08-22-2023, 08:48 PM | #1 |
147
Rep 546
Secret menu: Coolant temps and more
With the mileage display showing, car on, hold the mileage button on the left turn signal arm. Hold it for like 30 seconds and a small box will show up.
The bc button will be the only button you use. In the menu, there should be locked or something to that effect. Select that by holding the bc button. The code will be the sum of your last 5 digits in your vin. Just press the bc button as many times as needed. From there you'll be able to choose coolant. I just put in a custom tstat, with cruising temps in sport plus getting into low 80C. In traffic, around 100, all with ambient temps around 90F. Please share the temps you see and the ambient temps. |
