08-03-2023, 09:45 AM | #1 |
37
Rep 53
best all season tires?
Hi all,
I’m looking at a M850i that’s coming with HR cooling package and seems to have P Zero Summer tires. Sadly I live in the Midwest, so if I get this car I need to get All Season tires. What is the optimal way to do so? buying P Zero All Season tires or buying new wheels with them on it. Around how much would each option cost? Thanks in advance |
08-03-2023, 10:13 AM | #2 |
4125
Rep 273
I'll tell you, I've been very impressed with an all season set I put on my M850 from Vredestein. In fact, I liked them so much I put an all season set on my wifes' former '21 X3 M40i.
TireRack seems to like them as well: https://www.tirerack.com/tires/tests...y.jsp?ttid=280 |
08-03-2023, 12:23 PM | #3 |
Leave the gun. Take the Canoli.
9143
Rep 7,688
I was talking to the Michelin rep at the MiX event about my similar quandary. I asked him how bad it is to actually swap tires back and forth for summer and winter on the same wheels versus buying new wheels. In the end it sounds like the answer was to get the PS4 all seasons and leave them on year-round. I'm not tracking my car and I'm not likely to notice much of a difference in them compared to the regular PS4s that I have now for daily driving, and I don't have to buy new wheels. I'm not looking to drive the car in the snow but would like to be able to drive it when it's below 45° and maybe when there is a chance of a slight dusting as opposed to my car sitting dormant in the garage from November to April.
Current: 2023 Santorini Blue ///M8 ||| 2023 X3 M40 --> 2025 X5 M60
Retired: 2021 Enzian Blue ///M4 ||| 2018 ///M4 ||| 2017 ///M4 ||| 2014 435i ||| 2009 335i Coupe ||| 2007 335i Coupe |
08-03-2023, 02:03 PM | #4 | |
4125
Rep 273
This. |
08-03-2023, 02:11 PM | #5 |
9143
Rep 7,688
Side note, edited for all the errors that my voice to text and lack of proofreading at work caused.
On the swapping tire topic I told him I see all these things on the internet about how it is bad or not bad. He said these are so low profile tires that if you don't find someone that really knows what they are doing with swapping them that they can damage the bead.
bloozemanAZ4302.50 |
08-04-2023, 08:37 AM | #7 | |
37
Rep 53
08-04-2023, 10:17 AM | #8 |
9143
Rep 7,688
I figure I'll just try and sell mine to someone local if I can find a taker. Otherwise they'll sit in my basement. I'm assuming tire shops don't buy used tires?
08-04-2023, 11:09 AM | #9 | |
4125
Rep 273
So immediately after acquiring any new leased car, I put on a new set of tires and store the OEMs. That way, when I turn the car back in I just put the OEMs back on and I don't ever get dinged on tire replacement costs. You'd have to buy a new set anyways after 3 years so why not drive on them from the get go? |
snareman9143.00 |
08-04-2023, 12:21 PM | #10 | |
9143
Rep 7,688
BMWGUYinCO4125.00 bloozemanAZ4302.50 |
08-04-2023, 12:39 PM | #11 | |
37
Rep 53
08-04-2023, 02:38 PM | #12 |
705
Rep 245
Drives: MY24 Porsche Taycan
I love my Continental ExtremeContact DWS06 Plus. Good grip and handling and will even do burn outs and power slides. Also as I didn’t like the shorter sidewalls that created too much gap, I had 245/40 and 275/35 installed.
MY24 Porsche Taycan | Neptune blue | Black |
MY24 Audi SQ5 Prestige | Mythos black metallic | Magma red Nappa Retired: MY23 BMW 840i Coupe | MY21 Audi SQ5 | MY19 Audi A6 |
08-08-2023, 12:35 PM | #13 | |
99
Rep 49
Don't recommend swapping tires on same set of wheels. If you have the room, time, and want best or safest performance, separate wheels and tires for winter or summer are ideal. All seasons are fine if you are not pushing the limits in winter or summer weather. I personally like michelin cross climate 2 all weather tires for climates like Chicago. These sacrifice a little summer performance for considerably better winter performance. |
08-11-2023, 06:12 AM | #14 |
5914
Rep 10,288
08-14-2023, 02:28 PM | #15 | |
Rep 1
New here so not sure my way around on how to properly post etc. so hopefully this works. Doesn't this impact the accuracy of the speedometer? If so, how much? Are any other things impacted by the increase in the sidewall percentage (e.g. suspension, xdrive, etc.)? |
08-14-2023, 05:48 PM | #16 |
114
Rep 50
I'm running PS4s and I wanted to get PS4 all seasons for the PNW winter (I survived through last winter with the PS4s, not recommended). I have 295/30 on the front and 305/30 on the back, but can't seem to find matching PS4 A/S with either all 4 non-run flats or all 4 run flats.
Does anyone know if this configuration is even an option with Michelins? What would be the second best choice? |
08-18-2023, 01:59 PM | #17 |
268
Rep 848
Are they quiet? Michelin is known for being a super quiet tire!
08-18-2023, 02:21 PM | #18 |
1010
Rep 776
I live in the Chicago area and I vote for the Continental Extreme Contacts.
Grip is excellent for regular street driving. I drove it last winter, sometimes through snow, without any issue. I’m not trying to set records here, so on a winter day with heavy snow, you have to drive carefully no matter what tires you have. But I found them good enough to do the job. Wet traction is fine as well. They ride smooth. I’d get them again. |
08-18-2023, 05:03 PM | #19 |
36
Rep 11
I like the little bit of extra rubber there, it looks great. Do you notice any difference in the ride and/or handling?
08-19-2023, 05:57 AM | #20 |
705
Rep 245
Extremely quiet. In the High Performance A/S, they’re highest rated in just about every category on Tire Rack.
08-19-2023, 05:58 AM | #21 |
705
Rep 245
Ride is much better and quieter and haven’t noticed any difference in handling.
08-19-2023, 06:04 AM | #22 |
705
Rep 245
The speedo is off ~4% so speedo reads 65, actual speed 67. Ride is smoother and quieter. My 8 is RWD.
MY24 Audi SQ5 Prestige | Mythos black metallic | Magma red Nappa Retired: MY23 BMW 840i Coupe | MY21 Audi SQ5 | MY19 Audi A6 Last edited by Accentu8; 08-19-2023 at 08:59 AM.. |
