07-28-2021, 10:11 AM | #1 |
4100
Rep 3,214
cool paper on BMW F1 engines
Thought some people might get a kick out of reading this, it was written by Super Mario several years ago. I came across it last night. It's an interesting read for F1 fans that geek out on the technical side of things.
http://sd-2.archive-host.com/membres...urs_BMW_F1.pdf |
10
prompt292.00 Bubbles2753.00 charlie_m77.00 overcoil3078.50 Pugnacious82.50 Killed by Death12756.50 grannyknot953.00 EdM54069.50 Atavus74.50 MontyB11417.50 |
09-14-2021, 08:07 AM | #2 |
77
Rep 169
Thanks for this! I can't imagine designing things to run for a certain number of *hours*; it's a fine line between long engine life and catastrophic failure.
09-14-2021, 09:13 AM | #3 |
804
Rep 535
Interesting read, thanks for sharing!
Current: 2023 Volvo XC60 B6 Ultimate Thunder Grey on Blonde Polestar Enhanced
Previous: 2018 340 xDrive M-Sport Mineral Grey Previous: 2016 328 xDrive Alpine White |
09-14-2021, 05:14 PM | #6 |
#buildnotbought
10965
Rep 4,910
You can see one of these engines on display in the BMW museum in Munich.
Really intereresting, it's way smaller than you'd expect (than I expected at least). All the connectors, barb fittings etc are also really small, way smaller than normal automotive connectors etc. Obviously to save weight, but it gives a bit the impression that it's a model scale engine The clutch is also pretty interesting.
M5Rick60860.00 |
09-15-2021, 08:12 PM | #7 | |
77
Rep 169
Not to be confused with the so-called DeSaxe layout, where the bore centerlines are slightly offset (they don't point directly to the crankshaft axis). At least that is my understanding. Last edited by charlie_m; 09-16-2021 at 03:42 PM.. |
09-16-2021, 08:12 AM | #8 |
34189
Rep 11,637
Great article! Thanks for sharing!!
Sir 7ewis, 7X FIA Formula One World Championship, World Driving Champion. 100 Wins. 101 Pole Positions. 54 Fastest Laps. Actual Rain Master. Leave me to it, Bono. One Race Win in each of his 15 years in F1. Most Laps Led in Formula One. The Centurion. |
09-16-2021, 09:31 AM | #9 |
4100
Rep 3,214
MKSixer34188.50 Killed by Death12756.50 |
09-16-2021, 09:38 AM | #10 |
34189
Rep 11,637
Don't forget the metallic confetti when the seamless shift transmissions were introduced!! The first real glitter bombs!!
