11-03-2023, 02:26 PM | #1 |
Rep 32
Bmw e87 obd Kline problem
Hi I have e87 with Kline obd light on I tested all and voltage are correct , it's was working until I remove headunit because I want to change wires to new one and I can't install it again until I install new wires , when I try to scan using ista nothing detected all ECU not respond , if headunit not installed Kline will not work ??
Thanks |
11-05-2023, 12:59 PM | #3 |
512
Rep 570
More details would probably help. "Kline"? Exhaust, maybe Hard to imagine anything head unit or OBD with Kline suspension – the most common Kline around here.
11-07-2023, 02:56 AM | #6 |
198
Rep 417
Okay, so I'll try to decipher this here as there is clearly a language barrier to overcome.
By kline, I assume you mean K-line or K-CAN bus/diagnostics protocol. It's been ages since I did any meaningful work on E series, but isn't E87 D-CAN? DME might have the K-Line pin, but it's not connected to anything as far as I remember. K+DCAN cables should work, but K-Line dedicated most likely wont. Not sure what are you referring to as head unit, but older BMW's had their gateways integrated to KOMBI (gauge cluster). If that is out, then bus users on other networks can't communicate, nor can you see them with diagnostic tools. Last edited by Raimo5; 11-07-2023 at 03:06 AM.. |
11-07-2023, 01:27 PM | #7 |
Rep 32
I mean head unit by DVD player , I use k+d can cable it's was work when music player was installed , but now not , I was remove music player because wiring was not good I order new wiring but not installed yet , So I just want to know if music player can stop obd communication with all ecu
11-08-2023, 04:05 AM | #8 | |
198
Rep 417
11-08-2023, 12:16 PM | #9 |
466
Rep 2,781
K-line was used until 2007/03 manufactured e90 e91 and e87
then it was removed and switch to D-CAN on different pins so you need to clarify when you car is manufactured
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
