BMW M8 Forum and 8 Series Forum BMW M8 and 8-Series General Discussion M8 Competition performance build has started - lofty 1200+ WHP goal
      10-13-2023, 11:24 AM   #45
bbradyc5
BMW Noob
381
202
Drives: 2020 BMW M8 Comp
Originally Posted by AHall View Post
This is quite interesting and seems to be well planned. I read this will be a daily driver, but under what conditions will you be able to use a car with 1200 horsepower? Seems like the only application would be drag racing?
Daily driver with some weekend drag strip action. AWD and like stock driving mannerisms make daily driving a non issue. I daily drove a 1000hp rear wheel drive CTS-V wagon for years without issue. Slapped some winter wheels on it and good to go. If i can’t drive it on a regular basis then it’s not the car for me.
BMWGUYinCO4125.00
      10-13-2023, 11:28 AM   #46
alapoint
42
87
Drives: 2016 BMW 550i
Originally Posted by bbradyc5 View Post
The turbo manifolds are identical mirrors of each other left to right. The runners are so short that it should be negligible for any difference in lengths
Cant wait to hear it. Gonna be amazing
      10-13-2023, 11:43 AM   #47
hufington
hufington's Avatar
3122
1,354
Drives: 2022 X5 m50i
Great planning and execution. Curious to see the results.
2022 BMW X5 m50i
2024 MB S63 on order
'18 X5 50i / '16 BMW F10 550xi / '13 BMW F10 535i / '07 BMW E64 630i / '03 BMW E65 745i / '95 BMW E34 540i / '89 BMW E30 M3
      10-13-2023, 01:29 PM   #48
BlownLSX
BlownLSX's Avatar
227
345
Drives: C6Z, X3MC
Originally Posted by Igor_M5 View Post
But stock S63 use cross bank manifolds, where as yours resembles the traditional N63 design of each turbo being designated to each bank…
It’s no different then what other platforms do when going aftermarket big frame turbos.
      10-13-2023, 03:21 PM   #49
R8TTEDR
Drives: X540i
Not with this platform. The O2s are going to go haywire if it's not like an OEM setup with crossed manifold runners.
Igor_M52147.00
      10-13-2023, 03:33 PM   #50
Igor_M5
Igor_M5's Avatar
2147
1,839
Drives: Many, BMW.
Ding ding.
Hope your tuner is as experienced as your fabricator seems to be. 🙂
Had a similar run-in with a N63tu Alpina fitted with Vargas S2 S63tu turbos a while back.
Even after making the DMEs remapped to M tables and cross bank mani’s, the o2’s were not having it.
I do wish you a ton of luck though, looking forward to seeing this followed through to the end !
      10-13-2023, 03:45 PM   #51
BlownLSX
BlownLSX's Avatar
227
345
Drives: C6Z, X3MC
Merge the downpipes with a xpipe and monitor O2 afterwards. Not complicated.
      10-13-2023, 03:55 PM   #52
R8TTEDR
Drives: X540i
Let me know how it goes, goodluck!
      10-13-2023, 07:49 PM   #53
M8C F92
41
25
Drives: 2020 BMW B8 Competition
How did you select the turbos and how much work and are you going to have to modify the hood for fit? I have the RK Stage 2 turbos and have been looking to upgrade.
Also, which upgrade are you planning from Pure? I destroyed my stock transmission at 950whp so a necessary investment.
      10-13-2023, 09:01 PM   #54
4316
4,377
Loving the thread and God speed bbradyc5 on seeing your goal to fruition. I'm conservative so all my brain is telling me is WTF happens from a warranty perspective. 🤣
      10-13-2023, 09:50 PM   #55
bbradyc5
BMW Noob
381
202
Shop worked with Garrett directly to decide what size we should go with based on HP goals and fact that it is still intended to be a daily driver. Stock hood closes and clears (just barely), if turbo housing was any larger it wouldn’t work. Pure Drivetrain Stage 2 transmission upgrade along with converter and transfer case being upgraded by them.
Tenac4575.50
      10-13-2023, 09:52 PM   #56
bbradyc5
BMW Noob
381
202
Ha! Thanks man…I’ve always been a f the warranty kind of guy. Gotta pay to play is the name of this game and just hope when shit breaks (not if) that it’s only a bad day, not a really bad day 🤣
      10-14-2023, 05:40 PM   #57
JC_AD335i
JC_AD335i's Avatar
9
Drives: 2010 BMW 335i Coupe
2007 BMW 335i  [0.00]
I'm rooting for you✊🏿 This build is going to be insane🤯🤯🤯
bbradyc5380.50
      10-17-2023, 04:15 PM   #58
bbradyc5
BMW Noob
381
202
Some more progress updates. We are making a big design shift in switching from the Air to Water Intercoolers and going to an air to air setup. This is primarily driven by the much more simpler setup running A2A. Original plans of running an ice tank in the trunk was creating some additional complexity on how not to introduce air into the system and requiring to always having to bleed it. There is a ton of room for a massive A2A intercooler up front (the intercooler brick sized will support 1400+hp). At the end of the day it’s not like many southern parts of the country here where the 90 or even 100 degree weather days are a regular thing. Yes there are pros and cons to both A2A and A2W configurations but simplicity and reliability won out here and we should still be able to pull off a very efficient setup.
Here are some additional fab pics and a few showing the start of the fuel system upgrade plans.
- 3D printed brace with enlarged opening for intake piping. Final parts being machined now
- billet coolant expansion tank
- exhaust modded with custom x-pipe
- Fuel basket hat modified to handle plumbing for new brushless fuel pump and fuel supply lines
- triple split for fuel lines (one for factory DI and two for port injection fuel rails)
Appreciate 8
Tenac4575.50
BMWGUYinCO4125.00
SFfanboy107.50
KB7120.00
fmzip1649.50
      10-17-2023, 05:11 PM   #59
Tenac
Tenac's Avatar
4576
3,538
Drives: All
Truly amazing though I do wish you kept A2W bc that is what I must do down in AZ. lol Still really great progress so soon too.
2023 718 Cayman GTS 4.0
2019 718 Cayman Base
2015 M235 Manual
On the list for the M2 CS
SFfanboy107.50
      10-17-2023, 05:24 PM   #60
bbradyc5
BMW Noob
381
202
The A2W setup with the CSF charge coolers would work just fine, wanting the ability to add an ice tank for track days is the extra level of complexity. If you want to/end up doing a similar full frame turbo setup i have a brand new set of CSF Charge Coolers that were already cut/welded on the outlets that will work perfectly…will cut you a hell of a discount on them 😎. Unfortunately for me just another cost of breaking new ground 🔥 💰
Tenac4575.50
      10-18-2023, 12:49 AM   #61
bxdinster
60
65
Drives: 2020 M5 comp 2009 135i
so curious to hear the sound of a non cross bank manifold M5 will it have its v8 rumble restored???
bbradyc5380.50
      10-18-2023, 09:32 AM   #62
AHall
983
1,804
Drives: 1993 Nissan 240sx
bbradyc5 how are you handling the sensor built into the OEM coolant expansion tank since you are changing the tank to aluminum? This tank has been an issue in the F90 due to leaks.
      10-18-2023, 11:32 AM   #63
bbradyc5
BMW Noob
381
202
Yeah the OEM expansion tank is a piece of crap that BMW refuses to fix. They are having a fitting machined, one quick connect for a hose and one for a threaded BMW style level sensor.
M3/4/829.50
      10-18-2023, 01:28 PM   #64
bbradyc5
BMW Noob
381
202
Prepping for surgery
Appreciate 9
Tenac4575.50
BMWGUYinCO4125.00
SFfanboy107.50
OM4R4.50
KB7120.00
fmzip1649.50
      10-19-2023, 10:32 AM   #65
M3/4/8
Internet Nube - Experienced M Driver
M3/4/8's Avatar
30
20
Drives: M8/M4 Comp Coupes
[QUOTE=bbradyc5;30579374]Yeah the OEM expansion tank is a piece of crap that BMW refuses to fix. They are having a fitting machined, one quick connect for a hose and one for a threaded BMW style level sensor.
I would really appreciate if you can keep us informed of how that part and sensor works. I have a M8 Coupe headed to Brunswick and the threads on this expansion tank both here and on the M5 board are really dispiriting.
      10-19-2023, 06:12 PM   #66
bbradyc5
BMW Noob
381
202
[QUOTE="M3/4/8;30582253"]
No problem, once they have fittings on there an completed I’ll share some info. If BMW doesn’t finally fix this properly then replacing with a billet tank is the way to go. We didn’t have a choice as the OE tank wouldn’t clear turbo plumbing.
