PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS! |
BMW 3-Series (E90 E92) Forum
Tire Pressure
Wheels and Tires forum Sponsored by The Tire Rack
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer |
04-14-2008, 11:21 PM | #1 |
241
Rep 1,906
Tire Pressure
I'm running a P215/45ZR17 tire and currently have the PSI set at 32 all around. After some mild research I have come to the understanding that higher pressure in the front and lower in the rear will reduce understeer and increase oversteer. Lower in the front and higher in the rear will induce the opposite...
So I'm thinking of running 36 in the front and 34 in the rear. It's in terms of a handling basis, I don't care about the tread wearing faster in the middle. Any insight? |
04-14-2008, 11:55 PM | #2 |
41
Rep 3,200
For a street car, unless you've got some experience, I wouldn't recommend doing anything to promote oversteer as it's more difficult to control for the average driver.
328xi Coupe, Montego Blue on Black with Alum, Step, Sport, Premium, CA, PDC, Cold Weather (Damn Pennsylvania winters)
Current Mods: Heavy right foot - Planned Mods: Lightweight right foot |
04-15-2008, 01:15 AM | #3 |
Member
306
Rep 22,825
The concept is correct. But on a front wheel drive car (most), I would recommend the same pressure all around to retain chassis balance.
If, however, you want to try altering the pressure levels, I'd suggest 32(F) and 30(R). More pressure causes greatere tire stiffness, therefore less traction. |
04-15-2008, 03:11 PM | #5 |
Rep 205
i think you got it backwards. like ray said, more pressure = less traction.
to induce oversteer, you want less traction on the rear wheels. so more pressure in the back, less in the front. to induce understeer, you want less traction in the front, so put more pressure up there and less in the back. but if you want some understeer, you can just squeeze the throttle with traction control off so you can get the wheels to break loose under the power. that's the greatness of having a RWD drive car. none of the heavy breaking through the turn crap you'd have to do with a FWD car. practice on a closed track. it's fun. do you guys get this annoying beep beep beep beep beep when you start to lose traction? |
04-15-2008, 06:16 PM | #6 |
Member
306
Rep 22,825
04-15-2008, 07:48 PM | #7 |
143
Rep 6,333
that is just DSC at work
2017 BMW M4 DCT Lease Transfer: https://f80.bimmerpost.com/forums/sh...8#post23736398
04-15-2008, 07:55 PM | #8 | |
86
Rep 1,153
Ray that's a badass sig you got there!! |
