09-13-2011, 11:26 PM | #24 |
Skittles, OT OG
2340
Rep 649
Between school, work and vacation, I haven't had time to play with my T3i much. There was a German car show this weekend so I went with my friends and had a little photo shoot. These are 12 of the 230 pics I took that day. Let me know what you guys think. This way my first time ever attempting rolling shots too. Oh, and these pics are straight from the camera, no editing at all.
IMG_0595 by dsaadeh, on Flickr IMG_0599 by dsaadeh, on Flickr IMG_0602 by dsaadeh, on Flickr IMG_0702 by dsaadeh, on Flickr IMG_0714 by dsaadeh, on Flickr IMG_0724 by dsaadeh, on Flickr IMG_0733 by dsaadeh, on Flickr IMG_0728 by dsaadeh, on Flickr IMG_0752 by dsaadeh, on Flickr IMG_0773 by dsaadeh, on Flickr IMG_0783 by dsaadeh, on Flickr IMG_0801 by dsaadeh, on Flickr |
09-14-2011, 08:27 AM | #25 | |
1291
Rep 7,389
You need to add some color and contrast to a bunch of these. Simply pull the RGB curve down a tiny bit in the middle and bump up the contrast. You might start shooting RAW now and use something like LightRoom or DxO to do your RAW conversion and adjust the color and contrast. Dave
09-14-2011, 01:39 PM | #26 | |
Skittles, OT OG
2340
Rep 649
Thanks for telling me what exactly needs to be edited too. I have Aperture 3 on my MBP, so I'll play with the RGB and contrast tonight hopefully. I was shooting on automatic mode. I need to figure out how to change the shutter speed. I read on here that you should shoot in TV mode with a set shutter speed. I need to learn my camera a little more. |
09-14-2011, 01:53 PM | #27 |
4230
Rep 5,731
Drives: 2019 M2 Competition
So far this dude's photos aint all that...that ring picture is kinda gross
09-14-2011, 02:01 PM | #29 | |
1291
Rep 7,389
When you go to RAW you'll gain a stop or two of dynamic range if you "expose right" (to the right of the historgram). If you expose as far to the right as possible without blowing out highlights, then you'll maximize the dynamic range and detail of your image, preserving as much shadow detail as possible. There are highlight warning lights that should be turned on because they'll blink in the preview LCD if you've blown out a highlight. When shooting Tv or Av or Automatic, you expose right, generally, by setting the EV at +. Generally +1/3 to +1EV is enough, but I use as much as +2EV in certain circumstances. If your blinkie warning lights go off, the lower EV and even go to -EV if there are whites in sunlight, etc. "Expose Right" is a RAW technique. Your in-camera jpegs will look washed out, but when you do RAW conversion you'll pull your brightness levels down. I've never used Aperture, but lots of pros use it, so I think it's good and will do all the things we're talking about here. I use DxO Optics Pro because it's optimized for each of my lens/body combinations and corrects for the errors in my lenses, particularly zooms at wide angles. LightRoom does some of that, but not at every aperture and every focal-length like DxO. Dave
09-14-2011, 02:01 PM | #30 |
4230
Rep 5,731
09-14-2011, 02:05 PM | #31 |
1291
Rep 7,389
Where's your stuff?
09-14-2011, 02:13 PM | #32 |
4230
Rep 5,731
09-14-2011, 02:30 PM | #33 | |
76
Rep 5,114
Any more pictures for us to review for you Silver? Have you worked out your lighting yet? Unfortunatly shooting in automatic mode doesn't let you choose where your camera is focusing, it thinks it knows better, so experiment lots with different focus points on your camera. Center focus is always most acurate, however it can cause distortion if you focus on the point you want, then rotate the camera a lot to get it into the position you want, so make sure you shoot the focus point that is most appropriate. It will make a difference to your photos. Also, try using the "rule of thirds" sometimes it feels a bit weird framing a photo that way, sometimes you'll get your best results and expression that way. (really works best with backgrounds) but when shooting your macro, you're going to be pretty centered. It all comes down to experimentation. And like dave recommends, the best thing you can do overall, is use RAW images, you'll see how much of a difference in control over the image you will have. |
09-14-2011, 02:39 PM | #34 |
471
Rep 6,798
I recommend shooting in Av mode as well, assuming I'm not shooting in Manual. The only time I would switch to Tv mode is at night sometimes or when shooting sports. Tv mode may be ok to use for rolling shots, but not necessary. I wouldn't use Tv mode for stationary cars though.
09-14-2011, 07:00 PM | #35 | ||||
Skittles, OT OG
2340
Rep 649
I haven't figured out my lighting yet. The only thing that is preventing me from doing so is time. When I get a chance to sit down and research it, I will because I don't really know much about it. I also noticed that it's hard to focus it where you want in automatic mode. For example, when I was trying to take a picture of the car behind us using the rear view mirror, it would focus on the mirror itself. The one I posted is the only shot that I got in focus. And I think it probably could have been better. I didn't know what the "rule of thirds" is until I googled it. It makes sense but does feel awkward shooting like that. I will definitely try that very soon. I'm not sure how to shoot RAW images. Is that a setting on the camera? Sorry, I'm still noobish at this. Lol Quote:
09-14-2011, 07:31 PM | #36 |
76
Rep 5,114
AV and TV are both great ways to help you learn how the camera works without putting you in the deep end. P is also a good mode to shoot in. It is sort of a preset auto mode that you have some minor control over, but if you watch the aperture settings and the shutter speed settings, you'll get to know what affects will occur at different settings.
I think AV might be most helpful for you with shooting jewlery as you'll be messing with the depth of field a lot to get parts of the ring, or all of the ring in focus, but you're going to need a tripod, or at least something very steady to lean the camera against. But overall, the top things i would recommend for you are: Never ever shoot in automatic mode again as best as you can. Put the camera in RAW (that's under the quality settings) or RAW and Jpeg take the camera out of automatic focus and only choose what focus point you want Take the ISO setting off of Automatic and put it where it needs to be, the camera makes up some interesting numbers sometimes. do lots of reading on how aperture, ISO, and shutter speed work together don't be afraid to ask questions or post pictures to get feedback, ignor rediculous comments and concentrate on constructive ones. It doesn't matter if a picture is good or bad, but what matters is how you can improve it. Turn on blinking highlights on your picture review in the camera settings, it's quite handy learn how to read a histogram (it kind of goes with the blinking highlights for usefull information) If in doubt, take multiple shots of the same thing with different settings. choose witch you like most later, and learn from what settings you used for those photos. If anyone can add to that, please do, that's just what i could do off the top of my head. I'll keep thinking for any i missed. |
09-14-2011, 07:46 PM | #37 | |
471
Rep 6,798
If you're shooting F1 racing, football, etc you want to make sure the objects are in focus and not blurred, so you may care about shutter speed. That's when you use Tv. If you're shooting non/slow-moving objects, assuming you have enough light, changing your shutter speed from 1/100s to 1/500s doesn't give you much. However, changing from f/11 to f/4 does. It all depends on your composition as well. Sometimes you want a small aperture if you want the background to be clear, but other times you want the background to be out of focus as much as possible, so you choose a wide open aperture. This is just one of many parameters... you should also be thinking of DoF, focal lengths, ISOs, etc as well. It gets complicated, but start out simple and expand your knowledge by reading and with practice. In all honesty, you should check out the Zack Azaria videos I posted here for a good tutorial: http://www.e90post.com/forums/showpo...&postcount=316
09-14-2011, 07:49 PM | #38 | |
76
Rep 5,114
09-14-2011, 10:09 PM | #39 |
1291
Rep 7,389
I don't see any need to switch from Av to Tv or vice versa when going from stills to fast. There's a direct relationship between the aperture and shutter speed and you can see it in the viewfinder. If you're in Av mode and want to raise the shutter speed, then you either increase the aperture or raise the ISO. The opposite happens in Tv mode. Just be aware and always look at your final settings in the viewfinder.
Dave
09-15-2011, 02:09 AM | #40 | |||
Skittles, OT OG
2340
Rep 649
09-15-2011, 02:21 AM | #41 |
Skittles, OT OG
2340
Rep 649
These first two shots are one of my favorites that I see other photographers do. I'm not sure which is the proper way to take it though. Holding the camera horizontal or vertical?
IMG_0634 by dsaadeh, on Flickr IMG_0635 by dsaadeh, on Flickr This picture bothers me because I cut off a small part of the bumper. IMG_0636 by dsaadeh, on Flickr IMG_0676 by dsaadeh, on Flickr Shooting an picture like this, where would you guys focus the camera at? IMG_0754 by dsaadeh, on Flickr I really like this picture because you seem to focus on the AW E36 M3 but when you look to the left in the distance, you see the IB E46 M3. IMG_0777 by dsaadeh, on Flickr Thoughts? IMG_0785 by dsaadeh, on Flickr This rolling shot kinda bothers me. It looks like the car is stationary but you know it's not because the wheels are spinning. IMG_0809 by dsaadeh, on Flickr |
09-15-2011, 06:59 AM | #42 |
76
Rep 5,114
what ISO is, is sensor sensitivity.
think of it like an amplifier, when it's nice and quiet, everything is crisp and clear, but as you turn the volume up, you still hear everything, but you sooner or later start to get distortion as you turn it up. ISO sort of responds the same, the higher the sensitivity, the more noise it gets, but that being said, a lot of people are scared of noise when it really isn't something that we should worry about as much as we used to. Generally you want it low, but if you need a higher shutter speed, but you want lots in focus, you're going to have to compensate for the slow shutter speed by raising the ISO so that in turn you can bring the sutter speed up. ISO can be a good friend when you get used to using it. Keep watching the Zach Aries videos, I believe he explains how they work in conjunction with eachother. Dave/Dcstep shoots regularly at high ISO and I very very rarely notice noise in his photography. Part of that is because he shoots in RAW and part is because he has a great understanding of how to compensate for noise (amung other things) whie shooting in that format. I won't be surprised if you see 20,000 shutter clicks before you're really comfortable with all the settings and it all becomes natural. Just shoot, and shoot, and when you think you're done shooting, shoot some more. also since you're starting to shoot in RAW, i'm going to try and find a link for the codec so your computer can read RAW files so you don't have to worry about jpeg files. |
09-15-2011, 07:01 AM | #43 |
76
Rep 5,114
09-15-2011, 07:03 AM | #44 | |
471
Rep 6,798
On the other hand, as someone previously posted some killer lightning shots... I'm thinking more about shutter speed (1-5s) as opposed to aperture (f/8+).
