09-26-2023, 07:27 PM | #23 | |
Not a good Canadian sheep!
1283
Rep 1,116
Were you happy in the end with it. I can see you won't be stopped on something. |
09-26-2023, 11:12 PM | #24 |
"Salud"
13946
Rep 4,688
Drives: F01 & F15 / Mineral White
You would be much better off going aftermarket and come out much cheaper and utilize your current speaker covers with better speakers and amps.
09-27-2023, 04:38 AM | #25 | |
50
Rep 63
But I don't want aftermarket |
09-27-2023, 11:07 AM | #26 |
"Salud"
13946
Rep 4,688
09-27-2023, 12:03 PM | #27 | |
268
Rep 848
I don't mean to offend anyone here but honestly I don't understand the buzz behind B&W. I had B&W in my 7 series for four years and when I compare to the HK in the M850, I don't notice the great effect between the two to pay the extra $5k. I agree with the member's comment about B&O being a better system than B&W.
As I mentioned in previous post, the only thing I miss with the B&W is lights in the speakers! It created a really nice look at night when driving. The M850 look dark without the B&W speakers... Quote:
09-27-2023, 12:05 PM | #28 | |
"Salud"
13946
Rep 4,688
10-11-2023, 10:11 PM | #29 | |
Rep 5
Hi there! May I know how much was your total cost to retrofit the B&W system and what are the exact part numbers you've ordered? I'm quite keen on doing this retrofit on my 8 series too.
10-12-2023, 03:08 PM | #30 | |
50
Rep 63
I don't have an exact list of the part numbers, but you can gather them here: https://www.realoem.com/bmw/enUS/select Often I did not search specific part numbers, but just searched parts for the model, because often parts have multiple part numbers over time. For example the speakers, speaker covers, booster are exchangeable for all the models 8 series F91, F92, F93, G14, G15, G16. You only have to check for the rear side. It depends if you have coupe or grand coupe.. there are differences. Last edited by jeezz; 10-12-2023 at 05:21 PM.. |
10-13-2023, 11:32 AM | #31 |
162
Rep 92
I realise I’m joining this discussion a bit late in the day but if it’s of interest - I looked at the same thing and went aftermarket.
The crucial change is amplification and better DSP but you have to leave the existing system in place so that you can extract the feeds at the right point and leave the iDrive components of the system intact - otherwise you end up with all sorts of stuff that won’t work any more (parking sensors, warnings, voice control, the list is a long one)! I changed door drivers and added 2 x 12” subs behind the back seats. DSP took lots of the headachy mid bass out of the underwear subs and re-EQed the system for a much better result. Made a much better job of limiting the system so it couldn’t be blown up, corrected delays and gain structure between drivers to give better imaging and then sent it all to better amplification. It’s one of the best things I’ve ever heard. Total costs came to about Ł4500 and you need to know what you’re doing with audio (but on a personal level that’s my trade so not a problem). Happy to give advice if anyone’s interested. (Or even a listen - although I’m in the Uk). |
10-13-2023, 09:37 PM | #32 | |
4307
Rep 4,371
Westy162.00 |
10-14-2023, 01:47 AM | #33 | |
162
Rep 92
I forgot to mention that you absolutely definitely need to code out the active sound design, easily done (I did mine with BimmerCode) but if you don’t do it you’ll regret it for life - the droning and the noise of amplifying it is just horrendous 😆 |
10-14-2023, 03:24 AM | #34 |
910
Rep 1,156
Is coding out ASD just available on the basic version of BimmerCode or have you got to go into the advanced settings to do it? Also heard it can be done on BimmerLink? I’ve got both, I just can’t find my OBD adapter!
10-14-2023, 10:28 AM | #35 | |
162
Rep 92
SUCH an idiotic idea putting fake sounds through the hifi, whoever thought of it needs a slap, whoever agreed with them also needs a slap and whoever signed it off in development quite frankly ought to be sacked and never allowed near a car again!! |
10-14-2023, 09:51 PM | #36 | |
4307
Rep 4,371
Westy162.00 |
12-04-2023, 06:22 PM | #37 |
64
Rep 151
jeezz,
I have a question for you. I have a set of full leather door panels that have the HK setup. I have the BW setup already in my car. How difficult will it be to switch out the door panels and swap BW to the HK door panels? Thanks! |
12-05-2023, 06:27 PM | #38 | |
50
Rep 63
After that you have to carefully drill all the plastic welded mounting points of the speaker covers. For the front tweeter one it's a bit worse, you will need a dremel for that and grind the weld of, since it's not round mounting, it's like multiple welded "lines". To access one or two mounting points you also have to cut off a little plastic peace to reach it. After all done you can swap the covers and use BMW "repair screws" to make them hold back in place. For the tweeter cover you will have to weld it back with some plastic or just use like hot glue gun. So it's a bit of work. Last edited by jeezz; 12-06-2023 at 08:18 AM.. |
12-06-2023, 10:53 PM | #42 | |
4307
Rep 4,371
That said I've head several B&O components in my home audio over the past 2 decades. One being their 9000 CD changer (back when CDs were a thing) because it was a pure piece of art from a design standpoint. From a more sound perspective that included several versions of their Redline speaker series. Put them into comparison of B&W 801s, Kef Reference, Martin Logan, etc. in my audio system over 15+ years and B&O fell flat on their face and didn't even last 6 months. I'll stand by the B&W system in an 8-series as it is flat out amazing and built off the 801/Nautilus speakers. Tell me it has no bass and I just laugh. More importantly I can push it to nose bleeding volumes and it is pure unadulterated sound clear of any distortion, etc. As I always state even if not an audiophile the aesthetics of the B&W system is worth the price of entry especially if leasing. |
M8Bimmer1283.00 |
