06-02-2023, 11:53 AM | #1 |
Rep 13
STOCK 2023 M340 XDrive Jb4 Map 2 Dyno Results
Hello group. I got my Stock 23’ M340 Xdrive on the Dyno (Mustang Dyno) today at R/T Tuning. They are installing an AA Catted DP, CTS Charge Pipes, MST intake and some other bits for me today. I asked that they Dyno the car before and after install. The car is running map 2 with the JB4 on 94 Octane. Hopefully this helps everyone wondering what Map 2 does on a new stock m340.
06-02-2023, 01:35 PM | #2 | |
95
Rep 140
This is stock? Around 400 hp?
06-02-2023, 04:22 PM | #4 |
26
Rep 101
Drives: 2023 m340i xdrive
06-02-2023, 05:35 PM | #5 |
258
Rep 245
They’re saying the only modification it has right now in those dyno runs is the map 2. So just a jb4. Not a stock car. They will then install the additional mods OP listed above and re dyno the car.
06-02-2023, 07:22 PM | #6 |
82
Rep 170
Did you get any baseline runs and numbers without the JB4?
2015 335xi Black/BLK, FBO BM3 Stage 2, AA FMIC, CTS Turbo CP, FabSpeed Sport Cat DP, MPPK airbox w/high-flow filter, 18" AG M310's black
06-02-2023, 10:41 PM | #10 |
Rep 13
06-02-2023, 11:19 PM | #11 |
95
Rep 140
06-03-2023, 05:19 AM | #12 |
83
Rep 88
06-03-2023, 05:53 AM | #13 |
258
Rep 245
Yes the jb4 is a modification. It is a piggyback tune. OPs numbers are with the only modification to the car being the piggyback tune jb4
06-03-2023, 11:07 AM | #14 |
95
Rep 140
Thank you very much. I ask this because some videos and info around the B8TU in 340's and 440's are state that it has around 400hp without any modifications.
06-03-2023, 01:58 PM | #15 |
Rep 10
Drives: M340i X-drive
So basically stock power levels haha, looks like the JB4 works right at the beginning of the RPM range and then the DME immediately squashes the extra boost
Also, you're there, WHY wouldn't you do a run without the JB4 *facepalm* .... |
06-03-2023, 07:13 PM | #16 |
258
Rep 245
No because it doesn’t stock have 400 hp at the wheels.
06-04-2023, 08:31 AM | #17 |
217
Rep 354
Drives: 2023 M340i
Should have run Map 0 and then Map 2 to see the difference!
06-04-2023, 02:17 PM | #18 |
Rep 13
I dropped the car off to see the difference between JB4 with and without mods. Going back later this month to see if there is any difference. Unfortunately there wasn't enough time to run after mods. But we will see
