01-17-2022, 12:52 AM | #1 |
62
Rep 148
Carbon fiber interior trim
I am looking at a pre-owned M8. The interior trim is ash black silver wood. I prefer the carbon fiber. If I'm not mistaken, the only two areas that have the trim is the opening panel to the front compartment where the phone charging pad is located and the trim piece around the shifter. I would assume BMW sells the two pieces. If so, has anyone switched out those two areas? Any way of looking up the part numbers and cost?
01-17-2022, 11:24 AM | #4 |
Member BMW CCA Los Angeles
32
Rep 470
Drives: 2022 M8 GC Comp
Looks like M8Bimmer got you your answer. Normally I use realoem for this stuff, but doesn't look like it's been updated with the latest.
What other sources do people use to look up part numbers?
Current Rides:
2022 ///M8 GC Comp Much enjoyed: 2018 ///M4 ZCP || 2014 ///M5 ZCP || 2011.5 ///M3 Sedan || 2007 ///M Coupe || 2008 550i Sport || 2006 ///M3 ZCP || 2008 X3 3.0si || 2006 325i || 2003 Z4 3.0 Roadster || 2003 330ci || 2002 325i |
01-17-2022, 11:35 AM | #5 |
4539
Rep 3,507
I call parts dept, they typically have it quickly and a price with the part number.
01-17-2022, 01:39 PM | #6 |
1909
Rep 2,007
Drives: 2022 i4 M50
FWIW, a couple here have had theirs replaced by a shop and DIY. Here's a thread from Resjudicata with some pricing for having it done, and links to threads where other took the DIY route:
https://f92.bimmerpost.com/forums/sh....php?t=1817075
Current: 2022 i4 M50 | 2022 G07 X7
Gone: 2020 F92 M8 | 2020 G07 X7 | 2018 F80 M3 | 2017 F15 X5 | 2016 F16 X6 | 2015 F36 4 series GC |
