BMW M8 Forum and 8 Series Forum BMW M8 and 8-Series General Discussion BMW M850i Instrumented Test Performance Figures (by Car and Driver)
      03-30-2019, 09:16 PM   #45
F80R
60
250
Drives: Tanzanite Blue F80 M3
Originally Posted by AndroidRobot
Originally Posted by spatterson007 View Post
Originally Posted by upsidedownfunnel View Post
Even faster if that 7.6 sec 0-100mph is for real. That's crazy
Tested by the same publication, the M5 is significantly faster.
The regular M5 got a 0-100mph of 6.6s by C&D. When you compare these times, you really can't compare across publications. They all test these differently and C&D tend to get the absolute fastest times of anybody. C&D got a 0-60 of 2.8s for the base M5.
Here's the difference, M5 listed first, M850 listed second both tests done by C&D:
Test: M5, M850i
0-60: 2.8, 3.3
0-100: 6.6, 7.6
0-150: 15.9, 18.5
5-60: 3.7, 4.3
30-50: 2.2, 2.3
50-70: 2.4, 2.7
1/4: 10.9@129, 11.5@123
Top Speed: 163, 159
70-0: 147ft, 161ft
skidpad: 0.98g, 098g
Ah my bad. You are right. I'm my mind I was thinking of quarter mile times. HA. I was like no fucking way. xD
M5 is a monster. Nothing comes close unless it's the next gen M5
E63s does
      04-27-2019, 02:10 PM   #46
cstraley
14
14
Drives: BMW 850i Convertible
Negative Nanny
Originally Posted by padaarnaulat View Post
impressive at first glance. then you sit inside and then the new 3er and you'll realize how overpriced it is for the same fit and finish. it's just car to show you like to waste money.
rather not fit...3er has more room.
Negative Nanny I detect some jealousy here. I just purchased a new M850i convertible and it is much nicer than a 3er as you put it. And the 3er does not have a twin turbo V8 last time I checked. There isn't much competition in the convertible high horsepower "similar cost" category that I would consider "over it" at present. The technology in the M850i is second to none.
      04-29-2019, 08:34 PM   #47
cstraley
14
14
Great Performance
The car feels every bit as fast as the numbers!
Originally Posted by Stage IV View Post
Full review @ https://www.caranddriver.com/reviews...y-the-numbers/
2019 BMW M850i xDrive Coupe
VEHICLE TYPE
front-engine, all-wheel-drive, 4-passenger, 2-door coupe
PRICE AS TESTED
$118,945 (base price: $112,895)
ENGINE TYPE
twin-turbocharged and intercooled DOHC 32-valve V-8, aluminum block and heads, direct fuel injection
Displacement
268 cu in, 4395 cc
Power
523 hp @ 6000 rpm
Torque
553 lb-ft @ 1800 rpm
TRANSMISSION
8-speed automatic with manual shifting mode
CHASSIS
Suspension (F/R): struts/multilink
Tires: Bridgestone Potenza S007, F: 245/35R-20 95Y ★ R: 275/30R-20 97Y ★
DIMENSIONS
Wheelbase: 111.1 in
Length: 191.2 in
Width: 74.9 in
Height: 53.0 in
Passenger volume: 81 cu ft
Trunk volume: 15 cu ft
Curb weight: 4400 lb
C/D TEST RESULTS
Zero to 60 mph: 3.3 sec
Zero to 100 mph: 7.6 sec
Zero to 150 mph: 18.5 sec
Rolling start, 5–60 mph: 4.3 sec
Top gear, 30–50 mph: 2.3 sec
Top gear, 50–70 mph: 2.7 sec
Standing ¼-mile: 11.5 sec @ 123 mph
Top speed (governor limited): 159 mph
Braking, 70–0 mph: 161 ft
Roadholding, 300-ft-dia skidpad: 0.98 g
C/D FUEL ECONOMY
Observed: 20 mpg
EPA FUEL ECONOMY
Combined/city/highway: 20/18/25 mpg
