05-09-2024, 09:01 PM | #1 |
35
Rep 14
Drives: BMW M850ix
Check Engine Light
Good evening quick question. The check engine light came on in my car, could some new wheels which I installed today cause such issue?
I replaced the OEM front 245/35/19, rear 275/30/19. With Front 245/35/20, rear 285/30/20. Car is 2020 M850i grand coupe. |
05-10-2024, 11:07 AM | #4 |
18
Rep 44
No. Not unless the people that installed the wheels damaged something like the headlight level switch. I bet it's just chance. You might want to make sure you don't have a rock in you grill gates. Sounds stupid but that was my first check engine light. Dealer was really good about not charging me. I have much larger wheels and tires on my car (two sets), they don't cause CEL.
05-10-2024, 11:32 AM | #5 |
35
Rep 14
Drives: BMW M850ix
Thanks for all the answers, after shutting off the engine overnight the check engine light went off ill continue to observe and let you guy know how it workout for me. thanks again
Seaford1173.50 bloozemanAZ4335.50 |
05-13-2024, 04:21 PM | #9 |
4534
Rep 7,586
If you don't have an OBD II reader scanner...you can stop by any automotive store like Autozone/AdvancedAuto/O'Reilly's/Pep Boys/NAPA/etc...and they can pull the DTC (diagnostic trouble code) that was set by the OBD II system.
Even if the light turned off...the code is still there. Once you have the code you can simply google the 5 digit DTC to find others that have been seeking info about that code. Or you can use the following site to either enter the 5 digit (generic codes) or the BMW specific hex (6 digit) codes: https://bmwfault.codes/ BTW, the Check Eng Light is emissions based...thus it will illuminate when anything associated with the car's emissions system sets a fault. This has been a federal mandate since 1996 in the US. Again, you don't have to wonder what caused the light to come on...even if you don't have a scanner...the stores mentioned above will retrieve OBD II codes for free in just about every state (exceptions may be Hawaii & California)
bloozemanAZ4335.50 BMWFC34.50 |
