01-27-2018, 06:33 AM | #1 |
594
Rep 478
Transmission lumpy?
Does anyone else notice their transmission sometimes not have a super smooth change at low speeds or when you're creeping along in stuck and go traffic? My vehicle is a 2018 BMW 540i rear wheel drive.
2023 BMW G05 X5 xDrive40i
2023 BMW G30 540i |
01-27-2018, 08:15 AM | #3 |
22
Rep 77
In my F10 I've noticed perhaps a dozen times in over 2 years what feels like you occasionally catch the gear change software out. I couldn't even describe the exact circumstances, it's always at low speed, most likely the change from 1st to second but could be second to third, and I think it's when I'm building speed then ease off the throttle then back on and perhaps the gearbox goes to change up then changes back down again.
It's very similar to a poor or rough gear change in a manual car. It's never happened often enough for me to really think about it, but I do think - in my case - it's where my actions fall outside the gearbox programming! Never noticed it at anything other than crawling speeds. |
NGT25788.50 |
01-27-2018, 12:14 PM | #4 | ||
594
Rep 478
2023 BMW G30 540i |
01-28-2018, 03:04 AM | #5 | |
190
Rep 303
02-26-2021, 05:41 AM | #7 |
6663
Rep 15,858
When it starts happening, has anyone simply flicked the shifter to M/S and then back to D, to break any driver/situation adaptation? If not try it, it may be due to the current driving situation and resulting inputs. Get it back to a 'fresh' start.
02-26-2021, 02:53 PM | #8 |
Seeking mental floss
482
Rep 806
I have never experienced this in over 39K miles now. However, I frequently flick the lever to the left to M/S mode in traffic, where I think the transmission staying in gear makes the car much more easily driven. I use it for performance frequently also. I think this allows the ZF8 to mimic Drivelogic 2, which I always used on the DCT in my former M4. Maybe this explanation is the reason I have not had the described problems?
06-09-2021, 03:32 PM | #11 |
110
Rep 936
I have the same exact issue. When driving slow as in a parking lot, 1st to 2nd shifting is jumpy and that happens quite often. I wonder if clearing the transmission adaptations will fix this, however I think BMW warns against clearing the adaptations unless it is part of certain repair procedures.
06-23-2021, 09:37 PM | #12 |
Fixer of Cars
50
Rep 21
Just picked up a used 540i and noticed this issue, its mainly in traffic for me, its like the engine isnt dropping speed automatically between shifts. I'm going to try resetting the adaptations in the transmission and see if this gets rid of the issue.
06-23-2021, 09:38 PM | #13 | |
Fixer of Cars
50
Rep 21
Nothing wrong with resetting adaptations its just required with some repairs. |
10-29-2022, 09:15 AM | #15 | |
Rep 11
Drives: 520D G30 M-Sport 2019
The threads upon threads and forums upon forums with hundreds of posts.. someone must have come up with an a resolution by now. |
10-29-2022, 09:30 AM | #16 |
3984
Rep 2,661
Drives: 2019 BMW 540
I have this same issue when I first start the car in the morning. I let the car idle until the RPM doesn't settle down (usually takes a few seconds). Then I take off but I don't gun the car right off the bat.
There's a stop sign not too far from my house so I lightly accelerate the car. When I slow down, the car kind of gets all lumpy and stuff. At first I thought it was the turbos. My factory warranty expires in March of 2023. I'm taking the car in Feb for an inspection. I'll have them take a look at that stuff.
Current: 2019 BMW 540 (AWD)
Sold: 2009 BMW 328 (AWD) |
10-30-2022, 09:35 PM | #18 |
29
Rep 36
vanos solenoids
2018 540 with exactly above symptoms, resetting adaptation, changing transmission fluid did nothing.
replacing vanos solenoids - resolved! |
Mosaud19983983.50 aidant7991.50 |
11-01-2022, 09:02 AM | #19 |
Rep 11
Never even heard of that until you mentioned it. My 520D doesn't have the symptoms being described by research Iv done on Vanos Solenoid symptoms. But gives me something else to look into
11-01-2022, 09:30 AM | #20 |
680
Rep 649
I always drive with my car in Sport mode and I have to say that occasionally shifts feel a bit abrupt or clunky at low speeds, but I have always ascribed that to the sport mode. Not enough of a problem for me to worry about. --Bob
2019 540xi M Sport, Carbon Black/Cognac, 2014 328xi, 2016 Corvette Z06; Previous:2010 BMW 535xi M Sp, 2008 335xi, 1998 M3 Sedan,1980 528i, 1977 320i, 1976 2002
11-02-2022, 10:04 AM | #21 |
5789
Rep 4,733
Drives: BMW M550i xDrive (2020)
I set up my Sport Individual mode to use comfort settings for transmission for this reason.
2020 M550i xDrive (Champagne Quartz/Black)
2021 X7 40i M-Sport (Arctic Gray/Tartufo) RETIRED: 2018 540i Luxury Line (Dark Graphite/Canberra Beige) |
11-14-2022, 05:26 AM | #22 | |
36
Rep 94
Could you please inform me photos of or code of the parts. Cant understand clearly because of turkish english diffrence.. |
