10-10-2023, 06:55 PM | #25 |
BMW Noob
565
Rep 258
Turbo, exhaust and intake fab work nearly wrapping up before it goes for heat shielding
11
10-10-2023, 07:47 PM | #26 |
4826
Rep 3,702
Very nice work and once again thanks for keep us all updated.
2022 M8 Comp Convertible
10-12-2023, 12:07 PM | #29 |
11231
Rep 27,989
wild!
10-12-2023, 02:44 PM | #31 |
99
Rep 35
Drives: Bmw M8 Competition Coupe
Hell yea!! I received my turbos from Vargas last month so it’s nice to get an idea of what’s needed to accomplish this.
I saw a m8 on IG a few days ago having a 1,200hp car that ran 8.93 1/4 mile. This wasn’t you was it lol? |
JVYasF807.50 |
10-12-2023, 04:21 PM | #34 |
BMW Noob
565
Rep 258
Anything at 1000whp is going to need the same upgrades with stronger rods and likely pistons (even though the stock pistons have proven themselves pretty stout so far at the 900+whp level on Mr Vanos’ M5 I believe). Big item to go beyond that is solving the fueling issue which we are accomplishing with addition of port injection and new in tank pump setup to support e85. Other option is to go with modified cams and upgraded HPFP’s (spool is supposed to offer something soon), but even with this, you may hit limit on what direct injection fuel injectors can flow. I am not a fan of add on meth injection but that definitely can help with shortage of fueling too.
10-12-2023, 04:30 PM | #35 | |
713
Rep 493
Drives: 997.1 GT3 Shark, ex E92 M3 ZCP
10-12-2023, 04:37 PM | #36 |
BMW Noob
565
Rep 258
Anything is possible …. To get equivalent power levels on pump gas you may likely need to go a larger size on turbos and you’d probably want to either add meth to help prevent detonation and/or drop compression down a bit with piston selection.
DrivesAlot13.50 |
10-12-2023, 04:46 PM | #37 | |
99
Rep 35
Not a fan of the spoiler they added but it sounds insane. |
10-12-2023, 06:18 PM | #38 |
BMW Noob
565
Rep 258
From their build list they are running slightly smaller turbos (G25-660’s) and using upgraded cams for additional direct injection fueling along with water/meth injection. End of the day That’s a killer pass they put down
10-12-2023, 06:26 PM | #39 |
42
Rep 95
10-12-2023, 07:12 PM | #41 |
257
Rep 354
Interchillers don’t work and are terrible. There’s a reason you don’t seem them doing anything. They just don’t work well and add risk of intercooler failure/hydrolock. Always better off with a good A2A intercooler or W2A with ice tank. If you really wanna help with cooling, adding meth injection after the intercooler really works wonders. My IAT in my z06 are 59° @7200rpm making north of 1200w
KillerBlackRhino612.00 |
10-12-2023, 10:36 PM | #42 |
2361
Rep 1,943
Drives: Many, BMW.
But stock S63 use cross bank manifolds, where as yours resembles the traditional N63 design of each turbo being designated to each bank…
10-12-2023, 10:47 PM | #43 |
BMW Noob
565
Rep 258
Yeah the OE setup is for factory twin scroll turbos and hence the cross over manifold to balance cylinder firing order. No more twin scroll setup here and much higher boost levels so manifold runner lengths aren’t as critical to try and balance exhaust pulses.
JVYasF807.50 |
10-13-2023, 11:41 AM | #44 |
1072
Rep 1,914
This is quite interesting and seems to be well planned. I read this will be a daily driver, but under what conditions will you be able to use a car with 1200 horsepower? Seems like the only application would be drag racing?
