10-25-2019, 01:39 PM | #1 |
559
Rep 1,340
Presenting the AWE S-FLO Carbon Intake Suite for the F9X M5/M8. Available now.
High spooler. Presenting the AWE S-FLO Carbon Intake Suite for the BMW F9X M5/M8, available now:
S-FLO Carbon Intake: Dual filters with a 56% increase in surface area over stock, threaded seamlessly through the factory bracing with a sophisticated touch of 2x2 carbon fiber. Thanks to this increase in surface area, the M5’s S63 takes kindly to the respiratory refinement, translating 7 hp and 7 ft-lbs of torque to the wheels on factory software with plenty of room for upgraded software that demand higher-than-stock boost levels. The S-FLO Carbon Intake is the perfect option for those seeking more volume from their intake when under boost. Want to hear more turbo induction sound from within the cabin? Good, we hoped you would. Equip S-FLO and full spool ahead. S-FLO Carbon Covers: The S-FLO Carbon Covers share the same 2x2 carbon fiber construction as the S-FLO Intakes, even down to the weave direction. Featuring a raised ceiling right above the S-FLO Filters and perfect integration to the factory air ducting, the S-FLO Carbon Covers allow a significant amount of ram air to surround the intake while keeping it stealthy in the sound department. Mounting securely to the factory mounting points, the S-FLO Carbon Covers rid the plastic in exchange for an aesthetic fit for the F9X. S-FLO Carbon Grille Inlets: Trumping the factory inlets in every way, the S-FLO Carbon Grille Inlets utilize empty space behind the kidney grille for capturing charged air from the front of the vehicle. Facing forward instead of up (e.g. stock) allows the S-FLO Carbon Grille Inlets to funnel the charged air directly into the ducting behind the headlight and into the intake seamlessly. Adding form to function, the S-FLO Carbon Grille Inlets introduce a unique grade of aggression to the M5’s front end. The S-FLO Carbon Grille Inlets are the perfect compliment to the S-FLO Carbon Intake, and also work with the factory intake configuration. Upgrade options: The S-FLO Carbon Intake can be purchased with or without the S-FLO Covers and Carbon Grille Inlets. If you want to add either at a later date, no problem. What’s in the box? Complete S-FLO Carbon Intake, S-FLO Carbon Covers and/or S-FLO Carbon Grille Inlets (if chosen), two S-FLO Filters, and all necessary hardware for installation. Please note: we include rub strips to prevent damage from the factory bracing. Please see our installation instructions for proper application. Data: |
10-25-2019, 08:56 PM | #2 |
///M Fan
1657
Rep 1,490
Exciting I am sure once I get mine I will be interested in some basic bolt on mods and an intake will be on the list. Looks well thought out.
Noushy
2019 BMW X5 50i Mineral White/Tartufo all options including M Sport
2022 Porsche 911 C4S Silver/Brown 2023 BMW iX M60 Black Sapphire/Amido, Titanium Bronze trim/22 2023 Audi RS6 Avant Daytona Gray/Black 2024 BMW X5M Comp Brooklyn Gray/Taruma Brown, Titanium Exhaust on order |
GHollan92122.50 |
10-26-2019, 01:20 PM | #3 |
Joint Chiefs of Staff
24161
Rep 190,725
Check out our current sale by clicking on this link!
https://x-ph.com/sale/ Phone number 702-494-9435 |
12-17-2019, 05:00 PM | #4 |
559
Rep 1,340
Receive 15% off all AWE BMW products, available through participating dealers and at AWE-Tuning.com.
01-29-2020, 03:23 PM | #5 |
559
Rep 1,340
03-04-2020, 11:39 AM | #6 |
Vendor
186
Rep 193
We have a cure for your F90 spring fever, our Carbon S-FLO Intakes.In Stock Now!
Local to AWE? We can install these for you at our World HQ while you wait. Click for details and to schedule. Last edited by Sara/AWE; 03-04-2020 at 11:48 AM.. |
