02-26-2021, 09:27 AM | #1 |
4419
Rep 4,109
Has anyone else experienced this issue? It was intermittent so I booked the car in next week but it may have finally had enough this morning.
It sounds like it's going to start, you hear the little click but then silence. Obviously, I try again and again until it pops a starter motor failure error (the code thrown is 216119). Any workaround in the meantime would be a gem but I'm not optimistic. Bummer. |
02-26-2021, 10:19 AM | #2 | |
18961
Rep 10,095
Does it even turn over or just clicks?
2023 BMW M8 Coupe Competition Alpine White
2022 BMW M3 Competition XDrive Aventurine Red 2022 Porsche Carrera GTS Coupe Shark Blue 2020 Audi R8 V10 Performance Suzuka Gray 2012 Mercedes Benz C63 AMG Black Series Obsidian Black |
02-26-2021, 10:37 AM | #3 | ||
4419
Rep 4,109
I got it started again after I posted, went out to run some errands and intended to leave it running & locked. Of course, autopilot kicked in and I turned it off. So I may be here longer than intended. : |
02-26-2021, 10:39 AM | #4 |
18961
Rep 10,095
Shit--- no turn over sometimes means alternator issues as a weak battery would/should still yield a weak crank.
Resjudicata1597.50 bloozemanAZ4197.00 |
02-26-2021, 10:44 AM | #5 | |
4419
Rep 4,109
02-27-2021, 05:23 AM | #6 | ||
1598
Rep 2,935
the internet says: Fault Code DescriptionThe diagnosis monitors the voltage supply for the starter motor. Fault monitoring conditions: The fault is entered when at least one of the following faults is detected: - Wires or plug connections faulty - Voltage supply defective - Starter contacts are iced up Service Plan The starter relay may freeze at ambient temperatures below 0°C. Perform following checks: 1. Carry out functional check. 2. Check wires and plug connections 2. Check voltage supply and ground connection. 3. Check lines and plug connections between the following components: DME, integrated supply module, FEM/CAS/BDC and vehicle battery. 4. Check vehicle battery. 5. Check starter motor relay and integrated supply module. Service Plan 1. Check line and plug connections 2. Check voltage supply and ground connection 3. Check wires and plug connections between following components: DME, integrated supply module, FEM/CAS/BDC and vehicle battery. 4. Check vehicle battery. 5. Check starter motor relay and integrated supply module. Service Plan The starter relay may freeze at ambient temperatures below 0°C. Perform following checks: 1. Carry out functional check. 2. Check wires and plug connections 2. Check voltage supply and ground connection. 3. Check lines and plug connections between the following components: DME, integrated supply module, FEM/CAS/BDC and vehicle battery. 4. Check vehicle battery. 5. Check starter motor relay and integrated supply module. |
limeypride4418.50 FBMWWINS603.50 |
02-28-2021, 08:27 AM | #7 | |||
4419
Rep 4,109
Resjudicata1597.50 |
02-28-2021, 11:38 AM | #8 |
2940
Rep 1,763
So sorry to hear that! Hopefully it all gets resolved soon.
limeypride4418.50 |
02-28-2021, 12:20 PM | #9 |
4419
Rep 4,109
What's worse—which is what the pictures were supposed to show—is they reversed the tow truck into my rear end and scratched the $hit out of the CF diffuser as well as scraping the rear passenger side sill. When it rains, it p..... pisses me off! |
02-28-2021, 01:22 PM | #10 | |
2940
Rep 1,763
limeypride4418.50 |
02-28-2021, 02:07 PM | #11 | |
812
Rep 810
Looks like a deeper scrape on the CF and the lower panel needs a respray by a really good shop in order to match (unless it's just on PPF). I am sure they think they can just buff those out Just looking of how tight these straps were tensioned... At least the starter will be a quick repair. Good luck! |
limeypride4418.50 jjasonSU194.00 |
02-28-2021, 03:14 PM | #12 | |
378
Rep 378
You start with a minor problem and you end up with this |
limeypride4418.50 |
02-28-2021, 04:47 PM | #13 | |
4197
Rep 4,292
Have my fingers crossed that the BMW dealer makes it all right! |
limeypride4418.50 |
03-04-2021, 07:33 PM | #15 |
4419
Rep 4,109
03-04-2021, 07:43 PM | #16 |
272
Rep 526
Glad to hear it! I am sure it will work out, be well!
03-04-2021, 07:44 PM | #17 | |
1598
Rep 2,935
Either way tell ask them for their registered agent and address for service of paperwork for your attorney's lawsuit. You're not threatening them, just asking for a name and address. But I assure you, they will get the message and send a check. |
xmanpro2939.50 |
03-04-2021, 07:57 PM | #18 | |
2940
Rep 1,763
03-04-2021, 08:39 PM | #19 | ||
4419
Rep 4,109
The new CF pieces are less than I thought: ~$1,200 installed. |
03-04-2021, 09:50 PM | #20 | |||
2940
Rep 1,763
Hopefully you get the $$$ for the cf diffuser soon.
03-05-2021, 02:26 AM | #21 | |
604
Rep 909
As elementary as it sounds, make sure you do chase the tow service for the damage they did as this is a clear case (in your favor)! |
03-05-2021, 06:17 AM | #22 |
966
Rep 1,782
Just out of curiosity for those with similar symptoms in the future, so was the short caused by two connecting wires at the starter? As indicated the starter did not need replacing. I do not know how these starters are connected, but I would think all connections are via some type of harness connector. So maybe a short in a connector?
