Bimmerpost
4 Series
Technical Topics Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin Rear Diff Leak (2020 M340i xDrive)
      05-18-2023, 09:50 AM   #89
rahimhussainar@gmail.com
No_Country
11
71
Drives: 2020 M340i
What are some of the main symptoms to look out for?
I got clunk and whine.
Is the clunking only apparent in a specific manner?
For my car, if I am just cruising at like 2-3mph or a really low speed, and then press on the gas casually, the car will jump forward or jerk forward. But it does this inconsistently.
I have an xdrive tho so idk if that changes things.
Other than that I can’t notice much
      05-18-2023, 05:40 PM   #90
xnick101
652
826
Drives: 2021 BMW X3 M
2020 BMW M340i  [0.00]
I have that clunk when you take off kind of hard at low speed. I heard that has to do with something else back there. But yes if you have a grinding sound at WOT its likely the diff has metal in it.
2014 BMW 335i M-Sport - SOLD
2020 BMW M340i - SOLD
2021 BMW X3M
      07-08-2023, 02:45 AM   #91
F32Fleet
F32Fleet's Avatar
3637
10,394
Drives: 2015 435i
Low speed noises can be normal on an clutch based LSD.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
      10-04-2023, 09:46 PM   #92
hayko_M340
141
241
Drives: 2020 BMW M340I
Revisiting thread once again, at 47K miles. Warranty ends in 3K, gotta take it in service before it ends. Last time at 41K miles dealer noted it was "Sweating" by breather hole and normal per SIB. Also noted car was lowered on Dinan springs and aftermarket wheel which was supposedly what added on to it, yea right lol. Is there actually a redesigned diff cover and does it actually fix the leak or would it be pointless to put the car back to stock and take it in again. Any info greatly appreciated. When was this supposedly updated diff cover released? Vehicle is a February 2020 production date. Per dealer "performed visual inspection found rear differential is not leaking it just appears sweating from differential
cover per sib 330321 it is normal, upon inspection found that incorrect tires size are installed in front and rear.
Advise customer this can cause premature wear to the driveline.vehicle
equipped with aftermarket suspension and wheel and tires will contribute to creaks."
      10-05-2023, 11:35 PM   #93
xnick101
652
826
Yes, the new part # diff cover has revised breather holes which does resolve the leak. After BMW replaced my diff cover it has never leaked again.
2021 BMW X3M
      10-06-2023, 03:23 AM   #94
hayko_M340
141
241
Do you have part # by any chance? Was it 33-11-8-742-755 or is this the old one? Thanks.
      10-06-2023, 10:10 AM   #95
xnick101
652
826
I believe so, that's the new part number that shows up on realoem as well. You can go to the BMW parts department and they can confirm it as well as they can see the dates on the part numbers.
2021 BMW X3M
      01-02-2024, 07:16 AM   #96
thatm340i
Drives: m340i
I got my rear differential seal replaced they dropped the rear diff in order to do it and now i have a error code saying rear diff axle lock reduced does this mean i have to get it reprogrammed or recalibrated
      02-28-2024, 09:42 AM   #97
Austin027
Drives: 2020 BMW M340i
Hey I just bought my 2020 M340i with 23k miles and I'm getting gear oil leaking from the rear up top. I read this entire post multiple times and some people say part number 33-11-8-677-753 fixed the issue and some say 33-11-8-742-755 is the fix. I'm trying to make sure I get the correct differential cover so I don't have to do the job twice. Thanks for the help
      03-29-2024, 09:59 PM   #98
huzidada
33
Drives: 2021G21 M340 Xdive
What years M340i do these affect? When was the old cover superseded with the new one?
      04-08-2024, 10:20 AM   #99
Davg31
Belgium
110
314
Drives: G23
33-11-8-742-755 this one was fitted on cars before 2019, reference 33 11 8 677 753 from 02/2019, so it would be logical to assume that it's the correct version (plus it costs 4x less, which is often the case when it's the reliable version).
      04-08-2024, 04:28 PM   #100
Davg31
Belgium
110
314
Drives: G23
After checking, one would be for sdrive, the other xdrive, however no idea how to recognize a corrected version (new oil breather).
      04-15-2024, 07:42 PM   #101
none64
Germany
Drives: BMW F30, F16
So, anyone could confirm the right part number for RWD US spec M340i?
Tags
b58, g20, leak, leaks, m340i, oil, rear diff
g20
