11-18-2020, 12:36 PM | #1 |
1292
Rep 1,658
Question for those with CTEK/BMW 8 Step Chargers
I've been using the BMW version of CTEK's 8 step Lithium charger and have noticed something that I'm not sure is normal and would like to get some feedback.
CTEK says after 10 days the charger is supposed to enter step 8/pulse mode which is for longer term charging, yet on my M850 is goes into pulse mode after only 2-3 days and stays there for about a week or so, then for some reason goes back to step 6 for about a day then works its way back to pulse mode again. I reached out to CTEK and they said I might have defective charger so I reached out to BMW parts and they sent a replacement and it does the same thing. Called CTEK tech line and they said it should not be doing this and the car must have a draw. Car was at BMW just a few weeks back for the one year service, and the "vehicle will turn off soon message" that would pop up when driving and turn off after being driven a short distance as some others have reported. My dealer indicated that it was a SW issue and required an update but I declined due to the exhaust-gate issue. Battery testing was all good. So, for those with these chargers are you seeing the same thing where after being hooked up and the car not driven opened etc where it gets up to pulse and after a week or so it drops down to step 6 then goes back up again? FYI, I went with the BMW version as it has a dual mode of charging either lithium or conventional batteries vs the non-BMW version which does one or the other. Here's CTEK's latest response once I made certain they knew it was a BMW version: The BMW branded charger is different from all CTEK branded chargers and am not familiar with or even trained on that product. As you probably know, CTEK is the manufacturer of several premium branded chargers, including BMW. Due to contractual agreements, all queries regarding client branded chargers and accessories, including manuals and other details, are to be directed to the vehicle manufacturer. I’m hoping that a service tech with BMW will be able to assist you or that the product manual has some helpful information. Unfortunately my service dept doesn't know much about the nuances of these. Thx
Mineral White/Black, HP Cooling/Tire/M-Technology Pkg/Extended Shadow/Etc., Anthracite Headliner, Carbon Roof, DAx2, Display Key, Various Accs'. Topic permitting, I try to be objective as possible Last edited by RJC-1; 11-18-2020 at 01:46 PM.. |
11-18-2020, 01:41 PM | #2 | |
1607
Rep 2,937
11-18-2020, 01:45 PM | #3 | |
1292
Rep 1,658
Just trying to see if anyone using these chargers is experiencing what I am. When car was at dealership battery, short test etc all came back good except the need to update SW for the will turn off soon msg.
Resjudicata1607.00 |
11-18-2020, 01:47 PM | #4 | ||
1607
Rep 2,937
11-18-2020, 01:52 PM | #5 |
1292
Rep 1,658
Which one are you using?
11-18-2020, 03:14 PM | #6 | |
1607
Rep 2,937
Battery Tender Plus Charger and Maintainer: Automatic 12V Powersports Battery Charger and Maintainer for Motorcycle, ATVs, and More - 12 Volt, 1.25 Amp Battery Chargers - 022-0185G-DL-WH https://www.amazon.com/dp/B00DJ5KEEA...UTF8&psc=1 |
RJC-11291.50 |
11-18-2020, 04:42 PM | #7 | |
1292
Rep 1,658
https://www.shopbmwusa.com/PRODUCT/4...ATTERY-CHARGER https://www.shopbmwusa.com/product/1...LLIGATOR-CLIPS
11-18-2020, 06:00 PM | #8 | ||
1607
Rep 2,937
but I'd wager the bigger BMW one should be better for you. we have the Amazon one because we have 5 cars and it works with all of them, so far! |
RJC-11291.50 |
11-18-2020, 06:26 PM | #9 | |
1292
Rep 1,658
11-18-2020, 07:00 PM | #10 | ||
1607
Rep 2,937
RJC-11291.50 |
11-18-2020, 08:18 PM | #11 |
1292
Rep 1,658
Wolfman64 has the ctek 8 step version, most likely he'll chime in.
06-23-2023, 11:13 PM | #12 |
4303
Rep 4,366
Bumping this up to the top as looking to get a charger for the M850i just to rule out low lithium battery levels for OTAs. Planning on going with the CTEK OEM'd BMW battery aka 4961 (https://www.shopbmwusa.com/PRODUCT/4...TERY-CHARGER). $163 and a fractional rounding error of chump change given the time and investment with the M850i.
Are there other recommendations? There has been several threads on 1 battery vs 2, etc. Best trickle chargers for the single lithium in a M8, but I'm pretty confident my 2020 M850i has two batteries, i.e., AGM and Lithium. Any recommendations beyond the BMW charger? |
06-24-2023, 08:35 AM | #14 | |
156
Rep 116
https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1 |
06-24-2023, 10:34 AM | #15 | |
4571
Rep 3,537
2022 M8 Comp Convertible
07-19-2023, 04:07 PM | #16 | |
4303
Rep 4,366
07-19-2023, 04:12 PM | #17 | |
4303
Rep 4,366
Or may just keep both as the NOCO definitely maintains the AGM battery even though it's considered auxiliary according to the M850i TIS documentation. |
10-12-2023, 11:23 AM | #18 |
2043
Rep 1,849
Hi guys,
I'm coming from the F90 M5 board. I'm facing an issue with my BMW Lithium battery charger. After reaching step 2, it starts blinking and the charging cycle doesn't start. The charger worked for 2 years, I encountered the same problem as now which was resolved by taking the car for a drive. Now the charger doesn't want to know anything, even after driving the car. has anyone encountered this problem before? Here's a video of the charger not working : |
10-12-2023, 11:55 AM | #19 |
156
Rep 116
I have the CTEK MXS 5.0 charger which I believe is essentially the same as the rebranded BMW CTEK model you have. The instructions (attached) for my charger state on page 12 that stage 2 is a soft test, and if the battery is defective, charging will not occur. Sorry, as I'm sure that's not a response you were hoping to receive.
CTEK_MXS-5.0-Manual-v2.pdf |
10-12-2023, 12:18 PM | #20 | |
2043
Rep 1,849
In fact, I read in the user manual that if the charger blocks in step 2, this means that the battery cannot be recharged because it is too old. What's amazing is that the car starts without a problem and no low battery lights appear. No message on the iDrive either... I only use the car for long trips, and the rest of the time it is parked in my garage plugged into the charger (when it was still working). So I think that the battery can be recharged, but that a safety device prevents recharging. |
10-19-2023, 08:41 PM | #21 |
Not a good Canadian sheep!
1280
Rep 1,116
How can this charger charge 2 batteries at once? In the M8 we have 2 batteries I thought. If you connect under the hood where they show you too, won't it be charging both at once? And they are not the same type are they?
I assume under the hood is where this one connects. What's the story with this guys? Isn't this the same as the BMW charger. Does it charge both at once. https://www.amazon.ca/gp/product/B00...AN9A0OWP&psc=1 |
10-20-2023, 07:16 AM | #22 | |
156
Rep 116
https://f92.bimmerpost.com/forums/sh...senger%20side. I haven't done much research on this yet, but I would make an initial guess that if the mentioned switch did trip and the Lithium battery does not charge, it's no big deal because lithium batteries maintain their charge far better than lead (AMG), and I'm not sure which battery maintains the constant draw electronics anyway. It could well be the lead one. I use this to maintain the battery of my 2022 M850 vert for 4 months each summer in my climate controlled Florida garage while summering in Maine. I have not had any issues upon return, but that's not confirmation that I may indeed be slowly causing battery damage. However my instincts doubt it. Also, I have received no messages from iD7 indicating any battery/charging issues. https://cdn.shopify.com/s/files/1/01...f?v=1597088684 Also, this charger from BMW has a note that says it works for both lead and lithium batteries, thus issue resolved: https://www.shopbmwusa.com/PRODUCT/4...ATTERY-CHARGER Last edited by yugrac; 10-20-2023 at 07:29 AM.. |
