08-02-2019, 11:24 AM | #1 |
4555
Rep 3,516
Looking for advice M850i or the M8?
Hi All,
I been searching around quiet a bit and curious what others have to say about the thought going through my head.... Went to the dealer test drove the M850i and was impressed to say the least. Went home doing research ran across the M8. Fast forward to today you can order the M8 or Comp version. Here is my pickle!! Here is what I am after. I have been looking around for a fun sports car to have tune, mod, potentially (rarely) track with. I thought about F-type, 911, and some others but he M8 catches my eye the most. I know there might be another vehicle to put my money on say Austin, Merc, or others so if you believe at that price point something else would blow me away please share. I am new to the higher end sport cars coming from Mustang, Vet and others. (please do not suggest waiting for the C8, I will give that a few years of production before even thinking about buying one). Disclaimer: I do not care about value of trade, I plan to beat the shit out of it for the fun factor!!! If things break I will fix it, not a show car but a fun car. Okay so my questions if anyone is willing to help me out here; I don't see the value in getting the comp version for 17hp, but is there something else I am missing??? Can anyone with first hand experiences tell me if the difference in M850 and M8 is worth it? Will the aftermarket be good for the M8 or is it already at its max without crazy mods like removing engine and building a new one for more power? EDIT: Forgot to add the wrench.... Local dealer is offering just shy of 13% off a show room M850i that he says they can tune to the M8 power from a local shop.......... Thoughts on this?
08-02-2019, 03:34 PM | #2 |
1316
Rep 2,349
The main thing with the Comp is about the suspension and other small changes. Here is the copy paste from the press release. In my mind I wanted the Comp Pack on my M6 because I knew the car was a bit heavy and large, anything that could help slightly was a good thing in my mind
Competition models with specific chassis tuning. The standalone configuration and tuning of selected chassis components helps the new BMW M8 Competition Coupe and new BMW M8 Competition Convertible to unleash their dynamic talents with even greater intensity. The vehicle setup has been carefully adjusted to the engine’s higher output, generating an exclusive racing-car feel and producing a driving experience that richly indulges the emotions. The Competition models’ bespoke modifications translate first and foremost into superior steering precision, transitional responses and cornering dynamics. It starts with the extra-stiff engine mounting – resulting from an increase in the mounts’ spring rate from 580 to 900 N/mm – that benefits the Competition models’ precision on turn-in. Increased camber at the front axle, meanwhile, enhances their ability to absorb lateral forces through highspeed corners. And fitting the toe links with ball joints instead of rubber mounts has led to even more precise wheel guidance at the rear axle. I don't think anyone here has driven the M8 yet. However what I will say comparing the M850i to my M6 which is the 600ps 700nm version that from idle to about 5000rpm they felt the same. But above 5000rpm the M850i really did drop off - you can see this in the tech specs of the M850i where the torque starts to drop off at 4600rpm. By 6500rpm torque drops off by 30% in the M850i whereas the M6 has dropped off about 7% at 6500rpm and still pulls hard to 7200rpm. I suspect that you could replicate this if you went for a drive in an M5, ultimately the F90 M5 is very close to the M8 and feel how it compares near the top of the rev range. The S63Tu4 that comes in the M5 and M6 has the same forged rods as the new X3M and X4M S58 engine so the rods should be fairly strong - a common problem with my version of the S63Tu is bent rods. Plenty of people are running ~700-750hp and haven't broken any engines yet so perhaps they'll be ok with a whole lot of extra power. You can easily tune the M850i to 600hp without a problem at all. However the suspension and other chassis differences are huge between a real M and one that isn't. Again you could go for a drive in an M5 and compare it to the M850i and you'll see how much more aggressive the M5 is.
SCOTT26 "So as an admirer of the M5 and a potential customer of an M5 Touring. I would run naked around the streets of Garching if they were to offer one."
08-02-2019, 04:05 PM | #3 | |
4555
Rep 3,516
08-02-2019, 08:11 PM | #4 |
Living the Dream
36
Rep 69
Drives: '19 M850i Convertible, '19 X5
I agree. I went from an F10 M5 to the M850 and the M5 is a more aggressive beast that feels a little crisper and tighter as opposed the M850 which has plenty of power and speed but is just a tad soft especially when cornering at speed or changing directions so it makes for an excellent GT cruiser that as one of the reviewers put it (and I'm paraphrasing) you can drive it hard for a little while but anything more spirited than that for a longer time (especially if thinking about taking it to a track) you may want to go for the real M. I loved my M, but this fits my needs and wants for now (it's my daily driver and I love the little bit of extra comfort on the roads) but I can't say I don't miss the M at times when I want to have some real fun!
Heaven is where the police are British, the chefs are Italian, the mechanics are German, the Lovers are french and it is all organized by the Swiss.
Hell is where the police are German, the chefs are British, the mechanics are French, the lovers are Swiss, and it is all organized by the Italians. |
08-03-2019, 10:51 PM | #5 |
1691
Rep 2,699
Drives: 23 X5MC
M850 if you like more comfort and less money
M8C much better handling, more precise the plain M8 , fastest,obviously cost the most If money was not a consideration I would go M8C. Now the Aston Martin is a notch above the BMW in my opinion, maybe not in performance but it is one sweet looking car, especially if you have a British accent. |
08-03-2019, 11:00 PM | #6 | |
4555
Rep 3,516
The 8 series has my eye and the seat fit me very well. (I'm 6'2" at 315lbs, not obese just wide as hell). The F-type fits okay as well. The 8 series just has three options, that had me a bit confused, but thanks the here I think the M850 is out for sure. So now maybe the M8 or M8 C..... choices.... lol
08-04-2019, 08:34 AM | #7 |
1691
Rep 2,699
Drives: 23 X5MC
They are all fine cars, good luck with your choice. Buy and drive what you like! I agree the jag has a sick exhaust
08-04-2019, 10:01 AM | #8 | |
419
Rep 280
08-04-2019, 10:57 AM | #9 | ||
1913
Rep 4,128
Drives: M235i & G30 540i
The biggest thing for me though is I just don't think the M8GC is worth the $30k+ premium over both of the cars. The extra that makes the M8 a full M model is it really worth $30k+ more than the M850i? In addition, it comes with an uglier front bumper. I am having a hard time justifying the extra price. As for the M850i the seats are not as supportive as the ones on the M8 so tossing it around will be better in the M8 but the M5C has great support in its seat. All this to say I agree that the OP should consider the M5C also.
Lack of money is not the problem. It is merely a symptom of what's going on inside of you! - T Harv Eker
Follow me on Insta https://www.instagram.com/bmwm_life_/ https://www.instagram.com/autogiftua/ https://www.instagram.com/phoenixbmwlife/ |
08-04-2019, 02:35 PM | #10 | |||
419
Rep 280
08-04-2019, 02:44 PM | #11 | ||||
1913
Rep 4,128
That will make the experience tossing it around a lot better. Not that I plan on brutalizing it but in moments of spirited driving I prefer to be snug in the seat with the right amount of support.
edwarjejeega418.50 |
08-04-2019, 06:50 PM | #12 | |||||
419
Rep 280
phoenixbmwlife1912.50 |
08-05-2019, 12:35 PM | #13 |
23
Rep 30
08-05-2019, 05:10 PM | #14 |
67
Rep 141
If money not questions there is no doubt to take M8C, and there is no test drive\reviews at that time to say that is similar filling like f90 m5. I ride on M5 f90 and 850m, diffrent fill when deive. Emotions from car its not only flat specs. Also in M8 Bmw promise totally different fill from M5 of driving and that will be fastest BMW ever on Nurburgring. (Even say that will be faster than 911) We all live in marketing world so M8 will be diffrent to fill, and also to drive.
