08-08-2020, 10:48 AM | #1 |
17882
Rep 9,376
a
08-08-2020, 12:32 PM | #4 |
3069
Rep 5,577
are both pieces the same smoothness ? I'd probably choose A also for furniture quality.
But B would make a really good looking box or something. Are both pieces cut to size and sanded or are you going to add finish ? |
08-08-2020, 01:25 PM | #6 |
17882
Rep 9,376
It's already cut for the table and each side has a single coat of varnish at this point. These are BBQ tables that used to have particle board as a top
Here's the one I finished last week
overcoil3068.50 Lucky John616.00 |
08-08-2020, 04:26 PM | #8 |
1354
Rep 1,031
I like the knot in the wood
08-08-2020, 04:33 PM | #10 |
17882
Rep 9,376
Outdoors
This plywood is A/C
08-08-2020, 04:47 PM | #11 |
1472
Rep 826
I see. Well, personally, I would go with "C" if it was varnished/stained something a bit darker. Looks too plain the wait is now imo. Needs some spice if you will.
08-08-2020, 07:34 PM | #12 |
Recovering Perfectionist
14906
Rep 938
Drives: 2015 BMW i3 BEV
Personally, I'd lay out today's newspaper on either side, and hit it with several coats of "clear" polyurethane. Every single time that I have ever tried to finish wood, it always ends up with newspaper embedded in the finish. I said that if I were ever doing wood finishing again that I would intentionally seal the newspaper onto the finished surface to save myself some time.....
08-09-2020, 06:03 AM | #14 |
1209
Rep 2,476
A/C, alone, doesn't mean it is suitable for outdoor use. That is just the surface ply "quality" designation, i.e. one side is A grade, while the other is C grade...like what you show in your photos where one side has all of the knots(C) and the other doesn't(A).
For it to be suitable for outdoor use, there need to be additional designations, which vary by manufacturer and will say things like "exterior", "exposure x", "x"...you pretty much have to look up the manufacturer's spec sheet to determine what it is. To take that further, most plywoods that have an exposure rating can only withstand that exposure a limited amount of time before they begin to fail and delaminate. Last edited by Emilime75; 08-09-2020 at 12:51 PM.. |
08-09-2020, 12:23 PM | #15 |
3805
Rep 2,860
I vote side A. They make a marine polyurethane that is VERY durable, but if it isn't true exterior grade it will only be a matter of time. I'd use it on the finished one, either way, since you already have the time into it. But wouldn't sink more time into cutting/sanding more if it isn't exterior grade (looks like it would make nice shelving or other inside uses).
08-09-2020, 02:09 PM | #16 |
17882
Rep 9,376
Outside folding table when I take it out of storage. For the day at most. Won't be leaving it out in the elements
08-09-2020, 03:57 PM | #17 |
3069
Rep 5,577
08-10-2020, 12:40 PM | #19 |
17882
Rep 9,376
08-10-2020, 05:09 PM | #20 |
2070
Rep 4,365
08-11-2020, 04:54 PM | #22 |
2070
Rep 4,365
I would knot go with the nots. The smooth side looks better and if you want character you can do that with a finish or an insert if you want to put a tad more work in.
