03-22-2024, 01:24 PM | #23 |
625
Rep 1,196
Here was a response from ChargePoint:
"Hello! We wanted to clear up any confusion about the amperage change for Home Flex in the ChargePoint app. As of November 2023, the Home Flex charge current limit feature is here to stay. While we initially removed the feature to comply with changes to the National Electrical Code, we heard your feedback and worked hard to redesign it, and bring it back. Now you can once again control the charging rate of your EV in the ChargePoint mobile app. Users can safely adjust their current settings within 80% of the breaker amperage or their charger’s maximum-rated output. This allows users to manage their power consumption and cut costs by turning up their charging power when solar energy is available or turning it down when other appliances are in use. The power is back in your hands. If you need help, send up a DM or feel free to reach out to our 24/7 Driver Support team, we are happy to help!" |
03-22-2024, 01:49 PM | #24 | |
1385
Rep 944
Drives: ix xDrive50
2024 iX xDrive50 Phytonic Blue on Mocha with DAPP, Premium, B&W, Ventilated & Radiant Heated Seats, Adaptive Headlights, and Luxury
03-22-2024, 02:01 PM | #25 |
5628
Rep 4,536
Drives: 2022 iX xDrive50, DGM
Just checked my app (v6.3.0, Android) and this is what I get:
Nothing mysterious or nefarious here, and it's based on my original installation and setup - max 40A (plug-in), down to 8A if I want (some users actually choose to derate to 32A on a 50A circuit for an extra margin of safety - see SOC video). And you could always adjust it from the MyBMW app. Much ado. |
justinguo31745.00 |
03-22-2024, 02:44 PM | #26 |
48
Rep 136
To all the questions - I’ve had the original CP reset to factory and reconfigured. It’s a hardwired setup on a 60amp circuit limited down to 48a. I have already swapped out the unit for another one they sent me and same issue. The only catch is the car charged at a slow level 2 on a 9.5k charger but went at 7kw. I came drop the CP lower than 16A. I’ve adjusted the car max to take to the lowest available and no dice on the CP.
As far as their support it’s a bit frustrating at the escalation level. Took a week and a half before getting a replacement but no one could at any point give me any status updates. Not how I’d expect th to handle something that people rely on so heavily. I have not reset the car and am wondering if factory defaulting the whole Idrive would do anything? |
03-22-2024, 02:46 PM | #27 | |
48
Rep 136
03-22-2024, 05:29 PM | #28 | |
625
Rep 1,196
I’ll search and see if I can find it, although this obviously isn’t what’s causing the issue for the OP here since he states he’s not getting any current to his iX. |
03-23-2024, 01:45 PM | #29 |
53
Rep 32
Have you checked “location based settings” in your iX to see whether an amperage limitation was somehow set based on your home location? APPS: charging: location based settings
03-23-2024, 05:53 PM | #30 |
48
Rep 136
No settings are active. As noted I’ve got the bmw trickle charger which works no issue. I’m having someone check the charge tomorrow on an Audi so we’ll see from there. I suspect the car having issues at higher charge rate OR something in the wiring preventing CP from outputting but that wouldn’t make sense.
03-24-2024, 12:14 PM | #32 |
5628
Rep 4,536
Some steps you might not have taken, that won't hurt and might help:
1) Remove your profile and re-add it. Be sure it's synced to your BMW account and your key first. 2) Uninstall and reinstall the MyBMW app. 3) Do a diagnostic reboot on the car (in the car, doors closed, car off, foot off the brake, press the Start button rapidly 3 times. A confirmation should appear in the instrument cluster indicating Diagnostic Mode. Press and hold the Volume scroll button until the main screen goes off, allow the system to completely reboot, exit and lock the car). Wait an hour. Try charging again. Last edited by Paladin1; 03-24-2024 at 12:23 PM.. |
justinguo31745.00 |
03-24-2024, 04:40 PM | #33 | |
48
Rep 136
03-24-2024, 05:26 PM | #34 |
5628
Rep 4,536
That's actually progress - something may be wrong with your initial setup. You didn't specify lease or purchase, but you need to contact your dealership to be sure the car is in fact registered to you and that they're seeing the same thing on their end. Worst case you may need to do a factory reset on the car, but that will require resetting everything. Start with a dealer call, and you may also want to contact the BMW i Hotline - (855) 236-1025.
03-24-2024, 09:11 PM | #35 | |
48
Rep 136
03-26-2024, 04:13 PM | #36 |
48
Rep 136
Update: car is working as expected at the dealer, they are continuing to look into it. Suspicion - either ChargePoint did something to be incompatible with BMW or something happened in the BMW to make it incompatible with charger. Next step if they come up fruitless is to get another iX or electrified model as loaner and test it out. Highly suspecting something between the account and the software is not jiving but this is super odd and not making me feel comfortable being stuck out in middle of nowhere with a trickle charger…
Update1: MyBMW app login issue resolved with changing password, super ODD but it worked. Last edited by ok31; 03-27-2024 at 09:44 AM.. Reason: updating information |
03-27-2024, 11:49 AM | #37 |
625
Rep 1,196
Is your dealership using an actual L2 A/C EVSE OR a low rated DCFC which I think is quite common.
Meaning if they are charging your car with say a 50kWhr DCFC, then they aren’t able to potentially recreate your specific issue. |
03-27-2024, 07:53 PM | #38 | |
48
Rep 136
Came home plugged into my 60A circuit (48A to car) and 0kW followed by error unable to charge. My CP was able to charge a Jeep Willy 4xe this weekend, although that was at a lower kw since that other battery doesn't take a higher charge. This would suggest that my iX does not have a problem and works, it also suggests there is no conflict between BMW and ChargePoint. This leaves me perplexed because if I can charge another car but not mine, can it really be something with the breaker at my house? The only thing that wasn't done yet is an electrician didn't check out the setup but its a 6gauge 3 wire from the panel to the charger at a distance of probably less than 15' of cable. Done to code and passed inspection (those are a joke but point is it was all code correct). bad breaker that when it needs to output more shuts the CP because it isn't getting the right amount and shuts down to prevent a fault? |
03-28-2024, 09:38 AM | #39 | |
625
Rep 1,196
If the breaker was tripped at 48A continuous, you’d have to reset it manually, no? 2: Make sure that the iX doesn’t have something set under ‘location settings’, IF that’s even a thing in our cars, that’s been somehow set to not to charge at your home. 3: Make sure in the app that AC Charging limit is set to ‘Unlimited’. You’ve proved this isn’t an issue with your CP, although it would be great if an EV pulling more power than the Jeep could be used for a second ‘opinion’. Good luck! |
03-28-2024, 10:09 AM | #41 |
48
Rep 136
03-28-2024, 10:14 AM | #42 | |
48
Rep 136
I don’t have any location settings in the car and if I did then my bmw stock charger wouldn’t be working either. The limit is unlimited. I need to ask dealer what faults they saw and figure out if the car isn’t taking or the charger isn’t giving. When I plug in, it knows the amperage and adjusts accordingly it’s just that it doesn’t take and errors out but where is the question and why. Clearly there is something with either my account, charger (again) or wiring because yes with some degree of certainty my car is fine. At the same time with some level of certainty the charger is also fine UNLESS it’s my charger account so plan X is to create a whole new account and see what happens maybe even pretend it’s a different car. That’s the only difference between my friend and mine. They have the phev x5 configured but why that matters I can’t comprehend. To be continued…. |
03-28-2024, 10:38 AM | #43 | |
1385
Rep 944
Drives: ix xDrive50
I have been following this and trying to think of ways to brainstorm. Lots of information evolved, so I thought I would summarize all of your findings and observations to date:
03-28-2024, 01:34 PM | #44 | |
48
Rep 136
The ONLY thing at this point I’m considering is creating a whole new chargepoint app account. I don’t know why that would be a thing but why not. Another potential is to get a temp EV loaner and try at the house to rule out vehicle or house. If another BMW stops working then MAYBE CP in a software update did something and like you said switched soft place of inputs, wouldn’t explain why my would and friends wouldn’t but… |
exxxviii1384.50 |
