10-13-2023, 06:05 PM | #1 |
94
Rep 134
Check your Bowers & Wilkins
Hello guys!
So I think I have ecently find another widespread issue that affects G30 and F90 equipped with B&W sound system. For those who have it, you will probably agree that its definitely not the best high end stereo (especially compared to B&O) and it can get even worse if you mid speakers will stop playing. And you better check yours, if your car is 2020 and older Circled is the MID frequency speaker. So what happens? Water gets inside the door panel and drips on the open important part of the speaker, such its magnet and wiring. Traces of water and dirt inside the door panel when the speaker is removed. Speaker magnet and wiring is affected by all of this. You can see actual water inside the speaker that was just removed from the car. Overtime, it will damage it and your speaker will stop playing. Car won't get you any codes and it's actually hard to notice sometimes because the speaker will star loosing it sound gradually. The best way to test is to change output to specific side through equalizer. If the speaker is good, you will HEAR IT playing. If in doubt you can compare to rear doors. It mainly happens with the front doors on both sides, however I had a car that required rear ones to be changed as well. Speaker are not cheap at around $200 each and requires door trim removal to be changed and you also need to change all of the door panel clips ones you pulled it. So after some testing I did create special cover that protect pins, magnet and wiring of the speaker. It sits nicely inside the door panel and gives the speaker extra protection from water that drips on it. And it doesn't affect the sound. It sits nicely with the speaker installed and looks OEM. I plan do a repair kit, that will include speaker, door clips, speaker cover at very reasonable price. In the meantime, you can check if your MID speakers are actually working BTW, for whatever reason, it doesn't seem to happen with the cars that are equipped with Harmon & Kardon speakers. |
10-14-2023, 06:34 AM | #2 |
7504
Rep 6,870
Drives: '18 M550i|'21 X5|'03 540i
Garage List 2013 VW Tiguan [0.00]
2015 Infiniti QX60 [0.00] 2021 BMW X5 [0.00] 2003 BMW 540i [10.00] 2018 BMW M550 [10.00] |
No issues here on my 2018 and I pretty much power wash it weekly. Honestly, this is the first I’ve heard of this issue, I definitely haven’t seen it as widespread.
Have you done work to your car previously in terms of removing the door cards? Maybe related, may be not, when the dealer was prepping my car for delivery, the work order performed listed adding insulation to the doors, totally forgot they did this, but for some reason this thread made me think of it. I just dismissed as a TSB of some sort. Is it the absolute best system, no. But I find it very solid. It’s also the highest fidelity offered in the G30, so pretty much the only option if you want the best system. Can’t really comment on B&O in the G30, because it’s not offered . Every system sounds different in every car. HK sucks in the G30, but sounds good in my X5. Nice work though and glad you created a workaround to save yourself a few bucks.
2018 M550ix|Carbon Black|Dinan Modifications|2003 540i|Jet Black|M-Sport|2021 X5 Mineral White
Prior BMW's: 1987 325e|1993 740i|1998 740il|2001 530i|2002 745li|2007 750li|2006 750li|2001 530i|2012 535xi| |
10-14-2023, 10:12 AM | #3 |
338
Rep 471
My front driver side mid stopped working some years ago. Replaced under CPO. Could definitely hear the front stage being pulled to the right when it was non functional. From the time I made the appointment to the time it was replaced it did occasionally work until it finally died for good.
I would think each door would have a moisture barrier of sorts to keep water out. Dealer didn't mention any signs of water damage, just that the speaker was indeed shorted. The B&W is a decent system in the G30. An additional 2 8" subs or finding a way to put 10" subs under the seat could've really helped the low end extension. I've been driving an XM with the B&W for about a month now and even though it's got the same number and type of sub, it does have a bit better low end extension- probably a larger enclosure with a lower tuning freq given the difference in space constraints. Still not perfect but a notch above the G30. |
hookson93.50 |
10-14-2023, 02:24 PM | #4 | |
94
Rep 134
10-15-2023, 03:32 PM | #5 |
3054
Rep 1,566
Having just recently pulled my door panels off to install new speakers, look at the area where I circled. There is a little foam insert that can fall out and water will definitely drip in there and leak right onto the speaker. Check to see if yours is still there.
Edit: right after I posted this, I checked your pictures to see if yours was still there and it was. Make sure it isnt cracked |
Joe-BMW337503.50 |
10-15-2023, 03:35 PM | #6 | |
94
Rep 134
10-16-2023, 05:45 AM | #7 | |
7504
Rep 6,870
I have to think if I was having this issue, it would have shown its ugly head in 5 years. I also listen very careful for distortion.
10-16-2023, 08:27 AM | #8 | |
3054
Rep 1,566
Joe-BMW337503.50 |
10-17-2023, 05:05 PM | #9 |
Unapologetic Tool Hoarder
736
Rep 966
Had both fronts replaced on our 2020 CPO right after we brought it home. Sad part is the dealer (not the one that we purchased from out of state) acted like they were doing us a favor by replacing them.
10-17-2023, 05:06 PM | #10 |
94
Rep 134
10-17-2023, 05:16 PM | #11 |
736
Rep 966
It seemed WAY too quiet to be B&W system and more rear biased. I verified all of the settings. I'm fairly sure it worked when I picked it up because I drove 500 miles home with it and I was definitely listening loud. I ended up updating the iDrive version with ISTA since it was still on 2021 software and it threw some errors about front speakers being disconnected. I then ran the test procedures and confirmed they were indeed not playing any sound. That's when I took it to the dealer.
04-06-2024, 06:39 PM | #12 | |
989
Rep 1,807
04-07-2024, 01:26 AM | #13 |
290
Rep 391
Why would this sort of water damage be limited to just B&W front door speakers. Are the HK and regular HiFi speakers not in the exact same location with similar risk of water damage?
2020 540i MSport | Alpine White | Mocha Nappa | Aluminum Rhombicle | Exec Pkg | Luxury Seating | Bowers & Wilkins | Parking Assistance Pkg | MSport Brakes | Ceramic Controls | Space Saver Spare |
04-07-2024, 06:42 AM | #14 |
7504
Rep 6,870
No disrespect to the OP, but I don’t think this is a “widespread “ issue. This is honestly the first and last example I’ve come across. I wouldn’t sweat it.
04-07-2024, 11:50 AM | #15 |
1932
Rep 609
I hope it’s not an issue w my 23 m550. I am thrilled with the BW stereo, it’s not perfect on the low end but clarity is amazing even when satellite radio is the source. I had an rs7 with a BO, the high end was better but I prefer the bw overall. The stereo in my wife’s Range Rover is also amazing the bass is truly remarkable. I have machine head on music dvd and the sound is incredible. I wish the m550 had a dvd player.
04-07-2024, 12:35 PM | #16 | |
94
Rep 134
https://f90.bimmerpost.com/forums/sh....php?t=2054428 |
04-07-2024, 04:12 PM | #17 | |
7504
Rep 6,870
If someone feels like checking this out for me, I would be interested in knowing if you have the same results. No need to fuck with the EQ, just stick your ear on it.
04-07-2024, 04:16 PM | #18 |
504
Rep 589
Somewhat related, I am always amazed by how these "high-end" stock systems look when you tear everything down.
I have a set of vintage B&W DM2s at home, and have experience with some of the newer stuff, and I just don't get why they can't seem to build a car system that exudes the same quality in materials and construction. These systems are hilariously overprice in terms of general sound quality, the interior as a sound stage, and the effort they seem to put into materials selection, etc... |
04-07-2024, 04:35 PM | #19 |
7504
Rep 6,870
Just to add, B&W set to Studio and everything centered. When on SiriusXM, if I fade 💯 to the rears, I’ll get something from the doors and rear deck, but not strong. Rears mids and deck don’t work on XM either when centered.
Probably a software update that I will pass on. Too much coding doke to lose. Let me know what you find fellow B&W guys with XM.
04-08-2024, 02:20 AM | #20 |
81
Rep 179
That's what I was testing recently when I was traveling as rear passenger in my car. When you fade speakers fully to the rear, only rear shelf speakers are working. You need to set it one notch short of fully rear in order to have speakers in the rear door working.
With that being said, I am noticing that the sound(when centered) is front biased which is noticed when you are sitting at the rear. Is there any way for me to check if all speakers are working properly other than placing my head in each speaker? |
04-08-2024, 05:26 AM | #21 | |
7504
Rep 6,870
It's just SiriusXM that I discovered that the rear doors and shelf are silent when centers and actually do not have any volume unless I put the fader 100% to the rear. Even the notch right before 100% produces nothing on the SiriusXM input. I did a little googling, I don't think I am the only one, but will be curious to see what you guys get. I am not overly OCD about this as I don't use SiriusXM much, maybe because it sucked in my car and now I know why, but I will just use the SiriusXM app via Apple Carplay to stream it. Hell, I will probably cancel it for this car as I have it on two other cars which come with digital streaming. It will save me $150 a year.
04-08-2024, 09:33 AM | #22 | |
3054
Rep 1,566
My experience is that studio sucks. I can’t hear anything from the rear speakers…so I never use studio. concert or on stage Sounds outrageously good. All speakers are activated. |
HerkHealer1759.00 |
