10-24-2022, 05:08 PM | #23 | |
814
Rep 810
Even if the rotors need replacement on that 6 - 7 year old car (or likely older), you can just swap for steels anyway. Just get new pads and you are good. At least on an AMG but assume this is the same BMW... |
10-24-2022, 09:54 PM | #24 | |
2175
Rep 757
10-01-2023, 02:29 PM | #25 | |
28
Rep 11
The 8-series comes with a variety of brakes. Given that there is at least one member on here who has demonstrated a complete lack of knowledge in this area, let me give you the various brake disk options. Rear axle: 345mm 370mm (Aerodynamics Package, M-Sport, and with M-Sport brakes) 398mm (M Performance & Sport Package M) Front axle: 348mm 374mm (Aerodynamics Package and M-Sport brakes) 395mm (M-Sport & M Performance) If you buy an 8-series with the standard brake system you will get the 348mm discs in the front and 345mm in the back. Even if you buy an 8-series with the M-sport package, it could have the 374mm discs in the front and not the 395mm. Just by looking at the photo you have posted, I can tell that's not the 395mm discs. One more thing thing, if you ever hear someone claim "the brakes on the 840 are weak and they fade", ask him to clarify what he means. "How long is a piece of string..." |
10-01-2023, 08:30 PM | #26 | |
87
Rep 181
Drives: 2013 BMW ///M6 F13
Let me chime in if I may. Some information below is incorrect. CCB replacements are around 4k per rotor not counting pads. CCB's will only last to 100k of daily driven and not tracked. If the car was tracked, you will significantly lose longevity. The M drivers package means the car has no MPH limiter, it doesn't mean the car was tracked. I think it comes down to hiw long you plan on owning it. A few years, buy it. Keeping it forever? Idk 16k worth it?? I had a m6 with CCB's, they were really good but doesn't justify the replacement cost imo |
10-02-2023, 01:55 AM | #27 |
161
Rep 200
Usually when the car come with carbon ceramic brakes , the top speed limiter is removed too . Also you qualify for a BMW track day to learn about the car. However , your car us not used but a bmw OWN M car ..like for like is there .
So the car you see with 15k miles was unlikely used at bmw's training ground . Don't worry. Get a qualified professional to check that the carbon ceramic brakes are not damaged buy stones or anything. Expensive to replace 2k each corner . That's the down side of thease brakes . |
