04-23-2024, 05:01 PM | #1 |
Rep 21
Clean Interior Mesh
What are you guys using to clean the interior mesh like material (like the outside of the glovebox for example)?
04-23-2024, 05:23 PM | #2 |
863
Rep 376
Drives: BMW iX60-2024
Garage List 2016 BMW X5m (retired) [0.00]
2016 BMW M4 (retired) [0.00] 2022 BMW iX 50 (ret ... [0.00] 2024 BMW iX m60 [0.00] |
Damp cloth, without much friction.
04-23-2024, 08:04 PM | #5 | |
863
Rep 376
Although you, Deutsch, appear to be responsible for about 12% of all American EV sales, so you can take a risk or two |
04-24-2024, 11:08 AM | #7 |
2351
Rep 1,468
deutsch1004039.00 |
04-25-2024, 03:49 PM | #8 |
3200
Rep 1,832
Drives: BMW iX Xdrive40 MSport
I run over those surfaces with the leather cleaning wipes I use on the dashboard leather. It works a treat.
Current: iX Xdrive40 | MSport | 22" Bicolour | Amido Interior | Mineral White Metallic |
05-02-2024, 09:28 AM | #10 |
5628
Rep 4,536
Drives: 2022 iX xDrive50, DGM
Very dilute Simple Green or Woolite as deutsch100 noted, on a damp, non-linting MF. Light circular pressure and don't overthink it. It's upholstery.
05-02-2024, 10:37 AM | #11 |
2351
Rep 1,468
My opinion is that you shouldn't use anything with surfactants, i.e., detergents, sprays, etc. All of those will leave a residue on the item that will attract more and more dirt over time. If you wipe it with a surfactant-based fluid, that surfactant will stay on the fabric as it dries.
If distilled water is not working, try adding a little bit of rubbing alcohol to the mix. Rubbing alcohol is a solvent and will break up dirt while evaporating cleanly and without leaving behind any residue. |
05-02-2024, 11:03 AM | #12 |
5628
Rep 4,536
Alcohol is indeed a solvent - a powerful organic polar solvent - and will remove plasticizers, cellulose, oils, binders, coloring, and anything else that is co-soluble in whatever witch's brew that this fabric is made from, the composition of which BMW has not divulged, but presumably an organic polymer.
Water is also a solvent, but much milder and not nearly as unpredictability destructive to organic materials. Surfactants are just surface tension-reducing organic hydrocarbons that improve water's ability to separate nonintegral materials from each other - as in debris from fabric. For which they have been used for several hundred years for a reason. The key is dilution - soap (a surfactant) rinses off your hands and other materials, like fabric, with its diluent, water. I would certainly trust this combination on an unknown substance like the "recycled" whatever is in this mesh before I would try something that might irreversibly alter its composition, texture or color. |
drbluedevil863.00 LVBMW1541.50 |
05-02-2024, 12:21 PM | #13 | |
1542
Rep 769
Drives: '24 iX M60 '23 Tesla Model Y-P
Paladin15628.00 drbluedevil863.00 |
05-02-2024, 01:07 PM | #14 |
5628
Rep 4,536
Sometimes I dream in formulas and reactions....
"They've promised that dreams can come true - but forgot to mention that nightmares are dreams, too." O. Wilde |
LVBMW1541.50 |
