04-01-2020, 10:47 PM | #1 |
442
Rep 468
Brick rot?
04-01-2020, 10:58 PM | #2 | |
3552
Rep 1,062
Drives: F15 xDrive50i M-sport
2017 F15 xDrive50i M Sport | Superformance GT40 Roush 511 IR FE
04-02-2020, 06:21 PM | #3 | |
442
Rep 468
I think the damage may be coming through from the exterior side... the backyard grass/dirt comes right up against the bottom of the wall and it's an irrigated yard so I'm sure there's a ton of moisture hitting the exterior wall. I may have to look at digging it out and making sure there's no direct earth to wall contact. Appreciate it! |
pennsiveguy3552.00 |
04-03-2020, 09:10 AM | #5 |
1619
Rep 880
Drives: 2011 E90 M3, 2019 F150
I have this same issue with my basement foundation wall which is concrete block. I assume at some point in the past 98 years the basement has seen water and caused this issue. I have taken out the lose material and filled with hydraulic cement. I will then cover these spots and the whole wall with waterproofer paint before framing down there.
04-04-2020, 09:20 AM | #6 |
3848
Rep 2,873
If you are going to waterproof, I was always told it had to be the outside of the wall (the real expensive way, I know). The waterproof paint just traps moisture in the bricks, and if there is much of it, then it will just burst thru spots in the paint. My aunt did her basement very thoroughly and it held for 2 yrs, then developed leaks that would actually squirt jets of water during rainstorms, then the wall sloughed sheets of paint stuck to corroded brickwork, like how rust eats under bondo. If you have much wetness use exterior drywall (or paint the back side) and put in a perimeter drain system. And the value of good exterior drainage cannot be overstated.
04-05-2020, 11:14 PM | #7 | |
3552
Rep 1,062
The wetness on the outside is only during the warm months, right? It's not helping, and I would definitely try to keep water off the bricks to prevent mold & mildew staining, but I doubt that it's the real cause of the spalling on the inside. Salt is destructive to masonry, and so are freeze-thaw cycles. I was just over at my mom's yesterday, swapping her summer tires onto her car. I'm weighing options for restoring the concrete floor in her garage. You can see the outline of where all the cars have been parked; the concrete is horribly pitted in those rectangles, and in great shape everywhere else. I'll be skim-coating it with acrylic concrete patch and then epoxy coating it this summer.
04-05-2020, 11:46 PM | #8 | |
3552
Rep 1,062
