Rep 229
There are MANY LS2 cars that dyno 340-350 on a regular basis, I've seen some in the mid-high 350s. |
08-02-2007, 07:48 AM | #90 | |
18
Rep 229
08-02-2007, 07:59 AM | #91 | |
Rep 10
08-02-2007, 08:09 AM | #92 | |
18
Rep 229
08-02-2007, 08:19 AM | #93 | |
Rep 13
Curious to hear that BMW helped design the suspension on the GTO. I will have to take a look into that. That would explain a lot. Definitely respect the BMW suspensions. |
08-02-2007, 09:21 AM | #95 |
18
Rep 229
HOT car man! Looks dead sexy in black. I assume you've got the Procede? Was the GTO an 04 or an 05+? GTOs are VERY tricky to launch...you don't see a lot of good ETs at the track without some tire or suspension mods. Best i got mine to do was 13.3@109 because I basically had to baby it out of the hole and all through first, matting it resulted in MASSIVE wheel hop. I didn't feel like breaking any driveline parts.
08-02-2007, 10:24 AM | #97 | |
18
Rep 229
05+ came with the 6.0 LS2 400hp and have the hood scoops and the split dual exhaust rears...obviously faster. I was looking at your timeslip, your 60 is decent...but if you can cut a 1.90 or a 1.8XX you should hit 12s. 1 tenth on the 60' should net you 2 tenths by the end of the 1/4. |
08-02-2007, 11:34 AM | #98 | |
Rep 76
I have Garretts (USA), the new kit uses mitsubishi(JAPAN). Go research the install threads with the genTT. Notice they've had issues with the turbos coming too close to the headlights and also downpipe issues. That's an engineering problem right there. And please tell me of anyone at ls2gto.com that trapping "over 130 mph" with any genTT kit.
My crew. 2005 GTO Twin Turbo 10.8 at 133 mph 11 psi 4050# race weight |
08-02-2007, 12:21 PM | #99 |
Rep 13
Sweet looking car. I normally go up to Gainesville pretty often for Gainesville Raceway. I am currently waiting to pick up a set of Mickey's and then I will be up there a lot more. Hope to see you up there.
08-02-2007, 01:16 PM | #100 | |
76
Rep 1,883
08-02-2007, 02:25 PM | #101 |
70
Rep 1,565
http://www.airpowersystems.com/ls1/us_gto.htm
It's this kind of crap that makes me mad about our M3. Gee, look, somebody can produce a TT kit for another car for $6k. You can get 1 turbo for $16k with 1 or 2 vendors that is basically a custom build at this point. Messed up. |
08-02-2007, 05:42 PM | #105 | |
Rep 76
http://www.ls2gto.com/forums/showthread.php?t=14661 The factory LS2 pcm is setup to be extremely sensitive to IAT's as it's stock 10.9:1 compression is right on the edge for 91 octane. That's why you may see lower dyno figures occasionally as anyone who dyno's in hotter weather is subject to that issue and the pcm pulls timing pretty aggressively.
08-02-2007, 09:29 PM | #106 |
478
Rep 3,044
Drives: 2011 Dakar Yellow M3, 2018 M5
In my experience....
I've had two road encounters with GTO's, and in my experience they've been pretty formidable competition against my PROceded 6MT 335i coupe.
In my first run in, we agreed to run from a dig for one block. His car was auto, and with my bad start (didn't feed the clutch properly) he gained about 1.5 car lengths on me very early, and from there my car kept pace dead even. In my second run in (with a different GTO), it was clear the guy's GTO was modded, because when he blipped his throttle (6MT) his exhaust gurgled like an old muscle car. I'm guessing at the least he'd played with his exhaust. We did a rolling start from about 20mph, and i immediately took 2-3 car lengths on him, at which point he ended up keeping pace and never letting the gap increase. I'd like a few more run ins for a better approximation of how these cars really match up, but so far it seems to me that in the higher gears the cars are pretty evenly matched, it's mostly a lower gear race. Question: i understand that there has been an engine upgrade since 2004, but are there different engine variants available for the current 2007 models? from what i can tell, all post 2004 GTO's are running the same engine. somebody please correct me if i'm wrong. i'm curious to know what exactly i'm running against.
[ESS VT2-625] [Akrapovic Evolution Exhaust] [KW Clubsports] [OSS Angel Eyes] [Revinora r-CRT Lip] [Vorsteiner Boot] [Challenge Race Diffuser] [See the Build Thread HERE] |
08-02-2007, 09:46 PM | #107 | |
148
Rep 5,389
|2009 RENNtech MB C63 AMG | Black/Black Leather/Black Maple | Premium II | MultiMedia | iPod | | TeleAid | Charcoal Filter Delete | BMC High-Flow Air Filters | High-Flow Secondary Cats | Clear Side Markers | |
08-02-2007, 10:14 PM | #108 |
813
Rep 3,974
Very nice run. So you also saw faster times from your car than any of the fairly stock GTOs. I mean, I personally watched and took pictures of about 4 different GTOs at LACR. None of them came close to the 13's. On average I was beating them by about a second in my stock 335i. So if anyone else beats them at the track, and gets to see what their actual times are compared to the 335i, please post them. We will then get a better idea of how fast they are. Its hard to tell in a street race with such closely matched cars. I mean, one person can jump on the throttle .30 seconds earlier, and that could be the outcome of the race. One thing I'm trying to figure out is why the 335i seems to be so inconsistant with mods. I mean, if I could consistantly get 50 more horsepower out of my car with software, it would be great. But I have seen non-stock 335i track times that are barely different than my stock one. I think it has to do with particular temps, etc, and how the computer pulls timing, etc. Although my runs were almost at 100F at high altitude.
08-03-2007, 12:15 AM | #109 |
Rep 76
Here's a list of the top 15 bone stock LS2 GTO drag times that have been posted at ls1gto.com. Notice that while the e.t. varies some, trap speed is pretty consistent at 108 mph (+/- 1 mph or so - the slower mph cars are more than likely automatics).
LS2 Stock Classes: 1) PhantomGoat06 12.88 @ 108.9 2) NYTIGER 12.920 @ 109.40 MPH 3) Boilermaker GTO 12.9299 @ 106.89 MPH 4) 05torridred60 12.971 @ 108 MPH - SAP mufflers 5) jumbojet 12.974 @ 108.08 MPH 6) BlackSheep 12.98 @ 108 MPH 7) GTOboss 13.007 @ 108.52mph 8) KYGTO 13.035 @ 108.96 MPH 9) Judgethis05 13.036 @ 108.72 10) hookmechanic 13.074 @ 106.76 MPH 11) SLoW SHO 13.082 @ 108.15 12) SloNlo 13.086 @ 108.75 MPH 13) TheCamel 13.112 @ 108.49 MPH 14) BadGTO 13.14 @ 104.99 MPH 15) Lord Vador 13.132 @ 108.85 MPH http://www.ls1gto.com/forums/showthread.php?t=106613 Obviously, driver skill plays a big part as even I've seen some run in 14's with poor driving. These cars are difficult to drag race with the 6 spds.
