BMW M8 Forum and 8 Series Forum BMW M8 and 8-Series General Discussion M8 axle exploded
      09-26-2020, 09:32 PM   #23
noushy
///M Fan
noushy's Avatar
1657
1,490
Drives: M8 Comp, X5M Comp, iX M60
Originally Posted by debdoub View Post
Originally Posted by RJC-1 View Post
Many marques/vehicles offer larger wheels and tires as a factory option and there's no changes to beef up driveline components. He also wasn't tracking the car just driving 40-50 mph according to the OP. If I were the OP I would insist BMW to put something in writing explaining the exact reason the spring/s caused their driveline part to disintegrate at 40-50 mph of normal driving. I would then send that to HR for their take.
EDIT: I have been very vocal here nd on other forums to avoid modifications without prior blessings...
Nailed it ⬆️⬆️⬆️
I think we all have especially engine mods like flash tunes.
Noushy
2019 BMW X5 50i Mineral White/Tartufo all options including M Sport
2022 Porsche 911 C4S Silver/Brown
2023 BMW iX M60 Black Sapphire/Amido, Titanium Bronze trim/22
2023 Audi RS6 Avant Daytona Gray/Black
2024 BMW X5M Comp Brooklyn Gray/Taruma Brown, Titanium Exhaust on order
      09-26-2020, 09:35 PM   #24
RJC-1
RJC-1's Avatar
1284
1,647
Drives: 2019 BMW M850XI
BMW's new CEO has been very clear about slashing costs whenever and wherever they can...this is usually not very good for the customer, nor product loyalty.
Mineral White/Black, HP Cooling/Tire/M-Technology Pkg/Extended Shadow/Etc., Anthracite Headliner, Carbon Roof, DAx2, Display Key, Various Accs'.
Topic permitting, I try to be objective as possible
      09-26-2020, 10:46 PM   #25
noushy
///M Fan
noushy's Avatar
1657
1,490
My m8 has 14000 miles and its been bullet proof. I highly doubt a car starting at $140k is cost cutting.
Noushy
      09-26-2020, 11:08 PM   #26
brad850csi
1316
2,349
Drives: 16 F13 M6 Comp
My theory here is that because the rear tyres were quite a bit shorter than the front tyres the car thought that the rear tyres were spinning faster than what they actually were. This would mean the car would put more torque towards the front than normal which killed the (perhaps weak/faulty) front axle.
However I'd also say that I'd damned well expect the front axles to handle shock loads such as if they spin a little bit and regain grip on a dry road surface, the load there would be much higher than just driving normally with more power being sent to the front.
SCOTT26 "So as an admirer of the M5 and a potential customer of an M5 Touring. I would run naked around the streets of Garching if they were to offer one."
LSM1118.00
      09-26-2020, 11:19 PM   #27
RJC-1
RJC-1's Avatar
1284
1,647
Noushy
When BMW's new CEO came in (before covid was even a big deal) he made cost cutting across the line a top priority, and the price of the vehicle can be totally irrelevant when it comes to cost cutting. Cutting costs like not having a passenger side dimming mirrors on $140k cars!!!, no longer covering brakes, wipers, and batteries in the standard warranty, cost cutting where they might have previously looked the other way if mild mods like larger tires were done and still cover them (hence the reference in this thread), salaries, R&D, development times, sharing components from lesser models in their more expensive models, flagships etc etc etc.
And, he in fact did cut costs to the tune of $13,600,000,000.00 in 2019 and they were even planning on "drastic measures" beyond the $13.6B.
https://www.bloomberg.com/news/artic...ale-car-demand
https://www.cnbc.com/2019/03/20/bmw-...cost-cuts.html
https://www.autoblog.com/2019/11/27/...-cost-cutting/
      09-27-2020, 01:28 PM   #28
sollomon
59
114
Drives: M4,M5,M8C,X5M50I, X5M
2020 BMW X5M50I  [0.00]
2020 Bmw m8 competi ...  [0.00]
2018 BMW M4  [0.00]
2018 BMW M5  [0.00]
Noushy
after 1 year drops half price
debdoub77.50
Ibiza3599.00
      09-27-2020, 01:33 PM   #29
noushy
///M Fan
noushy's Avatar
1657
1,490
Noushy
Sadly true for most high end cars. You want resale buy a Prius or model 3. AMG GT does the same thing... Porsche is better, Audi worse
Noushy
      09-28-2020, 09:46 AM   #30
1599
2,935
Not at all same cars; but I put H&R springs on my g37x and blew out the axle almost the exact same as you're describing.
I'm not saying that it's the problem, nor am I a mechanic; however, It's possible the H&R springs.
      09-28-2020, 03:20 PM   #31
1599
2,935
Nailed it
Noushy
Engine mods can be dangerous, but flash mods or strap on chips are "safer" than mechanical lowering springs.
You are far more likely to mess up the entire power train with wheels, spacers and lower springs [exactly like this OP]; than you are to blow a turbo with ECU boost [like OP said no tune].
and while it's far less likely to happen, even a blown turbo is a drivable fixable solution for half the price, of a whole new axle and drive train. where you can't even drive it and tow costs alone double the double price.
noushy1657.00
RJC-11283.50
      09-28-2020, 11:34 PM   #32
ukr
74
109
Drives: bmw
Going with aftermarket wheels and different tire sizes is tricky on an all wheel drive car. You have to maintain OEM tire diameter ratio between front and back or your transfer case will be toast quickly.
Appreciate 4
LSM1118.00
WCH347.00
Alan l.5428.00
      09-29-2020, 11:05 AM   #33
1599
2,935
Yep, ^this^
      09-29-2020, 02:30 PM   #34
limeypride
limeypride's Avatar
4424
4,109
Drives: 2022 M8 Competition GC
Below is part of the email I sent to my buddy at BMW Bellevue before I made the change
STOCK
275/35 = 86.6
285/35 = 87.5
... front:rear circumference delta = 0.9" (rear is larger)
ME
285/35 = 87.5
295/35 = 88.3
... front:rear circumference delta = 0.8" (rear is larger)
... - 0.1" relative to stock
He said BMW won't confirm whether my -0.1" circumference delta is supported or not but he felt it was within tolerance since it's actually closer to 1:1.
@OP, here are your numbers. I don't understand the tolerances at play here--I'll leave that to the experts--but the difference is substantial enough to give me pause. I'm not sure if the reversal as to the larger circumference is significant.
OP
285/35 = 87.5
305/30 = 85.4
... front:rear circumference delta = 2.1" (front is larger)
... + 1.2" relative to stock
      09-29-2020, 02:34 PM   #35
MrElussive
18
13
Drives: MINI
Your bigger problem is if it gets fixed one way or another, will it happen again.
      09-29-2020, 03:30 PM   #36
cfm56d7b
5876
10,249
Drives: 2017 440i Gran Coupe & 2015 X5
This is a cautionary tale. BMW is taking a clear position on this matter and will not perform this repair under warranty. If pursued further, legal expenses will most certainly exceed $4500.
In the age of corporate cost cutting, all modifications will be scrutinized closely when repairs under warranty are being considered.
There is only one practical option for OP. Fix the axle. Pay BMW. Return the vehicle to stock form until warranty expires.
noushy1657.00
RJC-11283.50
      09-29-2020, 08:58 PM   #37
noushy
///M Fan
noushy's Avatar
1657
1,490
This obsession with slamming vehicles and overall wide tires makes no sense. I have never had an issue with HRE or M Performance wheels. As for changing springs not sure why as the M8 is already fairly firm for a GT.
Noushy
      09-29-2020, 09:34 PM   #38
limeypride
limeypride's Avatar
4424
4,109
Noushy
Power to traction and because it looks crap; pigeon-toed (spacer/offset issue)... and not to my taste.
/Dean
Vic5519240.00
      09-29-2020, 09:37 PM   #39
noushy
///M Fan
noushy's Avatar
1657
1,490
Noushy
Because it looks crap; pigeon-toed (spacer/offset issue)... and not to my taste.
/Dean
But is it worth the risk of suspension and or drivetrain damage?
Noushy
      09-29-2020, 09:39 PM   #40
limeypride
limeypride's Avatar
4424
4,109
Noushy
/Dean
Noushy
Subjective. To me, yes.
      09-29-2020, 09:40 PM   #41
noushy
///M Fan
noushy's Avatar
1657
1,490
Noushy
/Dean
Noushy
Limey I got you but this was more to the OP and his wrecked car. I think you are more cautious about your mods.
Noushy
      09-29-2020, 11:18 PM   #42
mjr24
1644
2,402
Drives: M8 Comp GC, X7, AMG GT53
Noushy
Agreed 110%. This isn't 1998 when the cars had 6 inches of wheel gap. No M cars made in the last 15 years look remotely high. Not only that, these people might be getting like 1% better handling versus stock (in other words, they likely don't even notice the difference) considering the stock suspension is already great. I swear people just do this to say they "modded" their car and basically burn money.....makes no sense.
Lowering springs are pretty much moot technology at this point....
Wider tires I get.....but lowering springs I just don't.
2022 M8 Comp GC, 2021 AMG GT53, 2022 X5M Competition, 2021 X7 40i, 2019 M5, 2018 M550I, 2017 Audi Q7, 2014 M6 GC, 2013 Mercedes CLS550, 2011 750LI, 2008 M6 Cabrio, 2008 Porsche Cayenne S, 2004 Mercedes SL55 AMG, 2003 Mercedes SL500, 2000 Mercedes CL500, 1993 Lexus SC400, 1989 525i, 1985 318i
      09-30-2020, 06:36 PM   #43
rb555
33
37
Drives: 2019 BMW M850I convertible
Some time ago, I had asked my SA if adding wheel spacers would be a problem. He said probably not. However, should a problem occur. BMW would most likely deny the claim because the car was altered from stock.
By altering the drive train in any way, it gives BMW an excuse to deny the claim.
Anytime you change anything in the drive train, your risking the warranty coverage on the drive train and all the related components.
2019 M850i Mineral White. Driver assistance pkg., Driver assistance pro, neck warmers
      09-30-2020, 07:12 PM   #44
Wolfman64
Wolfman64's Avatar
812
810
Limey’s explanation for the larger front tires seems the most probable cause on an AWD system as it forces a slightly different rotational speed. 2” plus makes a difference especially as software plays a role (assume the M8 AWD is variable with torque vectoring).
Lowering springs would have more impact on the suspension components (arms/bushings).
