05-01-2017, 10:33 AM | #45 | |
2032
Rep 8,339
05-01-2017, 10:41 AM | #46 |
#buildnotbought
10859
Rep 4,893
They are just as much related as say time is related to power
Or for example as antych said litres and meters. You can make a perfect formula to link those physical quantities. What makes it silly is wanting to have more meters than litres...
antych246.00 |
05-01-2017, 10:54 AM | #47 | |
246
Rep 435
Drives: 2017 BMW M4CP SO
rainfall161.50 |
05-01-2017, 12:40 PM | #48 | |
723
Rep 912
Each motor has a different objective. For example, a transport truck motor isn't able to rotate at high speeds, thus not allowing the equation of horsepower to truly demonstrate how strong it actually is. They make monstrous torque. The job of those motors is to pull so it makes sense. Performance automotive motors have different objectives as well, and with lower reving turbo motors becoming more mainstream we're seing a bias to higher torque figures. "The perfect engine produces ample torque at low rpm and sustains that output to the redline. The amount of torque produced is directly proportional to the air flowing through the engine." - Car and Driver http://blog.caranddriver.com/horsepo...he-difference/ "Remember, you cannot have horsepower without torque, but you can have torque without horsepower!" - Hot Rod http://www.hotrod.com/articles/hrdp-...sepower-guide/ |
05-01-2017, 01:33 PM | #49 |
36
Rep 86
So tell us what the OP DID ask and grace us with your wisdom by answering his question - sound reasonable?
05-01-2017, 02:56 PM | #50 |
25
Rep 296
You always measure TQ and calculate HP. You build an engine to make peak TQ where you need it for your task. Peak TQ is the max power output of an engine, The longer you can maintain TQ the higher your HP because RPM's usually climb faster than TQ falls off.
If you have two equal cars with equal weight and drive ratios operating at their peak TQ values they would run exactly the same speed and times even though the engines are working differently... Example: 300HP Civic at 8k RPM peak TQ of 197 VS 300hp Charger at 4k RPM with a peak TQ of 394 They are making the exact same power level by differing means. No replacement for displacement as low RPM TQ gets you moving and does not fall off drastically allowing you to continue to make decent power past peak TQ. Large displacement limited in peak RPM due to mass of engine components. Small displacement tuned to run peak TQ at higher RPM's can make less peak TQ but have an equal power output. Forced induction can significantly increase TQ output in both applications and move that value earlier or later into the power band depending on turbo size and efficiency. Smaller sooner, larger later. Diesel’s make so much power because of the high CR and fuel source which also requires much beefier components and the heavier components severely limit peak RPM. Diesel’s also do not have a carburetor/throttle body they increase/decrease RPM by adding or removing fuel not controlling airflow.
2007 Z4MC, 1" drop H&R Springs, Evolve Tunning, Headers, K&N Filter, RPI scoop, Red top high energy coils, UUC Red Poly mounts (none bolt-through), UUC Lightweight Flywheel with Organic Clutch and a custom exhaust with just one AeroTurbine muffler.
05-01-2017, 03:09 PM | #51 |
25
Rep 296
My question in the title, let’s say a Porsche 911 turbo has 580 HP/ 780 Torque why can’t it have 750HP/ and 580 torque?
580HP / 780TQ puts peak power at 4,008 RPM 750HP / 580TQ puts peak power at 6,791 RPM I would believe the second to be truer for that vehicle and engine configuration, so it can and often does…
05-01-2017, 03:30 PM | #52 | |
1125
Rep 2,564
So 750 HP peak may occur at 8,000 rpm where torque has dropped off to 492 lb ft. While peak torque can occur somewhere lower than 8,000 rpm. |
05-01-2017, 03:41 PM | #53 | |
723
Rep 912
For example, square bore and stroke versus longer stroke or larger bore, how many valves, flow of the heads, is it force inducted or not, size of motor, variable valve timing etc. These differences will result in the different style of power output. These differences in the Porsche motor are probably more down to the limitation of the rev range, versus the forced induction and compression ratio. |
05-01-2017, 04:01 PM | #54 |
460
Rep 1,133
Hang on mate. Typically an internal combustion engine will have two output values HP and Torque. Yes they are different values, However, for most naturally aspirated engines the HP value will be larger than the torque. In supercharged engines I think it changes to higher torque than HP. I think that is what OP was asking here. Further, engine design such as piston diameter vs stroke have an effect on HP vs Torque values as well. Having a large diameter piston and relatively short stroke will yield larger torque numbers I think, it's called an over square engine like Harley Davidson, they make a lot of torque vs HP. Then again, I might have missed something here.
05-01-2017, 04:02 PM | #55 | |
246
Rep 435
Just to show how stupid this is, let's take 911 turbo s numbers: 580hp and 750 Nm - and convert torque to imperial units 580hp and 550 lb ft - solved, more power than torque like the OP wanted, but wait, you can express power in kW like they do in some countries 427kW 550 lb ft - now it's less power than torque again, magic! You can't do maths and physics like that. It's idiotic. And there's no unit called "torque" either. To compare two measurements they need to be of the same kind, like power, length, volume, temperature, etc. You can compare miles to inches, but you can't compare miles to gallons. Having more torque than power is like having more miles than gallons. I don't know if I can be any clearer. It's like explaining physics to a child. |
05-01-2017, 04:22 PM | #56 | |
246
Rep 435
The reason people are confused, is because those numbers look similar, being roughly in the same range. That is only because scientists and engineers picked units that are easy to work with. If you express torque as "ounce force inch" instead of pounds, 550 becomes 105600, or 0.75 in kNm. I don't think anyone would ever ask this question if they knew that porsche turbo s produces 0.75 "torque". |
GuidoK10858.50 |
05-01-2017, 04:41 PM | #57 | |
2032
Rep 8,339
05-01-2017, 04:45 PM | #58 | |
2032
Rep 8,339
He didn't ask why do cars rated in nm hp have lower numbers than sae. He asked why does one nm car have higher torque numbers vs another nm car that has higher hp numbers. What variable causes thst to happen. Last edited by Fundguy1; 05-01-2017 at 05:00 PM.. |
05-01-2017, 04:51 PM | #59 |
2032
Rep 8,339
The original poster wanted to know how a car could have higher or lower hp numbers vs torque. Pure and simple. Since hp uses torque to be calculated, the answer is a car could have higher torque vs hp if peak torque is at low rpm. The car could have lower torque vs hp if peak torque is at a higher rpm. Simple easy. No other explanation is needed. READ THE ORIGINAL POST AGAIN. It doesn't matter which system is used to measure hp, sae or nm, the answer is the same. He was asking the relationship between the two, not the calculated values, etc.
05-01-2017, 04:54 PM | #60 |
2032
Rep 8,339
Post title
Why do cars have higher torque outputs than horsepower? Op My question in the title, lets say a porsche 911 turbo it has 580 HP/ 780 Torque why cant it have 750HP/ and 580 torque? Nowhere is what you're offering asked for. The answer is if it made max torque high rpm it would. And if he wants more specific it would require jigher rpm still if he wants nm hp and not sae hp. Move along folks. Next. |
05-01-2017, 06:05 PM | #63 | |
2032
Rep 8,339
05-01-2017, 10:04 PM | #64 | |
#buildnotbought
10859
Rep 4,893
I can make my torque or power 0.0000001 or 100.000.000 or 593.678.456.787.876.112 and they're exactly the same. Just change the way the unit of measurement is expressed. The unit of measurement sets a scale.
05-01-2017, 11:12 PM | #65 | |
2032
Rep 8,339
05-01-2017, 11:22 PM | #66 |
2032
Rep 8,339
Why some other people are arguing about different rating systems is irrelevant.
Yes, there are different standards used by different countries Yes, they were developed by engineers as a way to quantify power Yes there are formulas to compare the numbers of each standard to each other Yes, the power numbers as a result will look different depending on what standard is used. All irrelevant. The question was how can torque of one car be higher than that car's hp and torque of a different car, entirely different make, model, etc, be lower than the other cars hp? The answer is how the engine develops its power over the span of rpms it covers. This is the torque curve. Max torque can be achieved early on or later in the curve. Early shows a lower hp figure. Later a higher one. Simple, easy, straight forward. No comparing standards, conversions, etc. |
