10-11-2007, 07:43 PM | #45 |
Moderator
559
Rep 4,240
^^Yeah, these AWD drive machines arent very light either. Lets not forget the drivetrain loses they suffer from. I cant wait to shed 150pounds off my 135i. 3100lb with 330hp(the real power rating) is nothing to mess around with.
- 04 Honda S2000(gone)
10-11-2007, 08:18 PM | #46 |
Zoom Zoom
38
Rep 1,069
Why would bother going through the effort of ruining your car for something that probably wont make that much of a difference anyway? I also severely doubt you would be able to remove that much weight without making some real compromises to the car's driveability.
In the garage: 2022 G80 M3 Manual - Portimao Blue
10-11-2007, 08:37 PM | #47 |
Moderator
559
Rep 4,240
I dont think you know what your talking about. How is shedding 150lbs of weight going to ruin the driveablity??? Sorry man but that makes no sense. I have enough experience in the ''scene'' to know what I'm doing. Have u ever heard of the Lamborghini Superalegga? Its basically a Gallardo with 10more hp and a 154lb weight reduction. You dont even want to know the premium they charge for that?
10-11-2007, 08:46 PM | #48 | |
Zoom Zoom
38
Rep 1,069
Do yourself a favor, if you want a light car, buy light car. Buying a heavy car and trying to make it light will only cost ridiculous amounts of money.
10-11-2007, 08:53 PM | #49 | |
Moderator
559
Rep 4,240
10-11-2007, 09:18 PM | #50 | |
Zoom Zoom
38
Rep 1,069
Again, to get 150 pounds off of the car, you are going to have to do a lot more than modify the batter and wheels, which, even then, are pricey parts that make it least cost-effective option out there, at least in my opinion.
10-11-2007, 09:19 PM | #51 | |
Moderator
559
Rep 4,240
10-11-2007, 09:24 PM | #52 | |
Zoom Zoom
38
Rep 1,069
You can obviously do whatever you want; its not my car. Just dont tell me I didnt tell you so...
10-11-2007, 09:27 PM | #53 | |
Moderator
559
Rep 4,240
10-11-2007, 09:30 PM | #54 |
Zoom Zoom
38
Rep 1,069
Good luck... but I'll have a 20 taped to my fridge that says you cant do it for a reasonable amount of money.
10-12-2007, 12:08 AM | #56 |
94
Rep 2,012
The only problem i have with shedding weight is ruining the perfect 50/50 weight ratio. And as for other methods of weight removal. Getting a CF roof skin, or a simple moon roof delete would shave off another 50 lbs or so. A titanium exhaust would shave off 20-25 lbs. And when the time comes, light weight flywheels will shave off 5-10 lbs. Cf drive shaft will shave off more. And all these not only reduce the weight of the car overall, but also gives advantages in other areas. Cf roof = lower center of gravity, light weight fly wheel + CF drive shaft = less rotating mass = less power drain and the obvious advantage of having a titanium exhaust, the flamed canister/tip look
10-12-2007, 02:10 AM | #57 |
Stay a while and listen...
21
Rep 375
10-12-2007, 02:22 AM | #58 | |
21
Rep 375
IMO 50/50 is overrated. In a performance oriented setup less weight is greater period. As we all know, weight effects every aspect of the car from acceleration, braking, cornering, top speed, etc. It really doesn't even matter if you raise the center of gravity. A proper setup can easily account for an unideal weight bias and make it a strength. |
10-12-2007, 04:15 AM | #59 |
94
Rep 2,012
sure, when you only track the car, the lighter the better. But when the car's your DD. You'd have to be more careful. Say you have high center of gravity, if u want to counter that, u'd have to get stiffer springs/sway bars to counter the body roll.
10-12-2007, 06:53 AM | #60 | |
11
Rep 394
If you want to see an extreme example of weight loss, check this out... A guy who has taken his 3350 lb. STI down to under 2700 lbs: http://************/2ctfj4 Now, some of his stuff is a little out there. But it shows what is possible with judicious lightening. I agree: if you want a light car, buy one. But 150lbs would be damn easy. As to STI vs 135: the STI (and Evo) game is ridiculous traction. They can put down every one of their ~300 hp due to excellent suspensions and sophisticated AWD hardware with LSD's. That will be the trump card over the 135i. Right now, we already know the 135i will have problems with traction (witness 335i, and no LSD for 135), so it will be closer than you think. |
10-12-2007, 07:01 AM | #61 |
1846
Rep 4,836
Man you people have to stop arguing on this form. The car hasn’t even been released yet and there are more pissing matches then some of the Audi forums. Comparing three yet to be released cars (STI, 135i, and Evo.) Good times.....
10-12-2007, 07:31 AM | #62 | ||
11
Rep 394
10-12-2007, 08:23 AM | #63 |
1846
Rep 4,836
I figured posting specs of the new STI was relevant to this thread. My point of arguing was more for the back and forth about weight reduction. But thanks for enforcing the point!
10-12-2007, 10:50 AM | #64 |
Zoom Zoom
38
Rep 1,069
I should add an addendum to my statement: "and without turning it into nothing buy a metal box." Clearly, the obvious solution is to remove every seat but the driver's, remove all the sound deadening material, remove the AC, etc. That probably wont cost you much but all you will have then is something closer to a race car than a real road car. This is what I meant when I originally posted "ruining driveablility".
10-12-2007, 11:50 AM | #65 | |
21
Rep 375
IMO the 135i should start pulling on the STI around 85mph due to DTL. What do stock STI's normally dyno? 250's? 260's? It seems an average 335i dynos >270's (aHH i benchraced again!) This site's going to be the death of me! |
