01-05-2021, 04:08 PM | #1 |
56
Rep 71
Drives: 2024 X5 50E
Window issue ?
Hey all!
Having an issue with drivers door window... Have the bring to dealer every few months for a readjustment. It won't go all the way up into the seal and leaves an air gap allowing in a lot of wind, noise and in some instances drops of water. Anyone else with issue? Only drivers door but then again I'm the only one in the car usually. |
01-05-2021, 09:31 PM | #2 | |
1603
Rep 2,935
If I pop the up one time, it leaves a gap. If I do it again or hold it, it closes completely. Same when I lower. If I drop it, it goes 90% and I have to push down again to get 100% down. |
01-07-2021, 09:58 PM | #3 |
1290
Rep 1,658
There's a way to reset this via the switch, turn ign on, start with fully closed window then press and hold the switch all the way down and keep holding for a few seconds after it stops then holding all the way up and keep holding for a few seconds after it stops then release. This is mainly used when the auto up/down feature isn't working and may also help when not closing fully.
01-07-2021, 10:31 PM | #4 | ||
56
Rep 71
Drives: 2024 X5 50E
01-10-2021, 09:55 PM | #5 |
1290
Rep 1,658
Resjudicata1603.00 |
