08-09-2023, 09:19 PM | #1 |
37
Rep 53
coolant leak, line upgrades?
Hey all,
I'm about to pick up a used 2019 m850i (25k miles) and want to do some preventive maintenance on it. I haven't seen it in person but the PPI noted that he smelled some coolant popping open the hood but couldn't find any leaks. The used dealership selling it to me said they couldn't find any leaks either and said they cleaned under the hood (noted might have been some spilled there) and said no leaks (did a coolant flush too) after checking again. How hard is it to get a dealership to swap out the potentially leaking lines with stronger/brass/aluminum parts? Sorry just a bit paranoid and want as least trouble as possible lol. I will be extending the warranty with the Platinum program too. Thanks! |
08-09-2023, 11:51 PM | #2 |
4603
Rep 3,547
They won't do what you are asking "upgrade" of the lines.. They will replace with OEM if a leak is found.
2022 M8 Comp Convertible
cfm56d7b5948.50 |
08-10-2023, 09:23 PM | #3 | |
148
Rep 552
I would suggest a custom 95C tstat |
08-11-2023, 06:10 AM | #4 |
5949
Rep 10,319
That’s correct - unfortunately. BMW has been increasingly using plastic parts where constant cooling and heating cycles will cause the part to fail, usually after the lease expires. Coolant flange is one such part. Should be replaced after 30K miles.
08-11-2023, 06:27 AM | #5 |
37
Rep 53
08-11-2023, 09:50 AM | #6 | |
4603
Rep 3,547
A simple hose replacement you want to do and say your AC stops working they will have to prove that the part you replaced caused the AC to break.... That is how you need to think about it.
08-11-2023, 11:46 AM | #7 |
48
Rep 128
Well, let me tell you about my coolant leak. Was driving on interstate and the car goes into limp mode. Error of "chassis stabilization" came up on a warning on the dash. Thinking it was a serious drive-train issue, pulled over. Nothing seemed to be amiss. Car was put on flatbed and hauled to dealer.... It was discovered not a drive-train issue, but a coolant leak that some 25 cent clamp let coolant leak into a computer module that controls some drive train components. Short story, computer bank, wiring harnesses had to be replaced. In doing this, the motor had to be pulled out of engine bay. Car in shop for 10 days, waiting for parts, and it would have been a $5400 repair bill, thank goodness I had the warranty yet.
08-11-2023, 03:34 PM | #8 | |
37
Rep 53
08-12-2023, 01:23 PM | #9 |
48
Rep 128
Just using my example on how repair costs can get out of hand with these cars when out of warranty. Of course, it is a crap shoot, but an expensive extended warranty can give piece of mind at least. Been my experience that when I had it, it was never used, when I did not have it, I got socked with some expensive bills.
