09-15-2023, 10:23 PM | #23 |
9052
Rep 7,621
Ok, mine finally updated. I had the car sitting in my garage while I washed it and when I went to move it over 5ft and turned it off it started running. Just finished recoding with Bimmercode. There is now an option called FBS. Anyone heard of it? From the limited info I found it enables other sounds for the car - iD8, Mini and Rolls. I enabled the one called BMW 2021 which they seemed to say was iD8. We'll see how it is tomorrow when I finally drive it. There are also more ASD options. There's the general on off and then specific ASD things like burble, up shift, etc. I turned them all off as ASD is just a horrible idea on BMW's part.
09-16-2023, 06:06 PM | #24 | |
4269
Rep 4,335
09-16-2023, 06:11 PM | #25 | |
4269
Rep 4,335
Good luck and now hopefully with the OTA on the car you'll get the final step to apply it. That's where the hazards "bug" comes into play but since you've already toggled them on off hopefully the OTA bootloader kicks in. 👍 |
09-16-2023, 06:12 PM | #26 | |
264
Rep 839
What do you mean by iD8?
09-16-2023, 06:38 PM | #27 |
9052
Rep 7,621
09-18-2023, 07:20 PM | #28 |
4269
Rep 4,335
iD8 the shit show of a large screen with literally all hard buttons even some that are mind boggling (ACC distance control and Speed Limit) nuked from the steering wheel. Upside is supposedly with iD8.5 they've redone the equivalent memory buttons to mimick them. Won't believe it until I see it as right now on iD8 there are 4 vs the "redo" matching the 8 available with physical buttons.
Either way it's a 2 step process: flick the iD8 wheel up so it displays the screen and then either scroll/press the wheel or just touch the screen. I say I doubt it as with iD7 you can program what I'll call discrete memory settings. For example on the M850i #3 pulls up the bass trim itself. On iD8 tried that but it won't do just the bass trim but rather just the audio sound menu. So more scrolling, etc. |
09-19-2023, 10:18 PM | #29 |
249
Rep 172
You’re saying I just need to toggle the hazards on and off a few times? And that will take my (multiple times) stalled update process over the finish line?
This must be a joke. But of course I need to try it now. |
09-20-2023, 09:42 AM | #31 | |
9052
Rep 7,621
09-20-2023, 09:43 AM | #32 |
9052
Rep 7,621
I did it because, easy enough and nothing to lose, but have no clue if it actually did anything. Where did the hazard idea come from? I missed the origin of it.
09-20-2023, 10:01 AM | #33 |
4269
Rep 4,335
That would be from me as when my dealer upgraded the M850i to 07/2023.33 the tech included the attached printout of the diagnostic as to why the OTA wouldn't install. I LOL as I had never used the hazard lights once in 3.5 years of ownership. So definitely a bug in the OTA bootloader preconditions check and hence the advice to at least try toggling the hazards on/off while on a drive.
snareman9051.50 |
09-20-2023, 10:14 AM | #34 | |
4269
Rep 4,335
LOL'd on iD27 and hard buttons. Ironically though apparently Volkswagen has gotten their proverbial heads out of their asses and are indeed bring hard buttons back albeit to the steering wheel only for now. However, the article I read of an interview with their design chief indicated that's the start basically due to consumer backlash and they are listening to their customers. |
09-20-2023, 11:30 AM | #35 | |
9052
Rep 7,621
bloozemanAZ4268.50 |
09-24-2023, 09:01 PM | #36 |
249
Rep 172
Toggling hazards on and off (a few times) did nothing fit me. 03/2023.67 is still sitting ready in the car and I’m supposed to follow the in car instructions. LOL.
Now, Park Assist inactive? That’s an option to switch off somewhere? Here I go down another rabbit hole again… |
09-24-2023, 10:40 PM | #37 |
9052
Rep 7,621
I think was did it for me finally was moving the car 5ft in my garage. The car apparently has to be cooled down for it to run, so it never ran after a drive. Then I washed my car in my garage and when I was done I moved it from the center back to the side of the garage and it ran.
