08-24-2023, 09:46 AM | #243 |
2885
Rep 2,614
Drives: 2024 M4 Convertible
There's nothing better about Shell gas than any other Top Tier-certified brand, objectively. Top Tier *means* that they're using the right detergents and additives that validate the certification.
There's plenty of options out there that don't involve giving your money to the stations that are overcharging you because of brand name only. I encourage you to at least take a look in your immediate 5-minute driving vicinity, I bet you have a Top Tier-certified brand that's significantly cheaper than Shell or Chevron. |
08-24-2023, 09:50 AM | #244 | |
10662
Rep 6,938
Drives: 2018 M2 AW DCT
BMWCCA member Puget Sound Chapter
08-24-2023, 09:59 AM | #245 | |
2885
Rep 2,614
https://www.toptiergas.com/gasoline-brands/ |
08-24-2023, 11:10 AM | #246 | |
10662
Rep 6,938
08-24-2023, 11:59 AM | #247 |
1020
Rep 910
08-24-2023, 12:03 PM | #248 | |
1020
Rep 910
I was using QT, and it was good, but now have the shell app and get .5-.35 off. I plan around those locations as they don't recognise Circle K. I wish I could find actual DATA!! |
08-24-2023, 12:07 PM | #249 | |
3575
Rep 10,352
"Drive more, worry less. "
08-24-2023, 12:10 PM | #250 |
5876
Rep 2,987
Drives: A Family Sedan
08-24-2023, 12:11 PM | #251 | |
3575
Rep 10,352
Now some engines have PFI w/DI inwhich you'd be correct. However, injectors tips need to remain carbon free. Carbon can build up on shut down because fuel at the hot injector tips just bakes.
08-24-2023, 12:14 PM | #252 |
2885
Rep 2,614
I don't see how you get .35c off without doing their weird "pay to get more off" promotional things. QT is consistently more than .35c off for premium than every other big brand around me anyway.
FrankMstein1019.50 |
08-24-2023, 12:15 PM | #253 | |
2885
Rep 2,614
It's literally how the top tier gas certification works. The additives prevent things like he described from happening. |
08-24-2023, 12:18 PM | #254 |
3575
Rep 10,352
Costco is 10 min away. I save almost $9/tank compared to Shell V-Power 93.
08-24-2023, 12:22 PM | #255 | |
3575
Rep 10,352
PFI allows fuel to wash over the valves which is why they stay clean.
08-24-2023, 12:27 PM | #256 |
1834
Rep 1,326
https://www.vehicleservicepros.com/c...in-gdi-engines
Despite the IDEA that fuel not making it into the crankcase, so it can't help with carbon buildup on GDI engines, both Honda and Volkswagen say BS. Audi outright says the garbage fuel standards we have in the U.S. are directly responsible for all the trouble we have with carbon deposits. Adequate detergent packages from Top Tier gasoline in the U.S. helps SOME with deposits by going through the crankcase and being volatile in the PCV system. Having done multiple oil analyses on my cars in the past, there is a significant amount of gasoline in many oil crankcases - dependant on car and engine. And if it's crap, of poor quality, it contributes to an oil vapor that can be more problematic, no matter how good your oil is. Cause if you put skanky convenience store gas in your tank into your $100,000 car with $20 per quart oil in it, you get skanky gas into your oil vapor floating around your crankcase. Shawn |
M2siast5876.00 |
08-24-2023, 12:30 PM | #257 |
2885
Rep 2,614
There's no wash on the valves, but the valves are still involved in the injected fuel/air mixture, which makes the valves harder to have deposits removed because of the fact there's no fuel wash. That's why Top Tier gas is more important. You don't get the deposits in the first place so there's no need to be concerned about deposits.
08-24-2023, 12:32 PM | #258 | |
1834
Rep 1,326
Do an oil analysis of your own oil and tell me it's 0% gasoline contamination. Gasoline contamination contributes to oil vapor in the crankcase, directly affecting valve stem deposits. Shawn |
FrankMstein1019.50 M2siast5876.00 |
08-24-2023, 12:38 PM | #259 |
2896
Rep 3,726
I run Stabil Marine in all my cars from E10 to full E85.
It has nice dose of PEA fuel system cleaners along with corrosion inhibitors. This helps slow fuel oxidation as well as clean injectors.
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race |
08-24-2023, 12:38 PM | #260 | |
1020
Rep 910
08-24-2023, 12:39 PM | #261 |
1020
Rep 910
08-24-2023, 12:41 PM | #262 |
1834
Rep 1,326
08-24-2023, 12:41 PM | #263 |
2896
Rep 3,726
Every tank of gas based on their recommendations.
Stabil Marine only takes 1 oz to treat 10 gallons, so it's somewhat cost effective since you only need to use 1.5oz to treat a full tank.
08-24-2023, 12:51 PM | #264 | |
3575
Rep 10,352
