12-11-2023, 09:19 AM | #1 |
Rep 13
Strange Fault Code after Downpipes
I DIY'd both primary and secondary downpipes on my 2022 M8 GC Comp.
Wasn't too bad just wish I had a lift to facilitate the whole process. After installation everything seemed fine, CEL light came up as expected but it wasn't for a catless downpipe. Atleast not within the first mile. I am getting -1C0204 : Oil Pressure Control Valve Actuation: Line break -180001 : Catless Downpipes Detected -21B2C7 -180104 Last 3 CEL's came up after 30 miles of driving give or take. My concern is the 1C0204 code, can't find absolutely anything. Anyone that may have access to the service tech's ISTA diagrams that may be able to provide me anything related to the oil pressure control valve? Mods on car -JB4 Map 2 -Catless downpipes -Intakes -Resonator Delete Last edited by HelloM8s; 12-11-2023 at 09:26 AM.. |
12-11-2023, 09:40 AM | #2 |
4564
Rep 3,524
First off without programing out the cat's the car will be throwing many awkward error codes. Number one rule I've encountered when installing catless before programming is DO NOT DRIVE... lol the reason isn't bad for the car but it will throw permanent codes which require the expensive diagnostic equipment to erase.
For your peace of mind I would back track on the directions and make sure to double check the plugs or anything you had to remove. You won't get an actual oil pressure error unless you had to mess around with that portion of the vehicle. Do you happen to plan to get the CEL programmed off? I think I would try that and clear all the errors before diving back in too deep if you do a once over of your install work.
2022 M8 Comp Convertible
KillerBlackRhino537.00 Vic5519554.50 |
12-11-2023, 10:31 AM | #3 | |
Rep 13
When I clear the codes using the JB4 the only one left is that oil pressure control valve. I have an autel scan tool and BM3 dongle to use with the BM3 app but that's about it. As far as tuning the emissions CEL I'm not ready to drop $3500+ in software (DME unlock + custom tuning) yet. So I may just place a decal over the light |
12-11-2023, 12:08 PM | #4 | |
4564
Rep 3,524
Don't forget though without the Cats and O2 sensors you risk damage if in possible lean situations. I would never suggest running without the sensors running to give the engine the data it needs to properly mix air/fuel properly. So programing is very important.
