03-04-2024, 12:30 PM | #1 |
39
Rep 39
Squealing Brakes...
My 2020 M8 only has 3,500 miles.
Still under warranty until July 2024. Brakes now squeals pretty loudly. Went to local BMW dealership, advisor took it for a drive only, no mechanic looked at it, & states that it's normal, that all M8's does it. Doesn't sound right. What are your experieced owners thoughts? Should I take it back to another dealership to insist a mechanic look at it again, & possible fix under warranty? Squealing noise is driving nuts... Thanks, |
03-04-2024, 12:57 PM | #2 |
19555
Rep 10,190
I hate when a tech says that; its normal.
While it can occur due to coast braking, if you do a proper burnishing of the brakes early on you can eliminate almost all that dreaded glaze causing squeals. Not sure with 3500 if you can still burnish them but why not try? I am on my 2nd M8 and no issues due to what I did with my new Coupe but also with my 2020 GC which had 1700 miles when I bought it; I burnished the fuck out the brakes.
2023 BMW M8 Coupe Competition Alpine White 2022 Porsche Carrera GTS Coupe Shark Blue 2020 Audi R8 V10 Performance Suzuka Gray 2012 Mercedes Benz C63 AMG Black Series Obsidian Black |
NavyBlue39.00 r33_RGSport13001.00 |
03-04-2024, 04:48 PM | #3 |
253
Rep 271
Have them chamfer the edges of the brake pads. Should solve it.
Salottox5m225.50 |
03-04-2024, 05:54 PM | #4 |
32
Rep 88
You don't even drive the car, what's the problem
snowbimmer5291.50 |
03-04-2024, 06:01 PM | #5 |
262
Rep 953
The little ol lady who only drove it to church on Sundays comes to mind, but the reference probably wouldn't work with the younger crowd.
In any event, yeah, super low miles there. You can also go to ceramic pads, lots of folks do it with various cars/brands. Not a cheap answer, but if it's driving you crazy it definitely works. |
03-04-2024, 10:08 PM | #6 |
39
Rep 39
Seaford1152.00 snowbimmer5291.50 |
03-05-2024, 09:10 AM | #7 | |
1152
Rep 1,697
Worth a try…… |
NavyBlue39.00 |
03-05-2024, 12:54 PM | #9 |
216
Rep 197
Drives: Alpina XB7
This is a super common problem with M-Sport brakes across all models.
Mine are especially squeaky when it’s below 40 degrees. As others have said; try doing a few hard stops from a decent speed. This usually makes the squeaking go away temporarily. |
NavyBlue39.00 |
03-05-2024, 11:37 PM | #10 | |
776
Rep 569
Drives: 2019 M5 Competition
There is a few things that work temporarily but, good luck getting them to do anything about it under warranty. It's complete BS. Go over to the F90 M5 forum and see all the hell we deal with. The only option is some aftermarket pads, but even then the squeal seems to come back. And the aftermarket pads are not cheap, and they're not great options either. Not to mention it's absolutely ridiculous to have to remove perfectly good OEM pads for aftermarket to get a squeal to go away, That comes back anyway. I had 4 brand new OEM rotors and OEM pads installed about 6-8k miles ago, they were good until about a month ago. Squeal comes back. The was worse before the service, but silent for 6-7 months, then its back. There are a few things you can try, but none of them work long term. It doesnt seem to matter the climate. Ive had people say in Arizona (where im at) there is more dust and heat, and thats why they squeal. But then there is people in cold wet climates saying it also. There is hot and humid climates, same thing. There doesnt seem to be a rhyme or reason. And it's a complete crap shoot if your car will do it at all. Some do it horribly, some dont do it at all. It's very odd. They suggest 50-60-70MPH or so slam on the brakes all the way to 0, do this 3-4 times, and the squeal will go away for a little bit. But it always comes back for me. But it kind of works for like 1-5 days. LOL. |
03-06-2024, 08:01 AM | #12 |
216
Rep 197
Drives: Alpina XB7
My favorite part is BMWNA claiming that it’s totally normal because “that’s what happens with high performance brakes.” Like we’re driving a McLaren Senna or something…
NavyBlue39.00 |
03-06-2024, 03:58 PM | #14 |
Rep 66
My M8 started squealing too! It's so embarrassing, especially at school pickup. Feels like everyone stares like I'm driving a bus or a garbage truck!
My dealer also said its "normal" and couldn't do anything about it. |
snowbimmer5291.50 NavyBlue39.00 |
03-06-2024, 08:00 PM | #15 |
Not a good Canadian sheep!
1279
Rep 1,115
It's outrageous!
snowbimmer5291.50 ChiefM43.50 |
03-06-2024, 09:51 PM | #16 |
5292
Rep 1,819
Drives: 2022 M850 GC - Carbon Black
My M850 has made nary a peep in over 35,000 miles. Not once.
Same size big ass land yacht. Same weight. Same length. Same width. 86% of the horsepower of an M8. Never had trouble stopping from high speeds or staying on the road during spirited driving. My 2 F90s drove me insane. Figure it out, BMW. |
NavyBlue39.00 |
03-07-2024, 07:20 AM | #17 |
61
Rep 46
I have experienced this issue with my G87 M2. The brakes squeal like a trash truck. I have found that it mostly occurs if the weather outside is cold (40's and below) and if I haven't washed the vehicle in a while. Im not sure if built up brake dust contributes or not. Dealer also said it was due to the performance pads. Oddly enough my F97 X3M never made a single noise.
As far as a recommendation, Akebono makes ceramic pads that are silent and cut the brake dust down 95%. They may be a worthwhile investment if yours are particularly noisy, or constantly noisy. |
NavyBlue39.00 |
03-07-2024, 04:27 PM | #18 |
Chief Warrant Officer 4
44
Rep 30
Drives: 2016 CLA 4MATIC Sport
Master mechanic here. Still waiting on my 24 M850i to delivered. Have been a Porsche guy and Mercedes guy since my early 30s, before then was a poor Honda and Acura kid. Needless to say, I do all my own work. 2020 with 3500 miles? Ok let me brake this down.
The squealing you hear is one of 3 things. Foreign object (think small rock) between brake pad and rotor, the brake pad vibrating at high frequency, or a wear indicator. Let me explain the last two. When brake pads are installed all guide pins in floating calipers are lubricated, and anti squeal compound is applied to the back of the brake pads. The anti squeal is essentially a light glue, some manufacturers use shims and a soft backing on brake pads to prevent the use of anti squeal. These statements apply to the rear brakes of the 8 series. The front brakes are fixed 4 piston calipers. The brake pads come with adhesive on the back. This adhesive is effectively the anti squeal. Your car is 4 years old. Regardless of mileage, dirt, grime, salt all work their way in and unstick the pads. I am not saying the bmw tech is right, it’s not normal, but if these are original pads, hate to say it but yeah this is to be expected. Another possibility is that the 8 series doesn’t have brake wear sensors on all 4 corners. This is a common cost cutting measure these days, even in high end cars. What this means is a brake pad is squealing because it’s about to ruin a rotor, on a wheel without a brake pad sensor. Anyways, from a blue collar guy who ended up being more successful than he ever thought he would be, this is my advice to you. Go to harbor freight, get a jack and some jack stands. Make friends with a mechanic and inspect your front and rear pads inboard and outboard pad on each wheel. If thickness is good on all four corners, feel your rotors from the inside of the machined face to the outside. It should feel smooth with no lip on the outside edge. If you grooves or waves, this points to a foreign object embedded in your brake pad. If all looks good, remove your rear calipers and grease the pins and apply anti squeal compound to the back of your brake pads. If you still have a squeal, replace your front brake pads as you can not apply anti squeal to them. Hope this helps. Chris Last edited by ChiefM; 03-07-2024 at 04:30 PM.. Reason: Grammar |
NavyBlue39.00 |
03-07-2024, 04:39 PM | #19 | |
1279
Rep 1,115
My expertise is pretty limited but it did the job for me on that car anyway. And it was a real squealer. The stuff dries out and gets pastier. I'm sure BMW does at least this when servicing the brakes ??? |
03-07-2024, 04:50 PM | #20 | |
44
Rep 30
NavyBlue39.00 |
03-07-2024, 05:37 PM | #21 |
1279
Rep 1,115
I've wondered before if this would help.
Take each pad and do this. On the metal back side where the pistons touch and push the pad, cut small groves in the metal. Take an angle grinder with a thinner disk on it and cut grooves. Not too deep. In some type of pattern . Maybe ? this would help break up that contact between the piston and the backing plate of the disk. I dunno? Seems like it could work. |
NavyBlue39.00 |
03-07-2024, 09:57 PM | #22 |
216
Rep 197
Drives: Alpina XB7
Seeing as you don’t yet have a BMW in your possession yet, you would’ve saved yourself some time typing out all those paragraphs by doing a bit of research on the 2018-current M-Sport brakes. The problem doesn’t have to do with any of the things you mentioned. It’s a well documented issue that most likely has to do with the brake pad compound BMW used. Similar to brand new carbon ceramics on certain hypercars; they squeak constantly. It seeems that it has more to do with the hardness quotient of the pads/rotors. People have simply replaced the pads and the squeaking stops. |
NavyBlue39.00 wesleyan921414.50 |
