07-02-2010, 10:53 AM | #1 |
/r/trees
50
Rep 875
zoom lens or a nice quality 50mm??
Hi,
I've just started getting back into photography and Iam shopping for a camera. I've narrowed my selection down to the canon t2i for the body. Now for the lens, Iam not sure. I am debating between the kit lens 17-55mm or to spend a bit more money on a quality 50mm like the f1.4 usm lens. Its considerably more money but Iam wondering if Iam going to be regretting not have the zoom range. I've seen shots with the kit lens, and they dont look so good. Main use of the this camera will be for travel so it will be used under a wide range of conditions. What would you do? I've also been considering non Canon lens but I really dont know the brands or have any clue on them. I'd be open to suggestions on these as well. |
07-02-2010, 11:25 AM | #2 |
145
Rep 2,809
i think the best bet since it's gonna be an all around lens would be to get a 18-200mm (tamron or sigma, will be cheaper than Canon)...i'm not a pro, but just sayin, if that will be your only lens you would want it to be versatile.
07-02-2010, 11:34 AM | #3 |
1162
Rep 1,548
What do you tend to shoot?
Personally, I'd get a zoom over a prime if you're only going to have a single lens for a while. Is there a trade off? Yes, but the flexibility not being fixed to a single focal range trumps it IMO. FWIW, the 18-55mm IS lens is not all that bad for your average person (IMHO anyways). Are there better lenses out there? Hell yes. I took one of my favorite pix of my car using the 18-55 IS lens, though. It was, though, when I had just gotten my dSLR and before I invested in much better glass.
- Jeff
bosstones' flickr |
07-02-2010, 11:48 AM | #4 |
/r/trees
50
Rep 875
Hi, thanks very much for the replies.
I started photography on a manual slr, with a 50mm. That is the experience Iam basing my decisions on. Iam hoping you guys can steer me in the right direction. So if i did go with a zoom lens, what are good alternatives to the canon 17-55?? I dont mind spending a bit more. I guess I am looking for a good "walkaround" lens. |
07-02-2010, 01:31 PM | #5 | |
49
Rep 280
http://www.fredmiranda.com/reviews/s...&cat=43&page=1 You mentioned you started with a manual and a 50. Well because of the crop factor on the T2i, I would suggest a 30mm lense instead. It will get you the same focal length of a 50mm on a full frame camera. The Sigma is suppose to be outstanding. I wish I had a 1.6x sensor body to get that lense. I have to deal with a full frame 5Dmk2 http://www.fredmiranda.com/reviews/s...&cat=38&page=1 |
07-02-2010, 02:10 PM | #6 |
40
Rep 2,334
zoom...
07-02-2010, 04:39 PM | #7 |
Retired e90post Member
135
Rep 3,038
07-03-2010, 01:22 PM | #8 |
/r/trees
50
Rep 875
Thanks again for the replies.
Iam just gonna get the 18-55mm IS kit lens. It appears to be decent value for the money. I didnt know anything about the "crop factor". I guess I have alot more reading to do. |
07-03-2010, 05:20 PM | #9 |
145
Rep 2,809
Spend a little more money and get a faster lens (f2.8). Crop factor basically means that it's not full frame ala 35mm. When you were using film with a 50mm, you were getting an actual focal length of 50mm. With a non full frame dslr(t2i) you have a crop factor of 1.6. So if you put a 50mm on a T2i it's actual focal length is 80mm
07-03-2010, 07:05 PM | #11 |
Apex Everything!
979
Rep 4,378
Drives: 2007 Honda S2000, 2017 GT350
Once you want to start upping the image quality, you're going to lust after the primes. Personally, if you are getting back into photography and starting with one lens, I'd recommend going prime, but that's just me. You get way more bang for the buck in terms of image quality. Sure, you can't zoom, but that's what your feet are for. Zoom makes sense in the ultrawide and telephoto ends (because primes just get expensive and the zoom ranges are more significant), but you can't go wrong with a 35mm/1.4 or 50mm/1.4. I just picked up a canon 35mm/1.4 L today and it blows away my 16-35/2.8. Primes > Zoom except in cost and convenience.
2011 E92 M3(Sold). 2007 Honda S2000 (Track Car). 2016 Cayman GT4 (Sold). 2017 Shelby GT350 (AKA Crowd Killer).
My pet project: https://stickershift.com |
07-03-2010, 08:30 PM | #12 |
1162
Rep 1,548
True dat about primes. They're just not for everyone, though. The convenience of zoom is too much an advantage to some. Primes do make you work a bit for your shot. I think that helps with composition and creativity, though.
- Jeff
bosstones' flickr |
07-04-2010, 08:46 AM | #13 |
Rep 132
A 50mm isn't as versatile as the kit lens as you've surmised by now, but one thing to note is that if you utilize the aperture priority setting of your camera, you can still make a lot of great use out of the 50mm. You'd really have to see images of the exact same object from the same point of reference using the zoom set at 50mm and the 50mm prime and do some pixel peeping to see if you notice a difference. Chances are, the kit lens at 50mm compared against the prime at 50mm will result in a noticeable but not exaggerated difference.
I'd suggest the zoom as well if it's going to be your only lens in your suite of lenses. I just did a side by side experiment with two pro level lenses, a prime and a zoom and by far the zoom is a superior lens value since it has a lot more flexibility. I'm now selling my prime because of this comparison. |
07-04-2010, 11:14 AM | #14 |
1162
Rep 1,548
car_girl is all up in the forums today!
If I get a chance, I'll try to do a quick compare between: 1. 18-55mm IS kit lens 2. nifty fifty (50mm f1.8) 3. 10-22mm 4. 16-35mm I'll use the same camera settings and distance to subject for each compare. I'll even use my tripod (for once). lol I'll also throw in something from an 85mm prime but, obviously, it'd be a different focal length than the rest. I just don't have anything in that range to do a direct compare it to.
- Jeff
bosstones' flickr |
07-04-2010, 03:39 PM | #15 | |
Apex Everything!
979
Rep 4,378
http://www.the-digital-picture.com/R...mp=0&APIComp=4 (mouse over the image to show the right lens compared to the left.)
07-04-2010, 05:37 PM | #16 | |
1162
Rep 1,548
- Jeff
bosstones' flickr |
07-04-2010, 11:53 PM | #17 |
72
Rep 396
Stay with kit len. 18-55, it will do a fine job. It is like everything else. Camera bodies and lens nowadays are much better made than a few years or decade ago.
A friend of mine teach photography class and shoots T1i with kit lens often at a family event. Of course, his typically wedding gear compose of something like 5DII + 85L. Anyhow, he said T1i will give a decent everyday picture and not as intrusive for everyday usage compare to his 5DII+Grip+Flash+85F1.2. |
